Sip 500 Internal Server Error Reason: Q.850;cause=16
Please help in understanding what is wrong in the config .Incoming calls don't work.
show run:
voice service voip
ip address trusted list
  ipv4 87.226.136.164 255.255.255.255
  ipv4 172.16.24.0 255.255.255.0
  ipv4 188.254.68.66 255.255.255.255
  ipv4 188.254.68.67 255.255.255.255
  ipv4 188.254.69.66 255.255.255.255
  ipv4 188.254.69.67 255.255.255.255
  ipv4 46.38.52.68 255.255.255.255
address-hiding
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback cisco
sip
voice class codec 1
codec preference 1 g729br8
codec preference 2 g729r8
codec preference 3 g711alaw
codec preference 4 g711ulaw
voice class codec 2
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
voice translation-rule 1
rule 1 /XXX5397962/ /1999/
voice translation-rule 2
rule 1 /XXX55317577/ /1999/
voice translation-rule 3
rule 1 /5555317884/ /1999/
voice translation-profile ROS
translate called 1
voice translation-profile ROS2
translate called 2
voice translation-profile ROS3
translate called 3
interface FastEthernet0/0
ip address 178.208.X.X 255.255.255.248
ip access-group INBOUND in
no ip unreachables
ip verify unicast reverse-path
ip nat outside
ip inspect IPFW in
ip inspect IPFW out
ip virtual-reassembly in
duplex auto
speed auto
no cdp enable
interface FastEthernet0/1
no ip address
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1.1
encapsulation dot1Q 1 native
ip address 10.110.0.200 255.255.255.0
ip nat inside
interface FastEthernet0/1.2
encapsulation dot1Q 2
ip address 172.16.24.254 255.255.255.0
ip nat inside
h323-gateway voip interface
h323-gateway voip bind srcaddr 172.16.24.254
ip dns server
ip nat inside source list NAT interface FastEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 178.208.X.X
ip route 192.168.0.0 255.255.0.0 Null0 254
sccp local FastEthernet0/1.2
sccp ccm 172.16.24.101 identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register XCODE123456
keepalive retries 1
keepalive timeout 10
switchover method immediate
switchback method immediate
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 6
associate application SCCP
dial-peer voice 10000 voip
tone ringback alert-no-PI
description ROSTELECOM Incoming
translation-profile incoming ROS
destination-pattern 74955397962
session protocol sipv2
session target ipv4:87.226.136.164
session transport udp
incoming called-number XXXX5397962
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 10010 voip
translation-profile incoming ROS2
destination-pattern XXX55317577
incoming called-number 75555317577
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 10020 voip
translation-profile incoming ROS3
preference 1
destination-pattern 5555317884
session target ipv4:188.254.68.66
incoming called-number 5555317884
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 10021 voip
preference 2
session target ipv4:188.254.69.66
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 2 voip
description to CUCM_PUB
destination-pattern 1...
