Show
Hi.
It has some command where I can see percent bandwidth utilized? For example i want see how much of my link frame it is utilized.
Another question. It has some command where I can see the length of a packet, just one, em kbps?
Re: Show
If you want to monitor a link on the router without using snmp, you can simply use the show interface command, i would recomend changing the load-interval to 30. The figures over 255 show how busy the link is, 255 = 100%
Hope this helps
Silver
Re: Show
are you using switch (catOS) or IOS based device like router?
When you say 'Frame', do you mean frameRelay or ethernet frames?
Ajaz
85
