05-31-2014 09:22 AM - edited 03-16-2019 10:56 PM
Dears
when i make a phone call to a mobile number sometimes it work just fine and sometimes it drop and give a busy tone and i had to try 3 to 10 times before it connect spechially if the number is not in use before
this is the syslog from debug
May 30 20:19:34.284: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:90555769123@192.168.200.86:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.200.53:5060;branch=z9hG4bK3bd451bf17e0
From: "Aysar Mohamed" <sip:2217156@192.168.200.53>;tag=37693~244641b0-36ac-434c-91c1-823f25a68b28-18299026
To: <sip:90555769123@192.168.200.86>
Date: Fri, 30 May 2014 20:19:34 GMT
Call-ID: b5a49480-3881e7d6-13a9-35c8a8c0@192.168.200.53
Supported: timer,resource-priority,replaces
Min-SE: 1800
User-Agent: Cisco-CUCM8.6
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Call-Info: <sip:192.168.200.53:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Cisco-Guid: 3047462016-0000065536-0000004549-0902342848
Session-Expires: 1800
P-Asserted-Identity: "Aysar Mohamed" <sip:2217156@192.168.200.53>
Remote-Party-ID: "Aysar Mohamed" <sip:2217156@192.168.200.53>;party=calling;screen=yes;privacy=off
Contact: <sip:2217156@192.168.200.53:5060>
Max-Forwards: 70
Content-Length: 0
May 30 20:19:34.284: //-1/B5A494800000/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=2217156
----- ccCallInfo IE subfields -----
cisco-ani=2217156
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=90555769123
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
May 30 20:19:34.288: //-1/B5A494800000/CCAPI/cc_api_call_setup_ind_common:
Interface=0x30CF41D4, Call Info(
Calling Number=2217156,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=90555769123(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=0, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=465
May 30 20:19:34.288: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 30 20:19:34.288: :cc_get_feature_vsa malloc success
May 30 20:19:34.288: cc_get_feature_vsa count is 1
May 30 20:19:34.288: :FEATURE_VSA attributes are: feature_name:0,feature_time:832953048,feature_id:85
May 30 20:19:34.288: //465/B5A494800000/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=2217156(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=90555769123(TON=Unknown, NPI=Unknown))
May 30 20:19:34.288: //465/B5A494800000/CCAPI/cc_process_call_setup_ind:
Event=0x2B82D890
May 30 20:19:34.288: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 90555769123
May 30 20:19:34.288: //465/B5A494800000/CCAPI/ccCallSetContext:
Context=0x2ABC2E44
>>>>CCAPI handed cid 465 with tag 0 to app "_ManagedAppProcess_Default"
May 30 20:19:34.288: //465/B5A494800000/CCAPI/ccCallProceeding:
May 30 20:19:34.288: //465/B5A494800000/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=802, Params=0x2ABC19D4, Progress Indication=NULL(0)
May 30 20:19:34.288: //465/B5A494800000/CCAPI/ccCheckClipClir:
In: Calling Number=2217156(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Out: Calling Number=2217156(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Destination Pattern=9T, Called Number=0555769123, Digit Strip=FALSE
Called Number=0555769123(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=Aysar Mohamed
Account Number=2217156, Final Destination Flag=TRUE,
Guid=B5A49480-0001-0000-0000-11C535C8A8C0, Outgoing Dial-peer=802
May 30 20:19:34.288: //465/B5A494800000/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-ani=2217156
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=0555769123
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
May 30 20:19:34.288: //465/B5A494800000/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x30CF41D4, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=2217156,(Calling Name=Aysar Mohamed)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=0555769123(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=802, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
May 30 20:19:34.288: cc_get_feature_vsa count is 2
May 30 20:19:34.288: :FEATURE_VSA attributes are: feature_name:0,feature_time:832952824,feature_id:86
May 30 20:19:34.292: //466/B5A494800000/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
May 30 20:19:34.292: //466/B5A494800000/CCAPI/ccCallSetContext:
Context=0x2ABC1984
May 30 20:19:34.292: //465/B5A494800000/CCAPI/ccSaveDialpeerTag:
May 30 20:19:34.292: //466/B5A494800000/CCAPI/cc_api_call_proceeding:
Interface=0x30CF41D4, Progress Indication=NULL(0)
May 30 20:19:34.292: //465/B5A494800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
May 30 20:19:34.292: //466/B5A494800000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:0555769123@10.208.9.69:5060 SIP/2.0
Via: SIP/2.0/UDP 172.29.7.94:5060;branch=z9hG4bK461C
Remote-Party-ID: "Aysar Mohamed" <sip:2217156@172.29.7.94>;party=calling;screen=yes;privacy=off
From: "Aysar Mohamed" <sip:2217156@172.29.7.94>;tag=7394E4-1898
