signalization debugging
Hi, Im troubleshooting signalization between CCM 4.2 and cisco voice GW (3825). I assume that there is problem in codecs but I cannot find any type of debugging on GW router which can show me what codec were offered for this call from CCM. I tried these debugs and I dont see it.
AnnexG:
AnnexG Event Messages debugging is on
H.225:
H.225 Event Messages debugging is on
H.225 Q931 IE Details debugging is on
H.245:
H.245 Event Messages debugging is on
can somebody give me clue?
Thanks a lot.
Re: signalization debugging
are you using H323????
i would rather user a debug voip ccapi inout than those to see the capabilities
java
if this helps, please rate
java
www.cisco.com/go/pdi
yes, I use H323, I tried debug you wrote here, but still dont see codecs which are offered...
Hi Thomas,
Try 'debug h245 asn', which will show what capabilities the parties exchange. Here is a sample output. From the gateway's perspective, what is offered would be in an incoming Terminal Capabilities Set message. Within that message, look for the capabilitytable section for the list of codecs offered.
BR2#deb h245 asn
H.245 ASN1 Messages debugging is on
BR2#
BR2#sh deb
H.245:
Aug 7 16:25:02.109: H245 MSC INCOMING PDU ::=
value MultimediaSystemControlMessage ::= request : terminalCapabilitySet :
capabilityTable
capabilityTableEntryNumber 1
capability receiveAudioCapability : g722-64k : 60
capabilityTableEntryNumber 2
capability receiveAndTransmitUserInputCapability : dtmf : NULL
capabilityTableEntryNumber 3
capability receiveAndTransmitUserInputCapability : basicString : NULL
capabilityTableEntryNumber 44
capability receiveAndTransmitUserInputCapability : hookflash : NULL
Hope this heps.
Michael.
275