session target ipv4:172.16.24.101
voice-class codec 2
dtmf-relay rtp-nte
debug ccsip all:
c2801#
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [188.254.68.66]:9290, local_address:[ - ]
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
06:19:26: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
06:19:26: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:5555317884@178.208.X.X;user=phone SIP/2.0
Via: SIP/2.0/UDP 188.254.68.66:9290;branch=z9hG4bK-6110d60075c89eab-a(STATE_IDLE, SUBSTATE_NONE)
06:19:26: //-1/xxxxxxxxxxxx/SIP/T3c000c-1
Call-ID: isbc6994325518770806443-1385214296-16204
Fransport/sipSPIUpdateResponseInfo: Dialog Transaction Address 188.254.68.66,Port 9290, Transport 1, SentBy Port 5060
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone MSK to SIP default timezone = GMT
06:19:26: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 188.254.68.66,Port 929rom:
<sip:9067259847@sipgw120.com;user=phone>;tag=sbc09026994325from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
06:19:26: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 188.254.68.66,Port 9290, Transport 1, SentBy Port 5060
06:19:26: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 188.254.68.66,Port 518770806443
ddress_to_bind: return addr 178.208.X.Xone>
06:19:26: //-1/EE5EC9DD8170/SIP/State/sipSPIChangeState: 0x6A874E70 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
CSeq: 1 INVITE
Min-SE: 90
Session-Expires: 3600;refresher=u6:19:26: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Convac
Contact: <sip:9067259847@188.254.68.66:9290;user=phone>
A //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: rellow: INVITE,CANCEL,BYE,ACK,REFER,UPDATE,INFO,PRACK
Supported:turn addr 178.208.X.X
06:19:26: //-1/EE5EC9DD8170/SIP/St timer,100rel
Diversion: <sip:8002001706@sipgw120.com>;privacyate/sipSPIChangeState: 0x6A874E70 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
Sen=off;screen=no;reason=unknown,<sip:8002001706@sipgw120.com>;priv6:19:26: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponsacy=off;screen=no;reason=unknown
Max-Forwards: 70
User-AgenteInfo: Dialog Transaction Address 188.254.68.66,Port 9290, Tra: VCS 5.8.2.56-03
Content-Length: 393
Content-Type: applicatnsport 1, SentBy Port 9290ion/sdp
v=0
o=- 12060 26053 IN IP4 188.254.68.67
s=SBC call
c=IN IP4 188.254.68.67
t=0 0
m=audio 24402 RTP/AVP 8 0 18 98 96 97 101
a=rtpmap:98 G.729a/8000
a=rtpmap:96 G.729ab/8000
a=rtpmap:97 G.729b/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=fmtp:18 annexb=no
a=ptime:10
a=X-vrzcap:vbd Ver=1 Mode=FaxPr ModemRtpRed=0
a=X-vrzcap:identification bin=DSR2866 Prot=mgcp App=MG
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x6A874E70) with key=[52] to table
06:19:26: //-1/000000000000/SIP/Info/sipSPI_ipip_vcc_Initialization:  Entry...
06:19:26: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 188.254.68.66,Port 9290, Transport 1, SentBy Port 9290
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling reg_invoke_ip_first_hop()
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling ip_best_local_address()
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: return addr 178.208.X.X
c2801#L
06:19:26: //-1/EE5EC9DD8170/SIP/Info/sipSPIUaddCcbToUASReqTable: ****Adding to UAS Request table.
06:19:26: //-1/EE5EC9DD8170/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x6
c2801#a
06:19:26: //-1/EE5EC9DD8170/SIP/Info/sipSPIMatchSrcIp
c2801#mat: VIA URL:sip:188.254.68.66:9290, Host:188.254.68.66
06:19:26: //-1/EE5EC9DD8170/SIP/Info/sipSPIGetShrlPeer: Try match incoming dialpeer for Calling number: : 9067259847
06:19:26:ched for incoming call
06:19:26: //-1/EE5EC9DD8170/SIP/Info/sipSPIGetCallConfig: Precondition tag absent in Require/Supported h
06:19:26: //-1/EE5EC9DD8170/SIP/Info/sipSPIGetFromCalledPartyId: P-Called-Party-ID header not found
06:19:26: //-1/EE5EC9DD8170/SIP/Info/sipSPIGetPeerByCalledPartyId: P-Called-Party-ID not found or parse error
06:19:26: //-1/EE5EC9DD8170/SIP/Info/sipSPIGetCallConfig: No match found for P-Called-Party-ID
06:19:26: //-1/EE5EC9DD8170/SIP/Info/sipSPIGetCallConfig: Peer tag 10020 matched for incoming call
06:19:26: //-1/EE5EC9DD8170/SIP/Info/sipSPIGetCallConfig: Precondition tag absent in Require/Supported header