To: <sip:0555769123@10.208.9.69>
Call-ID: 8C9F6977-E76E11E3-8277BE8C-EC3B12A0@172.29.7.94
Supported: timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1401481174
Contact: <sip:2217156@172.29.7.94:5060>
Call-Info: <sip:172.29.7.94:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Allow-Events: kpml, telephone-event
Max-Forwards: 69
Content-Length: 0
May 30 20:19:34.300: //466/B5A494800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
From: "Aysar Mohamed"<sip:2217156@172.29.7.94>;tag=7394E4-1898
CSeq: 101 INVITE
Content-Length: 0
May 30 20:19:34.612: //466/B5A494800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
Record-Route: <sip:10.208.9.69:5060;transport=udp;lr>
To: <sip:0555769123@10.208.9.69>;tag=sbc0806eppk5yip-CC-57
CSeq: 101 INVITE
Contact: <sip:0555769123@10.208.9.69:5060;user=phone>
Allow: INVITE,ACK,OPTIONS,BYE,CANCEL,REGISTER,INFO,PRACK,SUBSCRIBE,NOTIFY,UPDATE,MESSAGE,REFER
Content-Length: 328
Content-Type: application/sdp
v=0
o=- 17192647 17192647 IN IP4 10.208.9.69
s=SBC call
c=IN IP4 10.208.9.69
t=0 0
m=audio 39910 RTP/AVP 8 0 102 102 18 116
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:102 AMR/8000
a=rtpmap:18 G729/8000
a=rtpmap:116 telephone-event/8000
a=ptime:5
a=fmtp:116 0-15
a=fmtp:18 annexb=yes
May 30 20:19:34.612: %SIP-3-UNSUPPORTED: Unsupported ptime value
May 30 20:19:34.612: //466/B5A494800000/CCAPI/cc_api_caps_ind:
Destination Interface=0x0, Destination Call Id=-1, Source Call Id=466,
Caps(Codec=0x2, Fax Rate=0x2, Vad=0x1,
Modem=0x0, Codec Bytes=160, Signal Type=2)
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
May 30 20:19:34.612: //465/B5A494800000/CCAPI/cc_api_caps_ack:
Destination Interface=0x0, Destination Call Id=-1, Source Call Id=465,
Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Modem=OFF(0x0), Codec Bytes=20, Signal Type=2, Seq Num Start=3882)
May 30 20:19:34.612: //466/B5A494800000/CCAPI/cc_api_event_indication:
Event=170, Call Id=466
Event Is Sent To Conferenced SPI(s) Directly
Event=98, Call Id=466
May 30 20:19:34.612: //466/B5A494800000/CCAPI/cc_api_call_cut_progress:
Interface=0x30CF41D4, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1),
Cause Value=0
Call Entry(Responsed=TRUE)
May 30 20:19:34.612: //465/B5A494800000/CCAPI/ccCallCutProgress:
Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1), Cause Value=0
Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
May 30 20:19:34.612: //465/B5A494800000/CCAPI/ccConferenceCreate:
(confID=0x30C11410, callID1=0x1D1, gcid=8C9E3127-E76E11E3-8274BE8C-EC3B12A0, tag=0x0)
May 30 20:19:34.616: //466/B5A494800000/CCAPI/ccConferenceCreate:
(confID=0x30C11410, callID2=0x1D2, gcid=8C9E3127-E76E11E3-8274BE8C-EC3B12A0, tag=0x0)
May 30 20:19:34.616: //465/B5A494800000/CCAPI/ccConferenceCreate:
Conference Id=0x30C11410, Call Id1=465, Call Id2=466, Tag=0x0
May 30 20:19:34.616: //465/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
May 30 20:19:34.616: cc_api_get_xcode_stream : 4702
May 30 20:19:34.616: //466/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
May 30 20:19:34.616: ccConferenceCreate: ret1=0, codecMask1=2, bytes1=160, negot1=0, dtmf1=0
ret2=0, codecMask2=2, bytes2=160, negot2=1, dtmf2=6,
tx_dynamic_pt1=0, rx_dynamic_pt1=0, codec_mode1=0, params_bitmap1 =0
tx_dynamic_pt2=8, rx_dynamic_pt2=8, codec_mode2=0, params_bitmap2 =0
delay media to slow start case, codec negotation is not done
May 30 20:19:34.616: //465/B5A494800000/CCAPI/cc_api_bridge_done:
Conference Id=0x16, Source Interface=0x30CF41D4, Source Call Id=465,
Destination Call Id=466, Disposition=0x0, Tag=0x0
May 30 20:19:34.616: //466/B5A494800000/CCAPI/cc_api_bridge_done:
Conference Id=0x16, Source Interface=0x30CF41D4, Source Call Id=466,
Destination Call Id=465, Disposition=0x0, Tag=0x0
May 30 20:19:34.616: //465/B5A494800000/CCAPI/cc_generic_bridge_done:
Call Entry(Conference Id=0x16, Destination Call Id=466)
Call Entry(Conference Id=0x16, Destination Call Id=465)
May 30 20:19:34.616: //465/B5A494800000/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x16, Call Id1=465, Call Id2=466
May 30 20:19:34.616: //465/B5A494800000/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:90555769123@192.168.200.86>;tag=739628-1BDB
CSeq: 101 INVITE
Remote-Party-ID: <sip:0555769123@192.168.200.86>;party=called;screen=yes;privacy=off
Contact: <sip:90555769123@192.168.200.86:5060>
Supported: sdp-anat
Content-Disposition: session;handling=required
Content-Length: 233
v=0
o=CiscoSystemsSIP-GW-UserAgent 2639 5276 IN IP4 192.168.200.86
s=SIP Call
c=IN IP4 192.168.200.86
t=0 0
m=audio 18288 RTP/AVP 8 0 19
a=rtpmap:19 CN/8000
May 30 20:19:34.680: //466/B5A494800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 500 Server Internal Error
CSeq: 101 INVITE
Reason: Q.850;cause=127;text="interworking unspecified"
Warning: 399 - "SoftX3000 R601-CCU Rel POS:[3103] Release from CR"
Content-Length: 0
May 30 20:19:34.680: //466/B5A494800000/CCAPI/cc_api_call_disconnected:
