SIP/2.0 503 service unavailable
Dears
when i make a phone call to a mobile number sometimes it work just fine and sometimes it drop and give a busy tone and i had to try 3 to 10 times before it connect spechially if the number is not in use before
this is the syslog from debug
May 30 20:19:34.284: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:90555769123@192.168.200.86:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.200.53:5060;branch=z9hG4bK3bd451bf17e0
From: "Aysar Mohamed" <sip:2217156@192.168.200.53>;tag=37693~244641b0-36ac-434c-91c1-823f25a68b28-18299026
To: <sip:90555769123@192.168.200.86>
Date: Fri, 30 May 2014 20:19:34 GMT
Call-ID: b5a49480-3881e7d6-13a9-35c8a8c0@192.168.200.53
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM8.6
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Call-Info: <sip:192.168.200.53:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Cisco-Guid: 3047462016-0000065536-0000004549-0902342848
Session-Expires:  1800
P-Asserted-Identity: "Aysar Mohamed" <sip:2217156@192.168.200.53>
Remote-Party-ID: "Aysar Mohamed" <sip:2217156@192.168.200.53>;party=calling;screen=yes;privacy=off
Contact: <sip:2217156@192.168.200.53:5060>
Max-Forwards: 70
Content-Length: 0
May 30 20:19:34.284: //-1/B5A494800000/CCAPI/cc_api_display_ie_subfields:
    cc_api_call_setup_ind_common:
    cisco-username=2217156
    ----- ccCallInfo IE subfields -----
    cisco-ani=2217156
    cisco-anitype=0
    cisco-aniplan=0
    cisco-anipi=0
    cisco-anisi=1
    dest=90555769123
    cisco-desttype=0
    cisco-destplan=0
    cisco-rdie=FFFFFFFF
    cisco-rdn=
    cisco-rdntype=0
    cisco-rdnplan=0
    cisco-rdnpi=-1
    cisco-rdnsi=-1
    cisco-redirectreason=-1   fwd_final_type =0
    final_redirectNumber =
    hunt_group_timeout =0
May 30 20:19:34.288: //-1/B5A494800000/CCAPI/cc_api_call_setup_ind_common:
    Interface=0x30CF41D4, Call Info(
    Calling Number=2217156,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
    Called Number=90555769123(TON=Unknown, NPI=Unknown),
    Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
    Incoming Dial-peer=0, Progress Indication=NULL(0), Calling IE Present=TRUE,
    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=465
May 30 20:19:34.288: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 30 20:19:34.288: :cc_get_feature_vsa malloc success
May 30 20:19:34.288:  cc_get_feature_vsa count is 1
May 30 20:19:34.288: :FEATURE_VSA attributes are: feature_name:0,feature_time:832953048,feature_id:85
May 30 20:19:34.288: //465/B5A494800000/CCAPI/cc_api_call_setup_ind_common:
    Set Up Event Sent;
    Call Info(Calling Number=2217156(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
    Called Number=90555769123(TON=Unknown, NPI=Unknown))
May 30 20:19:34.288: //465/B5A494800000/CCAPI/cc_process_call_setup_ind:
    Event=0x2B82D890
May 30 20:19:34.288: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
    Try with the demoted called number 90555769123
May 30 20:19:34.288: //465/B5A494800000/CCAPI/ccCallSetContext:
    Context=0x2ABC2E44
    >>>>CCAPI handed cid 465 with tag 0 to app "_ManagedAppProcess_Default"
May 30 20:19:34.288: //465/B5A494800000/CCAPI/ccCallProceeding:
May 30 20:19:34.288: //465/B5A494800000/CCAPI/ccCallSetupRequest:
    Destination=, Calling IE Present=TRUE, Mode=0,
    Outgoing Dial-peer=802, Params=0x2ABC19D4, Progress Indication=NULL(0)
May 30 20:19:34.288: //465/B5A494800000/CCAPI/ccCheckClipClir:
    In: Calling Number=2217156(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
    Out: Calling Number=2217156(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
    Destination Pattern=9T, Called Number=0555769123, Digit Strip=FALSE
