Single Number Reach (SNR) remote Destination, Problem
After configure the SNR, a guy (John) call the ip-phone (with its internal and external number), my cell phone rings, I answer, the cell is stalled.
But the call between the John's phone and my cell John is not connected, in the John's phone, you always hear the bells, as if nobody had yet won.
if i test with a call forwarding (forward all or no answer), it's good, no problem
Who have a idea?
It's a french intallation BRI.
CUCM v9.1 (BE6000)
c2901 v15.4(1)T (i have test with 15.3 and 15.2 version)
no error message in the router's debug q931 when in test SNR
Routeur-CUCM#
Dec 22 16:31:20.660: ISDN BR0/0/1 Q931: RX <- SETUP pd = 8  callref = 0x75
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x89
                Exclusive, B1
        Calling Party Number i = 0x2183, 'JOHN PHONE'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, 'External number IP-PHONE'
        Sending Complete
Dec 22 16:31:20.680: ISDN BR0/0/1 Q931: TX -> CALL_PROC pd = 8  callref = 0xF5
        Channel ID i = 0x89
                Exclusive, B1
Dec 22 16:31:20.692: ISDN BR0/0/1 Q931: TX -> ALERTING pd = 8  callref = 0xF5
        Progress Ind i = 0x8088 - In-band info or appropriate now available
Dec 22 16:31:24.700: ISDN BR0/0/0 Q931: TX -> SETUP pd = 8  callref = 0x77
        Sending Complete
                Standard = CCITT
        Channel ID i = 0x8A
                Exclusive, B2
        Calling Party Number i = 0x2183, 'External number IP-PHONE'
        Called Party Number i = 0x80, 'My CELL PHONE number'
                Plan:Unknown, Type:Unknown
        Redirecting Number i = 0x00008F, '117'
Dec 22 16:31:24.768: ISDN BR0/0/0 Q931: RX <- CALL_PROC pd = 8  callref = 0xF7
        Channel ID i = 0x8A
                Exclusive, B2
Dec 22 16:31:29.804: ISDN BR0/0/0 Q931: RX <- ALERTING pd = 8  callref = 0xF7
        Channel ID i = 0x8A
                Exclusive, B2
Dec 22 16:31:31.984: ISDN BR0/0/0 Q931: RX <- CONNECT pd = 8  callref = 0xF7
        Channel ID i = 0x8A
                Exclusive, B2
        Facility i = 0x91A306020100020103
                Protocol Profile = Remote Operations Protocol
                0xA306020100020103
                Component = Return Error component
                        Invoke Id = 0
                        Error = 3 not available
It seems to be configuration issue with SNR.
Check this document- https://supportforums.cisco.com/docs/DOC-27111
Manish
Thanks, i used this document for to check my configuration, but it does not solves my problem.
My SNR "works", the cell ring, but when i answer, the communication is not connected with John (external phone) and my cell, as if the CUCM did not see that the cell has answered.
I use a MGCP gateway, it's possible to just use the the SNR feature with this gateway's type?
Or it's requires a H323 gateway?
Hi, no idea for me?
I don't use the MVA, and for the MVA I know it takes a H323 gateway.
I tested with a trunk sip link and it's ok, SNR work.
It's possible to use the SNR with a MGCP gateway?
I have check with this document, but no succes for use with my MGCP gateway.
Can you help me please?
Thanks.
HI Gilles.
Can you please attach a screenshot of both Remote Destination and Remote Destination Profile pages.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Re: Single Number Reach (SNR) remote Destination, Problem
Hi Carlo, you can see my screenshot of both Remote Destination and Remote Destination Profile pages in the attached file.
Hi Gilles
Can you try to put Answer Too Soon timer to 500 instead of 1500 and send a deb isd q931 from your gateway?
Carlo
Hi Carlo,
It's the same problème with "Answer Too Soon timer to 500", but i tested with H323 gateway and Trunk Sip and it's ok, but no with MGCP gateway :-(
Gateway-MGCP#debug isdn q931
debug isdn q931 is              ON.
