Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Silent Ringtone
Hi all,
I need a ringtone that is silent. My office uses CUCM 6. I found one and uploaded it and created one and uploaded, but the phone gives a tftp write error when I try and play it. I modified the ringlist.xml and it gives me the option to select it, but when I do it gives me that error.
Any help would be greatly appreciated.
Terry
Everyone's tags (3)
Hall of Fame Super Red
Re: Silent Ringtone
Hi terry,
Did you do this last step?
To cache the new Ringlist.xml file, stop and start the TFTP service by using Cisco Unified Serviceability
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_0_1/ccmfeat/fsrings.html#wp1020835
Cheers!
Rob
Re: Silent Ringtone
Rob,
I did perform that step as well, sorry I did not put that in the original post. I did just get it going though.
What I found was that after I uploaded the file that downloaded it would not work. I then made my own went in the system and deleted the first one and uploaded the new one and restarted the tftp services, and it still did not work. I thought I would just check my work and make sure it was ok and downloaded the file from the tftp server and opened it and found that it was still the first one. This time I stopped the tftp services first, deleted the bad file, uploaded the good file, and then restarted the tftp services. When I did that the new file was there and was working fine.
Thanks for the response.
Terry
Re: Silent Ringtone
Hey Terry,
Great work my friend
"Silence is Golden"
Cheers!
Rob
567
