SIP 3905 on Router - Error to register
Hey,
I have been trying to register the 3905 model on 2921 router in SRST mode.
Conf file has been attached.
thanks.
Configure type command under "voice register pool" then make sure to go into "voice register global" and recreate the profiles: "no create profile" "create profile"
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Hey Jorge,
There are not that commands under voice register pool and voice register global.
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.3(3)M, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 22-Jul-13 01:35 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
em05vg01 uptime is 6 minutes
System image file is "flash:c2900-universalk9-mz.SPA.153-3.M.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2921/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FTX1652AJ91
3 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
Hey, you know what? I think I got this wrong.
This is SRST,  no SIP CME, I'm sorry.
I can see that you have 3 pools, only one of them is using id network.
Please review the DP configuration on the 3905, and double check if the SIP SRST reference is configured correctly, if so, go into the Phone and do a reset. Wait for it to come up, then check the Web Page of the phone, or on the phone directly, and verify if the IP Address of the SRST reference is in the list.
Jorge Armijo
236