06:19:26: //-1/EE5EC9DD8170/SIP/Info/sipSPIGetCallConfig: Checking Video Type Rate=-1 video_codec_allowed=1F
06:19:26: //-1/EE5EC9DD8170/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
06:19:26: //-1/EE5EC9DD8170/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=0
06:19:26: //-1/EE5EC9DD8170/SIP/Info/sipSPIGetCallConfig: xcoder high-density disabled
06:19:26: //-1/EE5EC9DD8170/SIP/Info/sipSPIGetCallConfig: Flow Mode set to FLOW_THROUGH
06:19:26: //-1/EE5EC9DD8170/SIP/Info/sipSPIGetCallConfig: Media forking disabled
06:19:26: //-1/EE5EC9DD8170/SIP/Info/sipSPIContinueNewMsgInvite: Calling name , number 9067259847, Calling oct3 0x00, oct_3a 0x80, ext_priv 0x00, Called number
5555317884, oct3 0x00
06:19:26: //-1/EE5EC9DD8170/SIP/Info/sipSPIContinueNewMsgInvite: Carrier id code , prev_cid NONE, next_cid NONE, prev_tgrp NONE, next_tgrp NONE
06:19:26: //-1/EE5EC9DD8170/SIP/Info/sipSPIContinueNewMsgInvite: Requires reliable-provisional support
06:19:26: //-1/EE5EC9DD8170/SIP/Info/sipSPIValidateRequestUri: Not Enabled
06:19:26: //-1/EE5EC9DD8170/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPI_ipip_IsSDPPassthruEnabled:  - 0
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
06:19:26: //129/EE5EC9DD8170/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
06:19:26: //129/EE5EC9DD8170/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:6A01759C
06:19:26: //129/EE5EC9DD8170/SIP/Info/Session-Timer/sipSTSLExtractSessionExpiresHdr:
Session-Expires value: 3600 refresher: uac
06:19:26: //129/EE5EC9DD8170/SIP/Info/Session-Timer/sipSTSLExtractMinSEHdr: Min-SE Duration: 90
06:19:26: //129/EE5EC9DD8170/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_INITIAL_SR_REQ
06:19:26: //129/EE5EC9DD8170/SIP/Info/Session-Timer/sipSTSLInitialSRReqPeerEventGen: sending received session expires to the peer leg
06:19:26: //129/EE5EC9DD8170/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_PASS_ST_PARAMS, SE Value:3600, SE Refresher:uac, Min-SE Value:1800,
flags:2001
06:19:26: //129/EE5EC9DD8170/SIP/Info/Session-Timer/sipSTSLMain:
        SE: 3600;refresher:uac peer refresher:none, flags:2001, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
        Configured SE:1800, Configured Min-SE:1800
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPIProcessReplacesHeader: No replaces hdr found
SIP: Warning: Unrecognized attribute (X-vrzcap)
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPIValidateConnectionAddress: Dest port = 24402
SIP: (129) Attribute mid, level 1 instance 1 not found.
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/resolve_media_ip_address_to_bind: calling reg_invoke_ip_first_hop()
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/resolve_media_ip_address_to_bind: calling ip_best_local_address()
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/resolve_media_ip_address_to_bind: return addr 178.208.X.X
06:19:26: //129/EE5EC9DD8170/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 178.208.X.X
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(98) reserved for codec g729r8
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(96) reserved for codec g729abr8
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(96) could not be reserved
                          as its in use by other codec g729abr8
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPT: Requested payload-Type (96) is  reserved by another application
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 99 for Codec:
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(97) reserved for codec g729br8
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(97) could not be reserved
                          as its in use by other codec g729br8
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPT: Requested payload-Type (97) is  reserved by another application
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 97
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 102 for Codec:
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec No Codec
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 99
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved
                          as its in use by other codec No Codec
