Community Member
Shutdown problems mcs 7800
we have a problem with mcs 7800.It's a windows 2000 5.00.2195 SP4 with call manager 4.2.
Is imposible restart or shutdown this machine without push the init bottom.
symptoms:
Windows close applications, lost ping and lost image signal but the server fails to shut down until you physically click the button.
any suggestion?
Re: Shutdown problems mcs 7800
If the server has ILO try that way, otherwise i don't see any other option that does not involve pushing the button on the server
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
we hanven't ILO
370
