Simulate calls in CUCM
Robin Zhu
I want to do pressure test for UCCX. Can I simulate 300~400 calls to route point in CUCM?
CUCM 8.6.2
UCCX 8.5.1
Hi Robin,
For internal testing in Cisco we use Camelot tool for pumping calls through CUCM.
http://wwwin-vts.cisco.com/camelot/
Its an internal link for this tool.
I am not aware about the 3rd party tools for this purpose.
Hope it helps.
Anand
Please rate helpful posts !!
8 Replies 8
Jaime Valencia
If you're asking if CUCM has built in some method to simulate calls for such purpose, no, it doesn't.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hi Java:
Do you mind to advice if there're other methods like third-party tools, or I have to code script via JTAPI? thx.
Hi Robin,
Hope it helps.
Anand
Honestly speaking , there is no built-in app which does this.Just curious to know the reason behind the testing.
Siva
Hi Anand:
I cant open the link you attached. Is that for internal only? thx
Robin
Hi Robin,
Yes its an internal link.
Anand
Pls rate helpful posts !!
Robert Thomas
Level 7
Level 7
Best you can use is sipp, it's an opensource tool that can generate SIP and RTP traffic to fill the system with load.
laurent.flipo
Hello
... or you can use some commercial solution : http://www.spectra2.com
Laurent