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPT: Requested payload-Type (101) is  reserved by another application
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 103
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 101
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 101 for Codec:
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPIDoPtimeNegotiation: One ptime attribute found - value:10
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :10, codecbytes: 80
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :80, ptime: 10
06:19:26: //129/EE5EC9DD8170/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:10, Negotiated ptime:10 Negotiated codec bytes: 80 for codec g711ulaw
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPISetFaxFlags: FAX_PASSTHROUGH = 0, END_FAX_PASSTHROUGH = 0
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPIReserveRtpNtePayload: Reserved the payload type 101 for RTP-NTE
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: V150 NSE payload = 0, SSE payload = 0, SPRT payload=0
06:19:26: //129/EE5EC9DD8170/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-
line:1 and num-a-lines:0
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
        payload_type=0, codec_bytes=80, codec=g711ulaw, dtmf_relay=rtp-nte
        stream_type=voice+dtmf (1), dest_ip_address=188.254.68.67, dest_port=24402
06:19:26: //129/EE5EC9DD8170/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
06:19:26: //129/EE5EC9DD8170/SIP/Media/sipSPIUpdCallWithSdpInfo:
        Preferred Codec        : g711ulaw, bytes :160
        Preferred  DTMF relay  : rtp-nte
        Preferred NTE payload  : 101
        Early Media            : No
        Delayed Media          : No
        Bridge Done            : No
        New Media              : No
        DSP DNLD Reqd          : No
06:19:26: //129/EE5EC9DD8170/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 129 peer 0 flags 0x201 state STATE_IDLE
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPI_ipip_vcc_ProcessXcoderNeeded: xcoder_attached not yet initialised for this call.
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPI_ipip_report_media_to_peer: Xcoder not yet used for the call
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 129, Peer CallID 0, sdp 0x69EC3234 channels 0x6A8763C4
06:19:26: //129/EE5EC9DD8170/SIP/Info/copy_channels:
callId 129 size 0 ptr 0x6899F6D4)
CCB t38 version 0 ipip_caps version 0
CCB fax rate 2 ipip_caps rate 14400
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: reset the  switch..
Hndl ptype 8 mline 1
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711alaw
06:19:26: //129/EE5EC9DD8170/SIP/Info/codec_found:
Codec to be matched: 6
06:19:26: //129/EE5EC9DD8170/SIP/Info/codec_found: No match for the codecs found..
Hndl ptype 0 mline 1
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
Codec to be matched: 5
06:19:26: //129/EE5EC9DD8170/SIP/Info/codec_found:  codecs[i] = 5 & codec = 5 are same..
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 5
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=10,stream->negotiated_codec_bytes=80,
coverted ptime=10 stream->mline_index=1, media_ndx=1
failed to update call entry
Adding codec 5 ptype 0 time 10, bytes 80  as channel 0 mline 1 ss 1 188.254.68.67:24402
Hndl ptype 18 mline 1
06:19:26: //129/EE5EC9DD8170/SIP/Media/sipSPISelectCodecVersion: Codec (g729r8) is not in preferred list
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: An exact codec match not configured, using interoperable codec g729r8
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g729r8
Codec to be matched: 16
Hndl ptype 98 mline 1
Hndl ptype 96 mline 1
Hndl ptype 97 mline 1
Hndl ptype 101 mline 1
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: setting ipip_caps DTMF to RFC2833: callid = 129, dtmf = 6
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec
= 5
= -1
callId 129 flags 0x100 state STATE_IDLE
Report initial call media
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPI_ipip_report_media_to_peer: ccb->flags 0x804000C, ccb->pld.flags_ipip 0x201
callId 129 size 240 ptr 0x69E20A34)
CCSIP: Unable to report channel ind
06:19:26: //129/EE5EC9DD8170/SIP/Info/ccsip_update_srtp_caps:  5798: Posting Remote SRTP caps to other callleg.
