shrink CCM0301_log.LDF
We've running Callmanager ver 4.2(3) and BARS has been failing due to not having enough hdd space on the C drive. The CCM0301_log.LDF transaction log file is over 15GB!!
Is there a way to shrink the file?
CCM0301 database setting are as follows:
Recovery mode=Full
Transaction Log file setting set to "automatically grow file" with "unrestricted file growth"
Thanks in advance
Re: shrink CCM0301_log.LDF
For CCM0301
C:\> osql -E
1>use CCM0301
2>go
1>backup log CCM0301 with no_log
2>go
1>dbcc shrinkdatabase (CCM0301)
2>go
Also i'd recommend to change the unrestricted file growth to a fixed size to avoid this.
Once you're able to run BARS it will truncate the log so it's a good idea to program a backup every once in a while
java
if this helps, please rate
java
www.cisco.com/go/pdi
Thanks Java,
I will apply the commands in our maintenance windows.
When typing the required commands I got the following message below.
"C:\>osql -E
1> use CCM0301
2> go
1> backup log CCM0301 with no_log
2> go
The log was not truncated because records at the beginning of the log are
pending replication. Ensure the Log Reader Agent is running or use sp_repldone
to mark transactions as distributed.
1>"
I've not type the dbcc shrink command as I wasn't sure whether to carry on.
Any suggestions?
TIA
Imtiaz
153
