Community Member
SIP/2.0 403 Forbidden
Hello!
Could you help me. What can be a problem of receiving SIP/2.0 403 Forbidden from ISP in case of outgoing call.
Here the debug of the call
Received:
INVITE sip:989291053298@192.168.255.141:5060 SIP/2.0
Via: SIP/2.0/TCP 10.0.0.180:5060;branch=z9hG4bK6bc76f6538e2a7
From: <sip:00141766@10.0.0.180>;tag=48887437~bfabd68f-bf41-4676-9dcb-634d1cef2cdb-104101004
To: <sip:989291053298@192.168.255.141>
Date: Wed, 15 Oct 2014 18:45:46 GMT
Call-ID: 78196e80-43e1c0da-304c28-b400000a@10.0.0.180
Supported: 100rel,timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM9.1
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <sip:10.0.0.180:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Cisco-Guid: 2014932608-0000065536-0000322579-3019898890
Session-Expires:  1800
P-Asserted-Identity: <sip:00141766@10.0.0.180>
Remote-Party-ID: <sip:00141766@10.0.0.180>;party=calling;screen=yes;privacy=off
Contact: <sip:00141766@10.0.0.180:5060;transport=tcp>
Max-Forwards: 70
Content-Length: 0
Oct 16 01:45:46: //1481/78196E800004/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.3.3.M
Content-Length: 0
Oct 16 01:45:46: //1482/78196E800004/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:89291053298@10.69.13.2:5060 SIP/2.0
Via: SIP/2.0/UDP 10.69.13.30:5060;branch=z9hG4bK10BCE8
Remote-Party-ID: <sip:910837@10.69.13.30>;party=calling;screen=yes;privacy=off
To: <sip:89291053298@10.69.13.2>
Call-ID: 4F7ED0B7-53D211E4-8873848F-2406FF8D@10.69.13.30
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
User-Agent: Cisco-SIPGateway/IOS-15.3.3.M
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1413398746
Contact: <sip:910837@10.69.13.30:5060>
Expires: 180
Max-Forwards: 69
Content-Length: 0
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Oct 16 01:45:47: //1482/78196E800004/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
Allow: INVITE,ACK,CANCEL,INFO,PRACK,UPDATE,OPTIONS,REGISTER,REFER,SUBSCRIBE,PUBLISH
Contact: <sip:89291053298@10.69.13.2:5060>
CSeq: 101 INVITE
To: <sip:89291053298@10.69.13.2>;tag=82suqtc8sm
Require: 100rel
RSeq: 1
Content-Length:  237
Content-Type: application/sdp
Content-Disposition: session;handling=required
v=0
o=- 7167275 4854563 IN IP4 10.69.13.6
s=-
c=IN IP4 10.69.13.6
b=AS:64
t=0 0
m=audio 19908 RTP/AVP 8 0 101
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
Oct 16 01:45:47: //1481/78196E800004/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:989291053298@192.168.255.141>;tag=1EEEAEC-15E1
CSeq: 101 INVITE
Require: 100rel
RSeq: 1994
Contact: <sip:989291053298@192.168.141.10:5060;transport=tcp>
Supported: sdp-anat
Content-Length: 252
v=0
o=CiscoSystemsSIP-GW-UserAgent 435 3753 IN IP4 192.168.141.10
s=SIP Call
c=IN IP4 192.168.141.10
t=0 0
m=audio 16906 RTP/AVP 8 101
a=fmtp:101 0-15
a=ptime:20
Oct 16 01:45:47: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
PRACK sip:989291053298@192.168.141.10:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 10.0.0.180:5060;branch=z9hG4bK6bc7703efadd7f
CSeq: 102 PRACK
RAck: 1994 101 INVITE
Max-Forwards: 70
Content-Length: 240
v=0
o=CiscoSystemsCCM-SIP 48887437 1 IN IP4 10.0.0.180
s=SIP Call
c=IN IP4 192.168.103.166
b=TIAS:64000
b=AS:64
t=0 0
m=audio 24590 RTP/AVP 8 101
a=ptime:20
a=fmtp:101 0-15
Sent:
PRACK sip:89291053298@10.69.13.2:5060 SIP/2.0
Via: SIP/2.0/UDP 10.69.13.30:5060;branch=z9hG4bK10C5E6
CSeq: 102 PRACK
RAck: 1 101 INVITE
Max-Forwards: 70
Content-Length: 243
v=0
o=CiscoSystemsSIP-GW-UserAgent 1590 246 IN IP4 10.69.13.30
s=SIP Call
c=IN IP4 10.69.13.30
t=0 0
m=audio 16908 RTP/AVP 8 101
a=fmtp:101 0-15
a=ptime:20
Sent:
SIP/2.0 200 OK
Date: Wed, 15 Oct 2014 18:45:47 GMT
CSeq: 102 PRACK
Content-Length: 0
Received:
SIP/2.0 200 OK
CSeq: 102 PRACK
Content-Length: 0
Received:
CSeq: 101 INVITE
Reason: Q.850;cause=21;text="Call rejected"
Content-Length: 0
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sent:
CSeq: 101 INVITE
Reason: Q.850;cause=57
Content-Length: 0
Received:
lenta-141-router#ACK sip:989291053298@192.168.255.141:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Thank you in advance!
have you binded the right
have you binded the right interface towards the ISP? could you please share the CUBE config?
inbound calls are working fine?
//Suresh Please rate all the useful posts.
also, the calling number is
also, the calling number is changed from 00141766 to 910837 and sent to ISP. is this the valid DID?
Community Member
yes pretty sure that I binded
yes pretty sure that I binded the right interfaces towards the ISP. Inbound calls work fine. The config in attachment and  910837 it is valid DID that gave me IPS.
The outbound call is rejected
The outbound call is rejected by the ISP, so you can once check with them on why they disconnecting it.
3817