Cause Value=41, Interface=0x30CF41D4, Call Id=466
Call Entry(Responsed=TRUE, Cause Value=41, Retry Count=0)
May 30 20:19:34.680: //465/B5A494800000/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
May 30 20:19:34.680: //466/B5A494800000/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=466
May 30 20:19:34.680: //465/B5A494800000/CCAPI/ccConferenceDestroy:
Conference Id=0x16, Tag=0x0
May 30 20:19:34.680: //465/B5A494800000/CCAPI/cc_api_bridge_drop_done:
May 30 20:19:34.680: //466/B5A494800000/CCAPI/cc_api_bridge_drop_done:
May 30 20:19:34.680: //465/B5A494800000/CCAPI/cc_generic_bridge_done:
Sent:
ACK sip:0555769123@10.208.9.69:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
May 30 20:19:34.684: //466/B5A494800000/CCAPI/ccCallDisconnect:
Cause Value=41, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=41)
Cause Value=41, Call Entry(Responsed=TRUE, Cause Value=41)
May 30 20:19:34.684: //466/B5A494800000/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x30CF41D4, Tag=0x0, Call Id=466,
Call Entry(Disconnect Cause=41, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
May 30 20:19:34.684: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May 30 20:19:34.684: :cc_free_feature_vsa freeing 31A5D9F0
May 30 20:19:34.684: vsacount in free is 1
May 30 20:19:34.684: //465/B5A494800000/CCAPI/ccCallDisconnect:
Cause Value=41, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
May 30 20:19:34.684: //465/B5A494800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 503 Service Unavailable
CSeq: 101 INVITE
Reason: Q.850;cause=41
Content-Length: 0
May 30 20:19:34.684: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:90555769123@192.168.200.86:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
May 30 20:19:34.688: //465/B5A494800000/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x30CF41D4, Tag=0x0, Call Id=465,
May 30 20:19:34.688: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May 30 20:19:34.688: :cc_free_feature_vsa freeing 31A5DAD0
May 30 20:19:34.688: vsacount in free is 0
May 30 20:19:36.044: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:172.29.7.94:5060 SIP/2.0
Via: SIP/2.0/UDP 10.208.9.69:5060;branch=z9hG4bKmisco3ykfiooegpygsphkocp1T20326
Call-ID: isbcfemyk1p1mkteets1tcmi53eeehfhikcp@SoftX3000
To: <sip:172.29.7.94>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
May 30 20:19:36.048: //467/8DAABF6C8278/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:172.29.7.94>;tag=739BBC-1CE2
Date: Fri, 30 May 2014 20:19:36 GMT
CSeq: 1 OPTIONS
Accept: application/sdp
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Content-Length: 446
v=0
o=CiscoSystemsSIP-GW-UserAgent 3496 1601 IN IP4 172.29.7.94
s=SIP Call
c=IN IP4 172.29.7.94
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15
m=image 0 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:9600
a=T38FaxFillBitRemoval:0
a=T38FaxTranscodingMMR:0
a=T38FaxTranscodingJBIG:0
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
My SIP GW internal ip address is 192.168.200.86
and the Public IP is : 172.29.7.94
My CUCM is 192.168.200.53
my GW Config is :
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
codec preference 4 g729br8
voice translation-rule 3
rule 1 /^9\(\)/ /\1/
voice translation-rule 4
rule 4 /^22217/ /7/
rule 5 /^2217/ /7/
rule 6 /^022217/ /7/
rule 7 /^0122217/ /7/
voice translation-rule 5
rule 1 /^5/ /905/
rule 2 /^1/ /901/
rule 3 /^2/ /902/
rule 4 /^3/ /903/
rule 5 /^4/ /904/
rule 6 /^6/ /906/
rule 7 /^7/ /907/
rule 8 /^8/ /908/
rule 10 /^00/ /900/
rule 11 /'+'/ /900/
voice translation-profile OUT
translate called 3
voice translation-profile REDIAL
translate calling 5
voice translation-profile SIP-NEW
translate called 4
application
service mva http://192.168.200.53:8080/ccmivr/pages/IVRMainpage.vxml
service ccm http://192.168.200.53:8080/ccmivr/pages/IVRMainpage.vxml
license udi pid CISCO2921/K9 sn FCZ164960G0
hw-module pvdm 0/0
hw-module pvdm 0/1
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 192.168.200.86 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 172.29.7.94 255.255.255.252
duplex auto
speed auto
ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 192.168.200.1
ip route 10.208.9.0 255.255.255.0 172.29.7.93
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 192.168.200.53 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 2 register NAGHI-MTP
dspfarm profile 2 mtp
codec g711alaw
maximum sessions hardware 25
associate application SCCP
dial-peer voice 802 voip
description ** SIP TO STC **
translation-profile outgoing OUT
destination-pattern 9T
session protocol sipv2
session target ipv4:10.208.9.69:5060
session transport udp
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay sip-notify rtp-nte sip-kpml
no vad
dial-peer voice 811 voip
description ** SIP INCOMING FROM STC **
translation-profile incoming SIP-NEW
translation-profile outgoing REDIAL
destination-pattern 7...
