silent ringtone for cisco ip phones
I am trying to create a silent ringtone (no music) for cisco ip phones based on the specs given below. What is happening is the phone accepts the raw file (from the edited distinctive ring list). For every ring, there seems to be a clicking sound. Is there a way to fix it?
PCM File Requirements for Custom Ring Types
The PCM files for the rings must meet the following requirements for proper
playback on Cisco IP Phones:
• Raw PCM (no header)
• 8000 samples per second
• 8 bits per sample
• ulaw compression
• Maximum ring size-16080 samples
• Minimum ring size-240 samples
• Number of samples in the ring evenly divisible by 240
• Ring starts and ends at the zero crossing.
• To create PCM files for custom phone rings, you can use any standard audio
editing packages that support these file format requirements.
Hall of Fame Super Gold
Re: silent ringtone for cisco ip phones
for silent ring, just use the DND softkey.
I don't see it in softkey template. Am I missing anything here? or is it only for IP Manager Assistant?
I was able to create a silent ringtone with 2 software and used it successfully on a few ip phones. Posting it in case someone needs it for their use.
Thanks Kraghavansag for file
Thanks Kraghavansag for file sharing.
I was looking for same.
actually it depends on the version, 6.x and above have DND as a standalone feature
previous versions do require IPMA to use DND
java
if this helps, please rate
java
www.cisco.com/go/pdi
is there a document on cisco site which says that? I am unable to find any regarding the version difference.
I would take javalen word as autoritative, it's his job after all.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_0_1/ccmfeat/fsdnd.html
thank you so much. I was not looking at the right direction.
On the other hand, the wiki entry should be amended.
2547
