05-23-2014 05:15 AM - edited 03-16-2019 10:52 PM
Hi All,
Good evening. Can we configure one button for DN(Line) and SD. Our requirement is we need to configure one button for incoming and SD to a particular number.
Thanks in Advance.
Sankar.
05-23-2014 09:38 AM
Hi Sankar,
You probably have to look at PLAR configuration for it.
http://www.voipling.com/2013/10/adding-a-plar-automatic-ring-down-to-cisco-sip-phone-with-sidecar-key-expansion-module/
06-03-2014 03:25 AM
Hi Thomas,
The calls (inbound & outbound) would be passing through PSTN line, as it is not for internal. when ever an external customer calls complete DID number from a fixed number of their , it should hit that particular line button and for outgoing when ever we want to dial that particular PSTN number , we need to use the same button assigned to that particular external customer. So will this work?
Sankar.
06-03-2014 07:12 AM
