Community Member
SIP 500 Error on CUBE and CUCMBE
So Inbound calls works fine with no issues, however outbound I'm getting a busy signal when I dial out to the PSTN, not your typical CSS fast busy but busy like someone who does not have call waiting. Here are the debugs below.
*Sep  1 15:33:16.855: //10/38360D000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 500 Internal Server Error
Via: SIP/2.0/UDP 192.168.1.8:5060;branch=z9hG4bK12d271b8c5e
From: "user - 1000" <sip:2089013875@192.168.1.8>;tag=645~82127680-9903-4752-ad60-3545686b7a7f-25789895
To: <sip:+17705000140@192.168.1.3>;tag=1DD304-1CA2
Date: Sun, 01 Sep 2013 15:33:16 GMT
Call-ID: 38360d00-2231532b-11c-801a8c0@192.168.1.8
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Reason: Q.850;cause=44
Content-Length: 0
192.168.1.3= CUBE
192.168.1.8= CUCMBE
v=0
o=CiscoSystemsCCM-SIP 645 1 IN IP4 192.168.1.8
s=SIP Call
c=IN IP4 192.168.1.3
t=0 0
m=audio 19426 RTP/AVP 18 101
a=rtpmap:18 G729/8000
a=ptime:20
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
SIP trunk between CUCMBE and CUBE are MTP codec method is 711ulaw, in my Regions my CUBE is set to g729r8, and phones are set to 711ulaw. I'm not sure what's happening but it's very frustrating.
Anyone can be of assistance?
2 ACCEPTED SOLUTIONS
VIP Super Bronze
Looking at your config..The outbound dial-peer that is matched is configured as follows
dial-peer voice 101 voip
description 10-digit local calls to Intelepeer
destination-pattern ^[2-9]..[2-9]......$
session protocol sipv2
session target sip-server------------------------------------
session transport tcp
voice-class sip early-offer forced
voice-class sip profiles 100
dtmf-relay rtp-nte
no vad
From your config, the destination-pattern is pointing to a sip-server, however there is no configuration on your gateway to define the ip address of the sip server. This is configured under sip-ua
voice service voip
sip-ua
sip-server ipv4:10.10.10.10--------------where 10.10.10.10 is the ip address of given to you by your ITSP
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
Glad I could help, dont forget to rate useful posts though!
VIP Super Bronze
you will need to send the full debug ccsip messages. Also include your sh run. pls attach them
Community Member
Re: SIP 500 Error on CUBE and CUCMBE
                   Check attachments.
VIP Super Bronze
Kenneth,
Th gateway is not sending out the INVITE..I need the sh run of the gateway to see your setup...What is the call flow?
Is this sip to sip or sip to ISDN?
cucmbe--sip----cube--sip--itsp?
Community Member
What is your email address?
Community Member
Call flow is ITSP->CUBE->CUCMBE->IP Phone.
Community Member
You had the call flow correct.
VIP Super Bronze
You can send the config to me via PM..just send me a private message
Community Member
Please check PM.
VIP Super Bronze
dtmf-relay rtp-nte
no vad
voice service voip
sip-ua
Community Member
Yes I discovered that when I got home today. I thought it was in the config but it wasn't. I applied it to my config and all is working. Thank you for assisting me with this.
VIP Super Bronze
909