session target ipv4:192.168.200.53
incoming called-number 022217...$
codec g711alaw
dial-peer voice 812 voip
incoming called-number 22217...$
codec g711alaw
dial-peer voice 813 voip
incoming called-number 2217...$
codec g711alaw
dial-peer voice 814 voip
preference 1
session target ipv4:192.168.200.63
codec g711alaw
dial-peer voice 815 voip
preference 1
codec g711alaw
dial-peer voice 816 voip
preference 1
codec g711alaw
dial-peer voice 817 voip
incoming called-number 0122217...$
codec g711alaw
dial-peer voice 818 voip
preference 1
codec g711alaw
Please i need ur help ASAP
05-31-2014 10:12 AM
Hi Aysar,
seems there is no inbound dial-peer from CUCM to CUBE and hence it is matching default dial-peer 0 and negotiated g729 codec in that leg. the call leg from CUBE to ITSP matched the outbound dial-peer 802 negotiated G711A law codec.
Please create separate inbound dial-peer from CUCM to CUBE and outbound dial-peer from CUBE to CUCM for other direction.
Also, you may try binding the interfaces GigabitEthernet0/0 & GigabitEthernet0/1 in those dial-peers. Please refer this on how to bind the interfaces on dial-peers.
https://supportforums.cisco.com/blog/154506
//Suresh
Please rate all the helpful posts
06-18-2014 12:15 AM
Dears
can you mention in detail which type of dial-peer you want
sorry for the late replay
06-18-2014 03:16 AM
Aysar,
I agree with Suresh that you need to create a voip dial-peer to match inbound calls from cucm. However that is not the cause of your issue here, this could create another issue for you later on..
From the logs, your ITSP is diconnecting the call and it is most likely that they dont recognise the ip address the INVITE is coming from (172.29.7.94).
The warning 399, suggests simething is not right with this IP on their end. I sugest you contact them and find out why they are dropping the call
Received:
CSeq: 101 INVITE
Content-Length: 0
You should configure an inbound dial-peer as follows (assuming you are using a sip trunk between cucm and the cube)
dial-peer voice 1 voip
incoming called number .
no vad
voice-class codec 1
dtmf-relay rtp-nte
06-22-2014 06:34 PM
06-22-2014 11:51 PM
Have you spoken to your service provider yet? I did mention that you should speak with them.
07-14-2014 04:33 AM
Dears sorry for the late replay
I talked to them they say change the priority PCMA dn PCMU which no need and i did and also they ask T30 which cant be disable but they are lost too
07-14-2014 06:25 AM
Bad service provider returning you 500 messages back. From looking at your trace I don't see something that would cause them to return you a 500 message.
Maybe they have some balancing to several SIP servers on their side and one of them it's missconfigured who knows.
How reproducible is this?
Can you get us also a debug from a working call, so we can at least compare for diferences?
