Community Member
show translation-rule output
Hi Folks,
Is there a specific reason why show translation-rule output does not show rule 10.
There is what I mean, in the translation-rule below there is ten rules, but the output only show up to nine.
translation-rule 225
Rule 1 ^4034506511 000881641480675#
Rule 2 ^4034506512 000881641480676#
Rule 3 ^4034506513 000881641480873#
Rule 4 ^4034506514 000881641480674#
Rule 5 ^4034506515 000881641480677#
Rule 6 ^4034506516 000881641480885#
Rule 7 ^4034506517 000881641480678#
Rule 8 ^4034506518 000881641480679#
Rule 9 ^4034506519 000881641480680#
Rule 10 ^4034506510 000881641480670#
#show translation-rule 225
Translation rule address: 0x650E4DF0
Tag name: 225
Translation rule in_used 1
**** Xrule rule table *******
Rule : 1
in_used state: 1
Match pattern: ^4034506511
Sub pattern: 000881641480675#
Rule : 2
in_used state: 1
Match pattern: ^4034506512
Sub pattern: 000881641480676#
Rule : 3
in_used state: 1
Match pattern: ^4034506513
Sub pattern: 000881641480873#
Rule : 4
in_used state: 1
Match pattern: ^4034506514
Sub pattern: 000881641480674#
Rule : 5
in_used state: 1
Match pattern: ^4034506515
Sub pattern: 000881641480677#
Rule : 6
in_used state: 1
Match pattern: ^4034506516
Sub pattern: 000881641480885#
Rule : 7
in_used state: 1
Match pattern: ^4034506517
Sub pattern: 000881641480678#
Rule : 8
in_used state: 1
Match pattern: ^4034506518
Sub pattern: 000881641480679#
Rule : 9
in_used state: 1
Match pattern: ^4034506519
Sub pattern: 00881641480680#
Crazy
1 REPLY
Community Member
Re: show translation-rule output
I get the same behavior on 12.4(11)XW7. Looks like a bug in the show command. The test command works:
gwy1#test translation-rule 225 4034506510
The replaced number: 000881641480670#
If you change rule 10 to rule 0, then it will show up via the show command.
-steve
225
