single number reach on cme - softkey mobility is not working
I've cme 8.6 installed on a cisco router 2921, ipphone are 7942G and 7962G, I've configured SNR, but when i want to use the softkey mobility to activate and deactivate SNR I've an issue it does not work. Have you got any ideas ?
My ephone-template is like that :
ephone-template  1
url-button 4 snr
park reservation-group 2
service phone webAcess 0
transfer max-length 13
softkeys idle  Redial Cfwdall Pickup Newcall Join Dnd Mobility
softkeys connected  Hold Endcall Park RmLstC Select Trnsfer TrnsfVM Confrn ConfList Mobility Flash
after-hours exempt
codec g711alaw
ephone-dn  11  dual-line
number 130
label LOUBAT Sabine - 130
description LOUBAT Sabine
name LOUBAT Sabine
mobility
snr 0685220037 delay 4 timeout 15
call-forward busy 8888
call-forward noan 8888 timeout 15
mwi sip
ephone-template  1
url-button 4 snr
after-hours exempt
codec g711alaw
the command mobility is added in ephone-dn
number 130
label TEST- 130
description TEST
name TEST
mobility
snr 06xxxxxxxx delay 4 timeout 15
mwi sip
Best regards,
Ludovic GUYOMARD
I think you have 2-points here
1- you should use cfwd-noan in the snr command that "call-forward noan" is restricted
2- I think your mwi will work without mwi-sip ,, if the above sol didn't help,, try removing also this mwi-sip
In fact the feature SNR is working but I'm unable to use the Mobility Soft key to activate or deactivate SNR on an IP PHONE 7942G/7962G.
How can I make the Mobility soft key operationnal ?
Best regards,
Certainly it is a fw bug
try to upgrade the IP Phone fw and check
Also I think the above 2-points need to check also
HI,I know this is a old post
HI,
I know this is a old post.
Did you find any solution? I have the same problem with a Cisco 7965G. SNR is working, but the Mobility Softkey dosent work. Cannet activate or deactivate SNR.
Best Regards
Jonas
772