07-19-2014 04:14 AM
Dears
sorry again but we were facing some other sites problem in routing the whole week
so the working call debug is this
JJC-10LW-SIP-VGW1#debu ccs
JJC-10LW-SIP-VGW1#debu ccsip me
JJC-10LW-SIP-VGW1#debu ccsip mes
JJC-10LW-SIP-VGW1#debu ccsip messages
SIP Call messages tracing is enabled
JJC-10LW-SIP-VGW1#debu voice cc
JJC-10LW-SIP-VGW1#debu voice ccapi in
JJC-10LW-SIP-VGW1#debu voice ccapi ino
JJC-10LW-SIP-VGW1#debu voice ccapi inout
voip ccapi inout debugging is on
JJC-10LW-SIP-VGW1#term mon
JJC-10LW-SIP-VGW1#term monitor
JJC-10LW-SIP-VGW1#
Jul 19 11:11:04.382: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:90565285270@192.168.200.86:5060 SIP/2.0
Via: SIP/2.0/TCP 192.168.200.53:5060;branch=z9hG4bK7cbe506ffae4
From: "Autoline" <sip:2217187@192.168.200.53>;tag=147550~244641b0-36ac-434c-91c1-823f25a68b28-32840830
To: <sip:90565285270@192.168.200.86>
Date: Sat, 19 Jul 2014 11:11:04 GMT
Call-ID: 5e689980-3ca15248-203e-35c8a8c0@192.168.200.53
Min-SE: 1800
CSeq: 101 INVITE
Expires: 180
Cisco-Guid: 1583913344-0000065536-0000006562-0902342848
P-Asserted-Identity: "Autoline" <sip:2217187@192.168.200.53>
Remote-Party-ID: "Autoline" <sip:2217187@192.168.200.53>;party=calling;screen=yes;privacy=off
Contact: <sip:2217187@192.168.200.53:5060;transport=tcp>
Max-Forwards: 70
Content-Length: 0
Jul 19 11:11:04.386: //-1/5E6899800000/CCAPI/cc_api_display_ie_subfields:
cisco-username=2217187
cisco-ani=2217187
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=90565285270
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Jul 19 11:11:04.386: //-1/5E6899800000/CCAPI/cc_api_call_setup_ind_common:
Interface=0x30EF0454, Call Info(
Calling Number=2217187,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=90565285270(TON=Unknown, NPI=Unknown),
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=77419
Jul 19 11:11:04.386: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 19 11:11:04.386: :cc_get_feature_vsa malloc success
Jul 19 11:11:04.386: cc_get_feature_vsa count is 1
Jul 19 11:11:04.386: :FEATURE_VSA attributes are: feature_name:0,feature_time:805321432,feature_id:33227
Jul 19 11:11:04.386: //77419/5E6899800000/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=2217187(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=90565285270(TON=Unknown, NPI=Unknown))
Jul 19 11:11:04.386: //77419/5E6899800000/CCAPI/cc_process_call_setup_ind:
Event=0x30FFEC88
Jul 19 11:11:04.386: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 90565285270
Jul 19 11:11:04.386: //77419/5E6899800000/CCAPI/ccCallSetContext:
Context=0x2C11C24C
>>>>CCAPI handed cid 77419 with tag 0 to app "_ManagedAppProcess_Default"
Jul 19 11:11:04.386: //77419/5E6899800000/CCAPI/ccCallProceeding:
Jul 19 11:11:04.386: //77419/5E6899800000/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=802, Params=0x2C1107DC, Progress Indication=NULL(0)
Jul 19 11:11:04.390: //77419/5E6899800000/CCAPI/ccCheckClipClir:
In: Calling Number=2217187(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Out: Calling Number=2217187(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Jul 19 11:11:04.390: //77419/5E6899800000/CCAPI/ccCallSetupRequest:
Destination Pattern=9T, Called Number=0565285270, Digit Strip=FALSE
Called Number=0565285270(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=Autoline
Account Number=2217187, Final Destination Flag=TRUE,
Guid=5E689980-0001-0000-0000-19A235C8A8C0, Outgoing Dial-peer=802
Jul 19 11:11:04.390: //77419/5E6899800000/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-ani=2217187
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=0565285270
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Jul 19 11:11:04.390: //77419/5E6899800000/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x30EF0454, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=2217187,(Calling Name=Autoline)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=0565285270(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Jul 19 11:11:04.390: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 19 11:11:04.390: :cc_get_feature_vsa malloc success
Jul 19 11:11:04.390: cc_get_feature_vsa count is 2
Jul 19 11:11:04.390: :FEATURE_VSA attributes are: feature_name:0,feature_time:805320088,feature_id:33228
Jul 19 11:11:04.390: //77420/5E6899800000/CCAPI/ccIFCallSetupRequestPrivate:
Jul 19 11:11:04.390: //77420/5E6899800000/CCAPI/ccCallSetContext:
Context=0x2C11078C
Jul 19 11:11:04.390: //77419/5E6899800000/CCAPI/ccSaveDialpeerTag:
Jul 19 11:11:04.390: //77420/5E6899800000/CCAPI/cc_api_call_proceeding:
Interface=0x30EF0454, Progress Indication=NULL(0)