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPI_ipip_report_media_to_peer: do cc_api_caps_ind()
          Stream type            : voice+dtmf
          Media line             : 1
          State                  : STREAM_ADDING (2)
          Stream address type    : 1
          Callid                 : -1
          Negotiated Codec       : g711ulaw, bytes :80
          Nego. Codec payload    : 0 (tx), 0 (rx)
          Negotiated DTMF relay  : rtp-nte
          Negotiated NTE payload : 101 (tx), 101 (rx)
          Negotiated CN payload  : 0
          Media Srce Addr/Port   : [178.208.X.X]:0
          Media Dest Addr/Port   : [188.254.68.67]:24402
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPIHandleInviteMedia:
Preferred  DTMF relay 1 : 6
Preferred  DTMF relay 2 : 0
Negotiated DTMF relay   : 6
Preferred and Negotiated NTE payloads: 101 101
Preferred and Negotiated NSE payloads: 100 0
Preferred and Negotiated Modem Relay: 0 0
Preferred and Negotiated V150.1 Modem Passthrough: 0 0
Preferred and Negotiated V150.1 Modem Relay: 0 0
Preferred and Negotiated Modem Relay GwXid: 1 0
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: QOS negotiation for mline_index 1
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPIDoStreamQoSNegotiation: Best effort
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
06:19:26: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 17550 for stream 1
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPIUpdateSrcSdpFixedPart: Reserving rtp port for stream 1, src_port=17550
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 17550
SIP update src sdp, negoitated codec 5, payload type 0
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Negotiated method of dtmf relayand pyld: 6 101
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPIAddBillingInfoToCcb: sipCallId for billing records = isbc6994325518770806443-1385214296-16204
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentCPA: No CPA found in inbound container
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPIProcessCPA: No x-cisco-cpa content found
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPI_ipip_store_channel_info: Store channelInfo in CallInfo
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPI_ipip_store_channel_info: dtmf negotiation done, storing negotiated dtmf = 6,
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPIShrlCall: Check peer: 10020 for Shared-Line call, callid: 129
06:19:26: //129/EE5EC9DD8170/SIP/Info/ccsip_set_bearer_capability:
   Bearer Capability: Speech (0x00)
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateNewRawMsg: No Data to form The Raw Message
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPIContinueNewMsgInvite: ccsip_api_call_setup_ind returned: SIP_SUCCESS
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 81 to table
06:19:26: //129/EE5EC9DD8170/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
06:19:26: //129/EE5EC9DD8170/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:6A0173E4
06:19:26: //129/EE5EC9DD8170/SIP/Info/Session-Timer/sipSTSLValidateSessRefreshMsg: Ignoring 1xx response for session timer processing
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPISendInviteResponse: Associated container=0x6A0173E4 to Invite Response 100
06:19:26: //129/EE5EC9DD8170/SIP/Transport/sipSPITransportSendMessage: msg=0x6A5A1A34, addr=188.254.68.66, port=9290, sentBy_port=9290, local_addr=, is_req=0,
transport=1, switch=0, callBack=0x0
06:19:26: //129/EE5EC9DD8170/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
06:19:26: //129/EE5EC9DD8170/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
06:19:26: //129/EE5EC9DD8170/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x6A5A1A34 to default port=9290
06:19:26: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostRequestConnection: Posting UDP conn create request for addr=188.254.68.66, port=9290, context=0x68ABB118
06:19:26: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportSetConnWaitTimer: Wait timer set for connection=0x68ABCB0C,addr=188.254.68.66, port=9290
Wait Conn Timer started for 5000 msec
06:19:26: //-1/xxxxxxxxxxxx/SIP/Transport/sipCreateConnInstance: Created new initiated conn=0x68ABCB0C, connid=-1, addr=188.254.68.66, port=9290, local_addr=,
transport=UDP
06:19:26: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:188.254.68.66, rport:9290 with laddr:
06:19:26: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: Registering gcb=0x6A874E70 with connection=0x68ABCB0C
