SIP 180 RINGING Issue
blrnetwork
When i try to connect to a PSTN Phone behind PBX which is connected to my VoIP Gateway, i don't get a ring back.
In the debug i see PI value 8 from the Router but i don't get SIP 180 Ringing. Instead i get SIP 183 SESSION PROGRESS.
How to get the 180 RINGING ??
Rgds
Sarva
14 Replies 14
hadbou
Level 5
Level 5
Add this hidden command on the pots dial peer where the calls are going out of dial-peer:
progress_ind alert strip 8
Mark Pareja
Hi Mark
Excellent document ! Thanks for sharing.
Lavanya
I have same problem.
GW receives Alerting from PSTN via ISDN PRI, but sends 183 Proceeding to CUCM 8.5 instead 180 Ringing. IP phone than display CallProcceding instead Alerting message.
Jaroslav
Jaroslav,
     Please read this document .
https://supportforums.cisco.com/docs/DOC-21998
Hi Mark,
I read document, but I need modify incoming 183 message, not outgoing. I look for solution, which is independent on CUCM version. I have same problem with one installation CUCM 7.1 and there aren’t these possibilities. So I need modify 183 on Cisco ISR. It's possible with sip-profiles?
I read this document, but it looks, that with sip-profile it’s possible modify only message content, but I need modify message code (message type).
On which depends 180 and 183 messages? When GW sends 180 and when 183 message? I don’t understand, why GW sends 183 Proceeding message, if I see in “isdn q931” debug, that GW received ALERTING via ISDN PRI.
Here is one method I just tested .
dial-peer voice 22 pots
 description Carrier Side
 application session
 destination-pattern 22..
 progress_ind setup enable 3
 progress_ind alert enable 8
 progress_ind progress enable 8
 direct-inward-dial
 port 1/0:15
 forward-digits all
dial-peer voice 34 voip
 description Inside
 destination-pattern 34..
 session target ipv4:10.96.2.130
 dtmf-relay h245-signal
 no call fallback
One other suggestion I read was to dissable media cut through which should send the 180.
Router(config-sip-ua)# disable-early-media 180
Hi Mark,
Your configuration is for H323. I tried this configuration with progress indicators for SIP (session protocol sipv2) and behavior is same – GW receives alerting from ISDN PRI and sends 183 Progress message instead 180 Ringing message
debug isdn q931
debug ccsip messages
Mar  9 06:41:26.659: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x07CA
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x0080, '553287'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '279538'
Mar  9 06:41:26.659: //15369/B8D23DD08892/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 172.31.240.5:5060;branch=z9hG4bK421764
To: <279538>
Date: Fri, 09 Mar 2012 06:41:26 GMT
Call-ID: BAC003E2-68E911E1-889781D4-A11A5281@172.31.240.5
Timestamp: 1331275286
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Mar  9 06:41:26.687: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8
7CA
Mar  9 06:41:27.551: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x87
CA
        Progress Ind i = 0x8082 - Destination address is non-ISDN
        Locking Shift to Codeset 5
        Codeset 5 IE 0x32  i = 0x81
Mar  9 06:41:27.559: //15369/B8D23DD08892/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 183 Session Progress
To: <279538>;tag=241DE260-1DC
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIF
Y, INFO, REGISTER
Remote-Party-ID: <279538>;party=called
;screen=no;privacy=off
Contact: <279538>
Supported: sdp-anat
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 194
v=0
o=CiscoSystemsSIP-GW-UserAgent 2312 2271 IN IP4 10.0.128.16
s=SIP Call
c=IN IP4 10.0.128.16
t=0 0
m=audio 17884 RTP/AVP 8
a=rtpmap:8 PCMA/8000
a=ptime:20
Hi Jaroslav,
I hit the same problem. Trace from my GW is exact same respect to yours.
I'd like to ask you if you finally came up with a solution, or not.
Thanks and best regards,
Andrea
Hi Andrea,
Unfortunately no.  I used H323 instead SIP and here isn’t problem with ringing.
Hi Jaroslav,
we solved it at the end. Guys from the PBX managed to change configuration to send out to VGW a PI=8, and play the ringback accordingly.
Andrea
