Simultaneous Ring - voice hunt-group does not work
Hello all,
I have the request for simultaneous ringing while using a CME v 7.0, however the following configuration doesnt work:
voice hunt-group 2 parallel
final 3201
list 3201,85201,5201
pilot 5201
What we want is when someone calls 5201 to ring simultaneously to 5201, 3201 and 85201.
Any suggestions?
Many thanks in advance
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
What I am suggesting is that you cannot have hunt pilot and ephone-dn with the same DN as that creates a conflict and ephone-dn I believe will always be prioritized.  You need to either change the pilot DN to be something else or the ephon-dn to be something else.
Chris
Your best option would be to configure shared line appearance on the phones with ephone-dn 5201. If you do require hunt group then the pilot cannot be shared with another ephone-dn, you have both 5201 defined as pilot and a member.
HTH,
Chris
Hello Chris, thanks for your reply
So what you suggest is to remove the dn 5201 from a member? For example,
final 3201
list 3201,85201
pilot 5201
ephone-dn  1
number 5201
label 5201
name George
description George
I think i have tried that already  and didnt work, is the above what you suggest to do?
Again thanks for your prompt response
Chris
1281