    Called Number=0555769123(TON=Unknown, NPI=Unknown),
    Redirect Number=, Display Info=Aysar Mohamed
    Account Number=2217156, Final Destination Flag=TRUE,
    Guid=B5A49480-0001-0000-0000-11C535C8A8C0, Outgoing Dial-peer=802
May 30 20:19:34.288: //465/B5A494800000/CCAPI/cc_api_display_ie_subfields:
    ccCallSetupRequest:
    cisco-ani=2217156
    cisco-anitype=0
    cisco-aniplan=0
    cisco-anipi=0
    cisco-anisi=1
    dest=0555769123
    cisco-desttype=0
    cisco-destplan=0
    cisco-rdie=FFFFFFFF
    cisco-rdn=
    cisco-rdntype=0
    cisco-rdnplan=0
    cisco-rdnpi=-1
    cisco-rdnsi=-1
May 30 20:19:34.288: //465/B5A494800000/CCAPI/ccIFCallSetupRequestPrivate:
    Interface=0x30CF41D4, Interface Type=3, Destination=, Mode=0x0,
    Call Params(Calling Number=2217156,(Calling Name=Aysar Mohamed)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
    Called Number=0555769123(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
    Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=802, Call Count On=FALSE,
    Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
May 30 20:19:34.288:  cc_get_feature_vsa count is 2
May 30 20:19:34.288: :FEATURE_VSA attributes are: feature_name:0,feature_time:832952824,feature_id:86
May 30 20:19:34.292: //466/B5A494800000/CCAPI/ccIFCallSetupRequestPrivate:
    SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
May 30 20:19:34.292: //466/B5A494800000/CCAPI/ccCallSetContext:
    Context=0x2ABC1984
May 30 20:19:34.292: //465/B5A494800000/CCAPI/ccSaveDialpeerTag:
May 30 20:19:34.292: //466/B5A494800000/CCAPI/cc_api_call_proceeding:
    Interface=0x30CF41D4, Progress Indication=NULL(0)
May 30 20:19:34.292: //465/B5A494800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
May 30 20:19:34.292: //466/B5A494800000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:0555769123@10.208.9.69:5060 SIP/2.0
Via: SIP/2.0/UDP 172.29.7.94:5060;branch=z9hG4bK461C
Remote-Party-ID: "Aysar Mohamed" <sip:2217156@172.29.7.94>;party=calling;screen=yes;privacy=off
From: "Aysar Mohamed" <sip:2217156@172.29.7.94>;tag=7394E4-1898
To: <sip:0555769123@10.208.9.69>
Call-ID: 8C9F6977-E76E11E3-8277BE8C-EC3B12A0@172.29.7.94
Supported: timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1401481174
Contact: <sip:2217156@172.29.7.94:5060>
Call-Info: <sip:172.29.7.94:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Allow-Events: kpml, telephone-event
Max-Forwards: 69
Content-Length: 0
May 30 20:19:34.300: //466/B5A494800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
From: "Aysar Mohamed"<sip:2217156@172.29.7.94>;tag=7394E4-1898
CSeq: 101 INVITE
Content-Length: 0
May 30 20:19:34.612: //466/B5A494800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
Record-Route: <sip:10.208.9.69:5060;transport=udp;lr>
To: <sip:0555769123@10.208.9.69>;tag=sbc0806eppk5yip-CC-57
CSeq: 101 INVITE
Contact: <sip:0555769123@10.208.9.69:5060;user=phone>
Allow: INVITE,ACK,OPTIONS,BYE,CANCEL,REGISTER,INFO,PRACK,SUBSCRIBE,NOTIFY,UPDATE,MESSAGE,REFER
Content-Length: 328
Content-Type: application/sdp
v=0
o=- 17192647 17192647 IN IP4 10.208.9.69
s=SBC call
c=IN IP4 10.208.9.69
t=0 0
m=audio 39910 RTP/AVP 8 0 102 102 18 116
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:102 AMR/8000
a=rtpmap:18 G729/8000
a=rtpmap:116 telephone-event/8000
a=ptime:5
a=fmtp:116 0-15
a=fmtp:18 annexb=yes
May 30 20:19:34.612: %SIP-3-UNSUPPORTED: Unsupported ptime value
May 30 20:19:34.612: //466/B5A494800000/CCAPI/cc_api_caps_ind:
    Destination Interface=0x0, Destination Call Id=-1, Source Call Id=466,
    Caps(Codec=0x2, Fax Rate=0x2, Vad=0x1,
    Modem=0x0, Codec Bytes=160, Signal Type=2)
    Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
    Playout Max=1000(ms), Fax Nom=300(ms))