Jul 19 11:11:04.390: //77420/5E6899800000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:0565285270@10.208.9.69:5060 SIP/2.0
Via: SIP/2.0/UDP 172.29.7.94:5060;branch=z9hG4bK9676AEE
Remote-Party-ID: "Autoline" <sip:2217187@172.29.7.94>;party=calling;screen=yes;privacy=off
From: "Autoline" <sip:2217187@172.29.7.94>;tag=34373428-3A8
To: <sip:0565285270@10.208.9.69>
Call-ID: 35726640-E6C11E4-AF7485AD-E4E15E65@172.29.7.94
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1405768264
Contact: <sip:2217187@172.29.7.94:5060>
Expires: 180
Max-Forwards: 69
Content-Length: 0
Jul 19 11:11:04.390: //77419/5E6899800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Jul 19 11:11:04.406: //77420/5E6899800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
From: "Autoline"<sip:2217187@172.29.7.94>;tag=34373428-3A8
CSeq: 101 INVITE
Content-Length: 0
Jul 19 11:11:08.386: //77420/5E6899800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:0565285270@10.208.9.69>;tag=sbc0802gfkiogsi-CC-60
CSeq: 101 INVITE
Contact: <sip:0565285270@10.208.9.69:5060;user=phone>
Content-Length: 369
v=0
o=- 36781639 36781639 IN IP4 10.208.9.69
s=SBC call
t=0 0
m=audio 54900 RTP/AVP 8 0 18 4 2 98 99 97
a=rtpmap:4 G723/8000
a=rtpmap:2 G726-32/8000
a=rtpmap:98 G726-40/8000
a=rtpmap:99 G726-32/8000
a=rtpmap:97 telephone-event/8000
a=fmtp:97 0-15
Jul 19 11:11:08.386: //77420/5E6899800000/CCAPI/cc_api_caps_ind:
Destination Interface=0x0, Destination Call Id=-1, Source Call Id=77420,
Jul 19 11:11:08.386: //77419/5E6899800000/CCAPI/cc_api_caps_ack:
Destination Interface=0x0, Destination Call Id=-1, Source Call Id=77419,
Modem=OFF(0x0), Codec Bytes=20, Signal Type=2, Seq Num Start=2920)
Jul 19 11:11:08.386: //77420/5E6899800000/CCAPI/cc_api_event_indication:
Event=170, Call Id=77420
Jul 19 11:11:08.386: //77420/5E6899800000/CCAPI/cc_api_call_alert:
Interface=0x30EF0454, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
Call Entry(Retry Count=0, Responsed=TRUE)
Jul 19 11:11:08.390: //77419/5E6899800000/CCAPI/ccCallAlert:
Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Jul 19 11:11:08.390: //77419/5E6899800000/CCAPI/ccConferenceCreate:
(confID=0x31DE99E4, callID1=0x12E6B, gcid=3571C97F-E6C11E4-AF7185AD-E4E15E65, tag=0x0)
Jul 19 11:11:08.390: //77420/5E6899800000/CCAPI/ccConferenceCreate:
(confID=0x31DE99E4, callID2=0x12E6C, gcid=3571C97F-E6C11E4-AF7185AD-E4E15E65, tag=0x0)
Conference Id=0x31DE99E4, Call Id1=77419, Call Id2=77420, Tag=0x0
Jul 19 11:11:08.390: //77419/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Jul 19 11:11:08.390: cc_api_get_xcode_stream : 4702
Jul 19 11:11:08.390: //77420/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Jul 19 11:11:08.390: ccConferenceCreate: ret1=0, codecMask1=2, bytes1=160, negot1=0, dtmf1=0
Jul 19 11:11:08.390: //77419/5E6899800000/CCAPI/cc_api_bridge_done:
Conference Id=0x1DE1, Source Interface=0x30EF0454, Source Call Id=77419,
Destination Call Id=77420, Disposition=0x0, Tag=0x0
Jul 19 11:11:08.390: //77420/5E6899800000/CCAPI/cc_api_bridge_done:
Conference Id=0x1DE1, Source Interface=0x30EF0454, Source Call Id=77420,
Destination Call Id=77419, Disposition=0x0, Tag=0x0
Jul 19 11:11:08.390: //77419/5E6899800000/CCAPI/cc_generic_bridge_done:
Call Entry(Conference Id=0x1DE1, Destination Call Id=77420)
Call Entry(Conference Id=0x1DE1, Destination Call Id=77419)
Jul 19 11:11:08.390: //77419/5E6899800000/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x1DE1, Call Id1=77419, Call Id2=77420
Jul 19 11:11:08.390: //77419/5E6899800000/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:90565285270@192.168.200.86>;tag=343743C8-1C28
CSeq: 101 INVITE
Remote-Party-ID: <sip:0565285270@192.168.200.86>;party=called;screen=no;privacy=off
Contact: <sip:0565285270@192.168.200.86:5060;transport=tcp>
Supported: sdp-anat
Content-Length: 280
v=0
o=CiscoSystemsSIP-GW-UserAgent 7427 4964 IN IP4 192.168.200.86
s=SIP Call
t=0 0
m=audio 17956 RTP/AVP 8 0 18 19
a=fmtp:18 annexb=no
a=rtpmap:19 CN/8000
Jul 19 11:11:09.806: //77420/5E6899800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Content-Length: 369
v=0
o=- 36781639 36781640 IN IP4 10.208.9.69
s=SBC call
t=0 0
a=fmtp:97 0-15
Jul 19 11:11:13.546: //77420/5E6899800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Content-Length: 369
v=0
o=- 36781639 36781641 IN IP4 10.208.9.69
s=SBC call
t=0 0
a=fmtp:97 0-15
Jul 19 11:11:13.546: //77420/5E6899800000/CCAPI/cc_api_call_connected:
Interface=0x30EF0454, Data Bitmask=0x1, Progress Indication=NULL(0),
Connection Handle=0
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Jul 19 11:11:13.546: //77419/5E6899800000/CCAPI/ccCallConnect:
