signnaling on outbound call
have
CCM on 4.2.3srb
GW MGCP E1 ios 124.6T2
issue
on normal operation, user dial out 11 digits to reach outside. on ip phone we have the correct display of dialed number(11digits). we're discarded the first digits on route list before call going to pstn. we have an alerting tone, but when the call is connected, we have the number prefixed with two supplementary zero. in finally we have 4 zero . Does
anyone has solution?
on srst mode
no problem.
many thanks for advance
Green
Re: signnaling on outbound call
What if also at Route Pattern level you discard those first digits.?
To resume
For outbound call, users first dial 0 to get E1.
No digits manipulation on route pattern. discarded predot is made on route list to remove the first digit "0" to reach outside.Ex users dials 00130276768
When you hear alerting tone, the display of ip phone is correct "00130276768"
when the remote users answer and call connected, display on ip phone is "0000130276768" instead "0130276768".
on srst mode H323 gateway everything is ok
best reagards
102