May 30 20:19:34.612: //465/B5A494800000/CCAPI/cc_api_caps_ack:
    Destination Interface=0x0, Destination Call Id=-1, Source Call Id=465,
    Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
    Modem=OFF(0x0), Codec Bytes=20, Signal Type=2, Seq Num Start=3882)
May 30 20:19:34.612: //466/B5A494800000/CCAPI/cc_api_event_indication:
    Event=170, Call Id=466
    Event Is Sent To Conferenced SPI(s) Directly
    Event=98, Call Id=466
May 30 20:19:34.612: //466/B5A494800000/CCAPI/cc_api_call_cut_progress:
    Interface=0x30CF41D4, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1),
    Cause Value=0
    Call Entry(Responsed=TRUE)
May 30 20:19:34.612: //465/B5A494800000/CCAPI/ccCallCutProgress:
    Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1), Cause Value=0
    Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
May 30 20:19:34.612: //465/B5A494800000/CCAPI/ccConferenceCreate:
    (confID=0x30C11410, callID1=0x1D1, gcid=8C9E3127-E76E11E3-8274BE8C-EC3B12A0, tag=0x0)
May 30 20:19:34.616: //466/B5A494800000/CCAPI/ccConferenceCreate:
    (confID=0x30C11410, callID2=0x1D2, gcid=8C9E3127-E76E11E3-8274BE8C-EC3B12A0, tag=0x0)
May 30 20:19:34.616: //465/B5A494800000/CCAPI/ccConferenceCreate:
    Conference Id=0x30C11410, Call Id1=465, Call Id2=466, Tag=0x0
May 30 20:19:34.616: //465/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
May 30 20:19:34.616: cc_api_get_xcode_stream : 4702
May 30 20:19:34.616: //466/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
May 30 20:19:34.616: ccConferenceCreate: ret1=0, codecMask1=2, bytes1=160, negot1=0, dtmf1=0
                     ret2=0, codecMask2=2, bytes2=160, negot2=1, dtmf2=6,
                     tx_dynamic_pt1=0, rx_dynamic_pt1=0, codec_mode1=0, params_bitmap1 =0
                     tx_dynamic_pt2=8, rx_dynamic_pt2=8, codec_mode2=0, params_bitmap2 =0
    delay media to slow start case, codec negotation is not done
May 30 20:19:34.616: //465/B5A494800000/CCAPI/cc_api_bridge_done:
    Conference Id=0x16, Source Interface=0x30CF41D4, Source Call Id=465,
    Destination Call Id=466, Disposition=0x0, Tag=0x0
May 30 20:19:34.616: //466/B5A494800000/CCAPI/cc_api_bridge_done:
    Conference Id=0x16, Source Interface=0x30CF41D4, Source Call Id=466,
    Destination Call Id=465, Disposition=0x0, Tag=0x0
May 30 20:19:34.616: //465/B5A494800000/CCAPI/cc_generic_bridge_done:
    Call Entry(Conference Id=0x16, Destination Call Id=466)
    Call Entry(Conference Id=0x16, Destination Call Id=465)
May 30 20:19:34.616: //465/B5A494800000/CCAPI/cc_process_notify_bridge_done:
    Conference Id=0x16, Call Id1=465, Call Id2=466
May 30 20:19:34.616: //465/B5A494800000/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:90555769123@192.168.200.86>;tag=739628-1BDB
CSeq: 101 INVITE
Remote-Party-ID: <sip:0555769123@192.168.200.86>;party=called;screen=yes;privacy=off
Contact: <sip:90555769123@192.168.200.86:5060>
Supported: sdp-anat
Content-Disposition: session;handling=required
Content-Length: 233
v=0
o=CiscoSystemsSIP-GW-UserAgent 2639 5276 IN IP4 192.168.200.86
s=SIP Call
c=IN IP4 192.168.200.86
t=0 0
m=audio 18288 RTP/AVP 8 0 19
a=rtpmap:19 CN/8000
May 30 20:19:34.680: //466/B5A494800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 500 Server Internal Error
CSeq: 101 INVITE
Reason: Q.850;cause=127;text="interworking unspecified"
Warning: 399 - "SoftX3000 R601-CCU Rel POS:[3103] Release from CR"
Content-Length: 0
May 30 20:19:34.680: //466/B5A494800000/CCAPI/cc_api_call_disconnected:
    Cause Value=41, Interface=0x30CF41D4, Call Id=466
    Call Entry(Responsed=TRUE, Cause Value=41, Retry Count=0)
May 30 20:19:34.680: //465/B5A494800000/CCAPI/ccCallReleaseResources:
    release reserved xcoding resource.