Gateway-MGCP#
*Jan  9 17:31:47.135: ISDN BR0/0/0 Q931: RX <- SETUP pd = 8  callref = 0x0D
        Sending Complete
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
        Channel ID i = 0x89
                Exclusive, B1
        Calling Party Number i = 0x2083, '296622525'
                Plan:Unknown, Type:National
        Called Party Number i = 0x81, '1228'
                Plan:ISDN, Type:Unknown
*Jan  9 17:31:47.167: ISDN BR0/0/0 Q931: TX -> CALL_PROC pd = 8  callref = 0x8D
        Channel ID i = 0x89
                Exclusive, B1
*Jan  9 17:31:47.191: ISDN BR0/0/0 Q931: TX -> ALERTING pd = 8  callref = 0x8D
*Jan  9 17:31:51.191: ISDN BR0/0/0 Q931: TX -> SETUP pd = 8  callref = 0x04
        Sending Complete
                Standard = CCITT
        Channel ID i = 0x8A
                Exclusive, B2
        Calling Party Number i = 0x2083, '0296642525'
        Called Party Number i = 0x80, '0290035006'
        Redirecting Number i = 0x00008F, '2001'
*Jan  9 17:31:51.563: ISDN BR0/0/0 Q931: RX <- CALL_PROC pd = 8  callref = 0x84
        Channel ID i = 0x8A
                Exclusive, B2
*Jan  9 17:31:52.415: ISDN BR0/0/0 Q931: RX <- ALERTING pd = 8  callref = 0x84
*Jan  9 17:31:52.967: ISDN BR0/0/0 Q931: RX <- PROGRESS pd = 8  callref = 0x84
        Cause i = 0x87F2 - Unknown cause value
        Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
*Jan  9 17:31:55.127: ISDN BR0/0/0 Q931: RX <- CONNECT pd = 8  callref = 0x84
*Jan  9 17:32:02.123: ISDN BR0/0/0 Q931: RX <- DISCONNECT pd = 8  callref = 0x84
        Cause i = 0x8790 - Normal call clearing
*Jan  9 17:32:02.619: ISDN BR0/0/0 Q931: RX <- RELEASE pd = 8  callref = 0x0D
*Jan  9 17:32:02.623: ISDN BR0/0/0 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8D
        Info Request i = 0x80
*Jan  9 17:32:32.179: ISDN BR0/0/0 Q931: RX <- RELEASE pd = 8  callref = 0x84
*Jan  9 17:32:32.183: ISDN BR0/0/0 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x04
*Jan  9 17:32:34.271: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/0/0, TEI 0 changed to down
*Jan  9 17:32:34.299: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/0/0, TEI 0 changed to up
I think if its a MGCP gateway then might need to re-route the call back to H.323 gw and back to CUCM. having said if its only mgcp gw in the call flow then it won't work.
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
Hi Gilles.
To be honest I always preferred SIP or H323 as signaling protocol.
Tomorrow I'll setup a LAB to test MGCP with SNR and I'll let you know
Carlo
ok Carlo, thank you very much for your help.
Good morning Gilles.
I reproduded SNR configuration in my lab with mgcp gateway.
Adjusting following timers, all worked good.
Answer Too Soon Timer: 500
Answer Too Late Timer: 30000
Delay Before Ringing Timer:1000
Try this settings and let me know
Carlo
i have the same problem with this timers.
Gilles,
Please collect a debbug isdn  q931 during these 3 situations
1) direct call to your mobile from an ip phone
2) forward your extension to your mobile and call your extension from another ip phone
3) From an ip phone, call your extensions removing call forward settings.
Carlo
Hi Carlo, this is my Q931 debug:
Thanks.