Progress Indication=NULL(0), Data Bitmask=0x1
Call Entry(Connected=TRUE, Responsed=TRUE)
Jul 19 11:11:13.550: //77419/5E6899800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Contact: <sip:90565285270@192.168.200.86:5060;transport=tcp>
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 280
v=0
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=rtpmap:19 CN/8000
Jul 19 11:11:13.786: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:90565285270@192.168.200.86:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 192.168.200.53:5060;branch=z9hG4bK7cbf3ee8f0d9
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 160
v=0
o=CiscoSystemsCCM-SIP 147550 1 IN IP4 192.168.200.53
s=SIP Call
c=IN IP4 172.18.2.205
t=0 0
m=audio 20872 RTP/AVP 0
a=ptime:20
Jul 19 11:11:13.786: //77419/5E6899800000/CCAPI/cc_api_caps_ind:
Destination Interface=0x30EF0454, Destination Call Id=77420, Source Call Id=77419,
Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Modem=0x0, Codec Bytes=20, Signal Type=2)
Jul 19 11:11:13.786: //77420/5E6899800000/CCAPI/cc_api_caps_ack:
Destination Interface=0x30EF0454, Destination Call Id=77419, Source Call Id=77420,
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
Modem=OFF(0x0), Codec Bytes=20, Signal Type=2, Seq Num Start=3288)
Jul 19 11:11:13.786: //77419/5E6899800000/CCAPI/cc_api_event_indication:
Event=171, Call Id=77419
Jul 19 11:11:13.790: //77420/5E6899800000/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:0565285270@10.208.9.69:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 172.29.7.94:5060;branch=z9hG4bK967815FB
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 228
v=0
o=CiscoSystemsSIP-GW-UserAgent 216 1335 IN IP4 172.29.7.94
s=SIP Call
t=0 0
m=audio 16570 RTP/AVP 0 97
a=fmtp:97 0-16
Jul 19 11:11:13.790: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SUBSCRIBE sip:2217187@192.168.200.53:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 192.168.200.86:5060;branch=z9hG4bK9677516
From: <sip:90565285270@192.168.200.86>;tag=343743C8-1C28
To: "Autoline" <sip:2217187@192.168.200.53>;tag=147550~244641b0-36ac-434c-91c1-823f25a68b28-32840830
CSeq: 101 SUBSCRIBE
Max-Forwards: 70
Date: Sat, 19 Jul 2014 11:11:13 GMT
Event: kpml
Expires: 7200
Contact: <sip:192.168.200.86:5060;transport=tcp>
Content-Type: application/kpml-request+xml
Content-Length: 327
<?xml version="1.0" encoding="UTF-8"?><kpml-request xmlns="urn:ietf:params:xml:ns:kpml-request" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:ietf:params:xml:ns:kpml-request kpml-request.xsd" version="1.0"><pattern persist="persist"><regex tag="dtmf">[x*#ABCD]</regex></pattern></kpml-request>
Jul 19 11:11:13.790: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 SUBSCRIBE
Expires: 7200
Content-Length: 0
Received:
NOTIFY sip:192.168.200.86:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 192.168.200.53:5060;branch=z9hG4bK7cc05a8a91e9
CSeq: 102 NOTIFY
Max-Forwards: 70
Event: kpml
Subscription-State: active;expires=7200
Content-Length: 0
Jul 19 11:11:13.794: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 NOTIFY
Content-Length: 0
Jul 19 11:11:13.846: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:2217187@172.29.7.94:5060 SIP/2.0
Via: SIP/2.0/UDP 10.208.9.69:5060;branch=z9hG4bKs1p3pfcpmisth3geekgospc1yT32749
From: <sip:0565285270@10.208.9.69>;tag=sbc0802gfkiogsi-CC-60
To: "Autoline"<sip:2217187@172.29.7.94>;tag=34373428-3A8
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 19 11:11:13.846: //77420/5E6899800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: "Autoline" <sip:2217187@172.29.7.94>;tag=34373428-3A8
CSeq: 1 OPTIONS
Content-Length: 515
v=0
s=SIP Call
t=0 0
a=fmtp:97 0-16
m=image 16570 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:14400
Jul 19 11:11:15.690: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.208.9.69:5060;branch=z9hG4bKhicckiyt3fomyimfttkfkpepgT30948
Call-ID: isbc15hiyy31gk1gthmsh55cig1osceh3yo3@SoftX3000
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 19 11:11:15.694: //77421/3C2EA23AAF75/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:172.29.7.94>;tag=3437604C-262
Date: Sat, 19 Jul 2014 11:11:15 GMT
CSeq: 1 OPTIONS
Content-Length: 446
v=0
o=CiscoSystemsSIP-GW-UserAgent 3839 6748 IN IP4 172.29.7.94
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul 19 11:11:19.210: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:90565285270@192.168.200.86:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 192.168.200.53:5060;branch=z9hG4bK7cc118f5b886
Max-Forwards: 70
CSeq: 103 BYE
Reason: Q.850;cause=16
Content-Length: 0