May 30 20:19:34.680: //466/B5A494800000/CCAPI/ccCallSetAAA_Accounting:
    Accounting=0, Call Id=466
May 30 20:19:34.680: //465/B5A494800000/CCAPI/ccConferenceDestroy:
    Conference Id=0x16, Tag=0x0
May 30 20:19:34.680: //465/B5A494800000/CCAPI/cc_api_bridge_drop_done:
May 30 20:19:34.680: //466/B5A494800000/CCAPI/cc_api_bridge_drop_done:
May 30 20:19:34.680: //465/B5A494800000/CCAPI/cc_generic_bridge_done:
Sent:
ACK sip:0555769123@10.208.9.69:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
May 30 20:19:34.684: //466/B5A494800000/CCAPI/ccCallDisconnect:
    Cause Value=41, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=41)
    Cause Value=41, Call Entry(Responsed=TRUE, Cause Value=41)
May 30 20:19:34.684: //466/B5A494800000/CCAPI/cc_api_call_disconnect_done:
    Disposition=0, Interface=0x30CF41D4, Tag=0x0, Call Id=466,
    Call Entry(Disconnect Cause=41, Voice Class Cause Code=0, Retry Count=0)
    Call Disconnect Event Sent
May 30 20:19:34.684: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May 30 20:19:34.684: :cc_free_feature_vsa freeing 31A5D9F0
May 30 20:19:34.684:  vsacount in free is 1
May 30 20:19:34.684: //465/B5A494800000/CCAPI/ccCallDisconnect:
    Cause Value=41, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
May 30 20:19:34.684: //465/B5A494800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 503 Service Unavailable
CSeq: 101 INVITE
Reason: Q.850;cause=41
Content-Length: 0
May 30 20:19:34.684: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:90555769123@192.168.200.86:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
May 30 20:19:34.688: //465/B5A494800000/CCAPI/cc_api_call_disconnect_done:
    Disposition=0, Interface=0x30CF41D4, Tag=0x0, Call Id=465,
May 30 20:19:34.688: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May 30 20:19:34.688: :cc_free_feature_vsa freeing 31A5DAD0
May 30 20:19:34.688:  vsacount in free is 0
May 30 20:19:36.044: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:172.29.7.94:5060 SIP/2.0
Via: SIP/2.0/UDP 10.208.9.69:5060;branch=z9hG4bKmisco3ykfiooegpygsphkocp1T20326
Call-ID: isbcfemyk1p1mkteets1tcmi53eeehfhikcp@SoftX3000
To: <sip:172.29.7.94>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
May 30 20:19:36.048: //467/8DAABF6C8278/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:172.29.7.94>;tag=739BBC-1CE2
Date: Fri, 30 May 2014 20:19:36 GMT
CSeq: 1 OPTIONS
Accept: application/sdp
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Content-Length: 446
v=0
o=CiscoSystemsSIP-GW-UserAgent 3496 1601 IN IP4 172.29.7.94
s=SIP Call
c=IN IP4 172.29.7.94
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15
m=image 0 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:9600
a=T38FaxFillBitRemoval:0
a=T38FaxTranscodingMMR:0
a=T38FaxTranscodingJBIG:0
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
My SIP GW internal ip address is 192.168.200.86
and the Public IP is : 172.29.7.94
My CUCM is 192.168.200.53
my GW Config is :
voice service voip
  allow-connections h323 to sip
  allow-connections sip to h323
  allow-connections sip to sip
  fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
  sip
   registrar server
voice class codec 1
  codec preference 1 g711alaw
  codec preference 2 g711ulaw