  • 1) direct call to your mobile from an ip phone
Gateway-MGCP#
*Jan 13 09:18:38.615: ISDN BR0/0/0 Q931: TX -> SETUP pd = 8 callref = 0x07
Sending Complete
Standard = CCITT
Channel ID i = 0x8A
Exclusive, B2
Calling Party Number i = 0x0081, '02966412xx'
Called Party Number i = 0x80, '067197xxxx'
*Jan 13 09:18:39.015: ISDN BR0/0/0 Q931: RX <- CALL_PROC pd = 8 callref = 0x87
Channel ID i = 0x8A
Exclusive, B2
*Jan 13 09:18:42.867: ISDN BR0/0/0 Q931: RX <- ALERTING pd = 8 callref = 0x87
*Jan 13 09:18:44.435: ISDN BR0/0/0 Q931: RX <- CONNECT pd = 8 callref = 0x87
*Jan 13 09:18:44.439: ISDN BR0/0/0 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x07
*Jan 13 09:19:00.415: ISDN BR0/0/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x07
Cause i = 0x8090 - Normal call clearing
*Jan 13 09:19:01.087: ISDN BR0/0/0 Q931: RX <- RELEASE pd = 8 callref = 0x87
*Jan 13 09:19:01.091: ISDN BR0/0/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x07
*Jan 13 09:19:03.159: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/0/0, TEI 0 changed to down
*Jan 13 09:19:03.187: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/0/0, TEI 0 changed to up
Gateway-MGCP#
  • 2) forward your extension to your mobile and call your extension from another ip phone
Gateway-MGCP#
*Jan 13 09:26:30.751: ISDN BR0/0/0 Q931: RX <- RELEASE pd = 8 callref = 0x89
*Jan 13 09:26:30.755: ISDN BR0/0/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x09
*Jan 13 09:26:32.843: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/0/0, TEI 0 changed to down
*Jan 13 09:26:32.871: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/0/0, TEI 0 changed to up
*Jan 13 09:26:48.923: ISDN BR0/0/0 Q931: TX -> SETUP pd = 8 callref = 0x0A
Sending Complete
Standard = CCITT
Channel ID i = 0x8A
Exclusive, B2
Calling Party Number i = 0x0081, '02966410xx'
*Jan 13 09:26:49.287: ISDN BR0/0/0 Q931: RX <- CALL_PROC pd = 8 callref = 0x8A
Channel ID i = 0x8A
Exclusive, B2
*Jan 13 09:26:53.119: ISDN BR0/0/0 Q931: RX <- ALERTING pd = 8 callref = 0x8A
*Jan 13 09:26:56.931: ISDN BR0/0/0 Q931: RX <- CONNECT pd = 8 callref = 0x8A
*Jan 13 09:26:56.939: ISDN BR0/0/0 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x0A
*Jan 13 09:27:03.431: ISDN BR0/0/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x0A
*Jan 13 09:27:03.915: ISDN BR0/0/0 Q931: RX <- RELEASE pd = 8 callref = 0x8A
*Jan 13 09:27:03.919: ISDN BR0/0/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0A
*Jan 13 09:27:05.995: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/0/0, TEI 0 changed to down
*Jan 13 09:27:06.023: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/0/0, TEI 0 changed to up
Gateway-MGCP#
  • 3) From an ip phone, call your extensions removing call forward settings.
Gateway-MGCP#
*Jan 13 09:29:35.527: ISDN BR0/0/0 Q931: RX <- RELEASE pd = 8 callref = 0x8B
*Jan 13 09:29:35.531: ISDN BR0/0/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0B
*Jan 13 09:29:37.639: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/0/0, TEI 0 changed to down
*Jan 13 09:29:37.667: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/0/0, TEI 0 changed to up
*Jan 13 09:30:11.667: ISDN BR0/0/0 Q931: TX -> SETUP pd = 8 callref = 0x0C
Sending Complete
Standard = CCITT
Channel ID i = 0x8A
Exclusive, B2
*Jan 13 09:30:12.035: ISDN BR0/0/0 Q931: RX <- CALL_PROC pd = 8 callref = 0x8C
Channel ID i = 0x8A
Exclusive, B2
*Jan 13 09:30:16.595: ISDN BR0/0/0 Q931: RX <- ALERTING pd = 8 callref = 0x8C
*Jan 13 09:30:18.411: ISDN BR0/0/0 Q931: RX <- CONNECT pd = 8 callref = 0x8C
*Jan 13 09:30:26.243: ISDN BR0/0/0 Q931: RX <- DISCONNECT pd = 8 callref = 0x8C
Gateway-MGCP#
The source of my problem may come from a mismatch or misconfiguration of my MGCP gateway, or BRI ?
It's not possible with MGCP + BRI:
See the latest version of the Unified Mobility chapter of the 9.1 Features and
Services Guide:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/9_1_1/ccmfeat/CUCM_BK_C3E0EFA0_00_cucm-features-services-guide-91_chapter_010001.html#CUCM_RF_L399F788_00__section835
which still clearly states "Mobile Connect features do not get supported for T1 CAS, FXO, FXS and BRI.".  And a bit further down: "The Mobile Connect feature is supported only for Primary Rate Interface (PRI) public switched telephone network (PSTN) connections. For SIP trunks, Mobile Connect is supported over IOS gateways or intercluster trunks.
Hi Gilles.
Thanks for your info +5 to you.
So MGCP is still ok on PRI
Carlo
I realize this is later, and
I realize this is later, and a few version up, but MGCP is not mentioned at all on that page, so why do you think it is just MGCP+BRI? I know MGCP+PRI SNR works, and MGCP+FXO SNR does not. Have not tested H.323+FXO SNR yet.
Though I should mention I saw another post stating switching from MGCP to H.323 made Unified Mobility (possibly SNR) work with an FXO.
3107