Jul 19 11:11:19.210: //77420/5E6899800000/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Null,
Tone Direction=Sum Network, Params=0x0, Call Id=77420
Jul 19 11:11:19.210: //77419/5E6899800000/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x30EF0454, Call Id=77419
Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Jul 19 11:11:19.210: //77419/5E6899800000/CCAPI/ccConferenceDestroy:
Conference Id=0x1DE1, Tag=0x0
Jul 19 11:11:19.210: //77419/5E6899800000/CCAPI/cc_api_bridge_drop_done:
Jul 19 11:11:19.210: //77420/5E6899800000/CCAPI/cc_api_bridge_drop_done:
Jul 19 11:11:19.214: //77419/5E6899800000/CCAPI/cc_generic_bridge_done:
Jul 19 11:11:19.214: //77419/5E6899800000/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Jul 19 11:11:19.214: //77420/5E6899800000/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Jul 19 11:11:19.214: //77419/5E6899800000/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x30EF0454, Tag=0x0, Call Id=77419,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Jul 19 11:11:19.214: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 19 11:11:19.214: :cc_free_feature_vsa freeing 30003AD0
Jul 19 11:11:19.214: vsacount in free is 1
Jul 19 11:11:19.214: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Sat, 19 Jul 2014 11:11:19 GMT
CSeq: 103 BYE
P-RTP-Stat: PS=265,OS=42400,PR=264,OR=42240,PL=0,JI=0,LA=0,DU=5
Content-Length: 0
Sent:
Via: SIP/2.0/TCP 192.168.200.86:5060;branch=z9hG4bK967A168B
CSeq: 102 SUBSCRIBE
Max-Forwards: 70
Event: kpml
Expires: 0
Content-Length: 0
Jul 19 11:11:19.214: //77420/5E6899800000/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:0565285270@10.208.9.69:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 172.29.7.94:5060;branch=z9hG4bK96792084
Max-Forwards: 70
Timestamp: 1405768279
CSeq: 102 BYE
P-RTP-Stat: PS=264,OS=42240,PR=265,OR=42400,PL=0,JI=0,LA=0,DU=5
Content-Length: 0
Jul 19 11:11:19.218: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 192.168.200.53:5060;branch=z9hG4bK7cc2258418e3
CSeq: 104 NOTIFY
Max-Forwards: 70
Event: kpml
Subscription-State: terminated
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 104 NOTIFY
Content-Length: 0
Jul 19 11:11:19.222: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 SUBSCRIBE
Expires: 0
Content-Length: 0
Jul 19 11:11:19.222: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 192.168.200.53:5060;branch=z9hG4bK7cc3468e2973
CSeq: 105 NOTIFY
Max-Forwards: 70
Event: kpml
Subscription-State: terminated;reason=timeout
Content-Type: application/kpml-response+xml
Content-Length: 348
<?xml version="1.0" encoding="UTF-8" ?>
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:ietf:params:xml:ns:kpml-response kpml-response.xsd" code="487" digits="" forced_flush="false" suppressed="false" tag="dtmf" text="Subscription Expired" version="1.0"/>
Sent:
SIP/2.0 481 Subscription does not exist
CSeq: 105 NOTIFY
Content-Length: 0
Jul 19 11:11:19.338: //77420/5E6899800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 BYE
Content-Length: 0
Jul 19 11:11:19.338: //77420/5E6899800000/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x30EF0454, Tag=0x0, Call Id=77420,
Jul 19 11:11:19.338: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 19 11:11:19.338: :cc_free_feature_vsa freeing 30003590
Jul 19 11:11:19.338: vsacount in free is 0
JJC-10LW-SIP-VGW1#
JJC-10LW-SIP-VGW1#u all
All possible debugging has been turned off
JJC-10LW-SIP-VGW1#
Thanks in Advanced
07-29-2014 03:45 PM
Everything looks okay now..This call was disconnected by the user on cucm.
What is the problem you are having now?
Received:
: Cisco-CUCM8.6
Max-Forwards: 70
CSeq: 103 BYE
07-29-2014 04:47 PM
Yeah i know
you asked me in pervious replay to send you a succeful call which is this one and i hang up
the 90565285270 is my mobile
you asked me to send so you compare between the successfull call and the wrong call
07-29-2014 10:07 PM
Can you please find the below:-
i think you get bye message because no bind .
voice service voip
ip address trusted list
sip
bind all source-interface gig0/0
please rate all useful information
07-30-2014 01:32 AM
Islam,
I am afraid that is not a good suggestion. You need to understand his setup before you can even attemtp to bind all to a singe interface! What if he has multiple interfaces? This can break a lot of things..Please refer to my blog here on understanding sip binds commands.
07-30-2014 01:44 AM
+5 , yes i saw that logs is ok no issues that is why i thought he has to bind , sorry and thanks for your information.
07-30-2014 01:35 AM
You need to speak to your provider as I told you earlier and find out why they are terminating your call..