  codec preference 3 g729r8
  codec preference 4 g729br8
voice translation-rule 3
  rule 1 /^9\(\)/ /\1/
voice translation-rule 4
  rule 4 /^22217/ /7/
  rule 5 /^2217/ /7/
  rule 6 /^022217/ /7/
  rule 7 /^0122217/ /7/
voice translation-rule 5
  rule 1 /^5/ /905/
  rule 2 /^1/ /901/
  rule 3 /^2/ /902/
  rule 4 /^3/ /903/
  rule 5 /^4/ /904/
  rule 6 /^6/ /906/
  rule 7 /^7/ /907/
  rule 8 /^8/ /908/
  rule 10 /^00/ /900/
  rule 11 /'+'/ /900/
voice translation-profile OUT
  translate called 3
voice translation-profile REDIAL
  translate calling 5
voice translation-profile SIP-NEW
  translate called 4
application
  service mva http://192.168.200.53:8080/ccmivr/pages/IVRMainpage.vxml
  service ccm http://192.168.200.53:8080/ccmivr/pages/IVRMainpage.vxml
license udi pid CISCO2921/K9 sn FCZ164960G0
hw-module pvdm 0/0
hw-module pvdm 0/1
interface Embedded-Service-Engine0/0
  no ip address
  shutdown
interface GigabitEthernet0/0
  description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
  ip address 192.168.200.86 255.255.255.0
  duplex auto
  speed auto
interface GigabitEthernet0/1
  ip address 172.29.7.94 255.255.255.252
  duplex auto
  speed auto
ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 192.168.200.1
ip route 10.208.9.0 255.255.255.0 172.29.7.93
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 192.168.200.53 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
  associate ccm 1 priority 1
  associate profile 2 register NAGHI-MTP
dspfarm profile 2 mtp
  codec g711alaw
  maximum sessions hardware 25
  associate application SCCP
dial-peer voice 802 voip
  description ** SIP TO STC **
  translation-profile outgoing OUT
  destination-pattern 9T
  session protocol sipv2
  session target ipv4:10.208.9.69:5060
  session transport udp
  voice-class codec 1
  voice-class sip dtmf-relay force rtp-nte
  dtmf-relay sip-notify rtp-nte sip-kpml
  no vad
dial-peer voice 811 voip
  description ** SIP INCOMING FROM STC **
  translation-profile incoming SIP-NEW
  translation-profile outgoing REDIAL
  destination-pattern 7...
  session target ipv4:192.168.200.53
  incoming called-number 022217...$
  codec g711alaw
dial-peer voice 812 voip
  incoming called-number 22217...$
  codec g711alaw
dial-peer voice 813 voip
  incoming called-number 2217...$
  codec g711alaw
dial-peer voice 814 voip
  preference 1
  session target ipv4:192.168.200.63
  codec g711alaw
dial-peer voice 815 voip
  preference 1
  codec g711alaw
dial-peer voice 816 voip
  preference 1
  codec g711alaw
dial-peer voice 817 voip
  incoming called-number 0122217...$
  codec g711alaw
dial-peer voice 818 voip
  preference 1
  codec g711alaw
Please i need ur help ASAP
Hi Is it sip circuit from STC
Is it sip circuit from STC. Please advice
Duplcate post , go to here
Duplcate post , go to here.
And go through the suggestion that Suresh made on that post.
Dearsyes its from STCand i
Dears
yes its from STC
and i discover that when i call mobily device or local phone or an international number it go through normally
but when i call saw or zain the problem still exist
when i ping from my router to the GW it never disconnect but when i ping their SIP Server it ping and sometimes lost 4 to 12 ping
392