06:19:26: //129/EE5EC9DD8170/SIP/Transport/sipTransportLogicSendMsg: Waiting for Connection for sending msg=0x6A5A1A34
06:19:26: //129/EE5EC9DD8170/SIP/Transport/sipSPITransportSendMessage: Deferred sending msg=0x6A5A1A34
06:19:26: //129/EE5EC9DD8170/SIP/State/sipSPIChangeState: 0x6A874E70 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_RECD_INVITE, SUBSTATE_NONE)
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPIProcessContactInfo: Previous Hop 188.254.68.66:9290
06:19:26: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 165)
06:19:26: //129/EE5EC9DD8170/SIP/Info/ccsip_event_handler:
ccsip_event_handler: peer ID 130 chans 0x6780D478 event 165 flags 0x844001C 0x100 0x601 data 0x6780D478
ccsip_event_handler: CC_EV_H245_SET_MODE: peer ID 130 chans 0x6780D478 event 165 flags 0x844001C 0x100 0x601 data 0x6780D478, type = 1
06:19:26: //129/EE5EC9DD8170/SIP/Info/ccsip_gw_set_sipspi_mode: Setting SPI mode to SIP-H323
06:19:26: //129/EE5EC9DD8170/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SET_MODE
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 3
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 58
06:19:26: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWConnectionCreated: context=0x68ABB118
06:19:26: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessConnCreated: gConnTab=0x68ABB118, addr=188.254.68.66, port=9290, local_addr=, connid=3,
transport=UDP
06:19:26: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessConnCreated: connection instance created for addr:188.254.68.66, port:9290 local_addr=
local_port=57282
06:19:26: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportStopConnWaitTimer: Wait timer stopped for connection=0x68ABCB0C,addr=188.254.68.66, port=9290
06:19:26: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceHandleConnectionCreated: Moving connection=0x68ABCB0C, connid=3 state to established. local_addr=,
local_port=57282
06:19:26: //129/EE5EC9DD8170/SIP/Transport/sipTransportPostInternalMsg: Posting Internal Msg type=0
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 63
06:19:26: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x6A5A1A34, addr=188.254.68.66, port=9290, local_addr=, connId=3 for UDP
06:19:26: //129/EE5EC9DD8170/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 188.254.68.66:9290;branch=z9hG4bK-6110d60075c89eab-a3c000c-1
From: <sip:9067259847@sipgw120.com;user=phone>;tag=sbc09026994325518770806443
To: <sip:5555317884@178.208.X.X;user=phone>
Date: Sat, 23 Nov 2013 13:42:29 GMT
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
06:19:26: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_ALERTING
06:19:26: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_call_service_msg: ccb NULL, unable to update the callinfo ui parameters
06:19:26: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 5
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPIAddCiscoGcid: Fatal Error in parsing CCB/Msg
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIStoreTunnelData: Container /RawMessage Absent
06:19:26: //129/EE5EC9DD8170/SIP/Error/sipSPI_ipip_set_history_info_header: Not SIP2SIP mode
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPIUaddCcbToUASRespTable: ****Adding to UAS Response table.
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x6A874E70 key=isbc6994325518770806443-1385214296-1620415B6280-0
06:19:26: //129/EE5EC9DD8170/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:180, container:6A017B1C
06:19:26: //129/EE5EC9DD8170/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
06:19:26: //129/EE5EC9DD8170/SIP/Info/sipSPISendInviteResponse: Associated container=0x6A017B1C to Invite Response 180
06:19:26: //129/EE5EC9DD8170/SIP/Transport/sipSPISendInviteResponse: Sending 180 Response to the Transport Layer
transport=1, switch=0, callBack=0x618A57B8
06:19:26: //129/EE5EC9DD8170/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x6A5A1A34
06:19:26: //129/EE5EC9DD8170/SIP/Info/sentInviteResponse18x: Sent a 18x Response
06:19:26: //129/EE5EC9DD8170/SIP/Info/sentInviteResponse18x: Transaction active. Facilities will be queued.
06:19:26: //129/EE5EC9DD8170/SIP/State/sipSPIChangeState: 0x6A874E70 : State change from (STATE_RECD_INVITE, SUBSTATE_NONE)  to (STATE_SENT_ALERTING, SUBSTATE_NONE)
06:19:26: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 30ty-ID:
<sip:1999@178.208.X.X>;party=called;screen=no;privacy=off
Contact: <sip:5555317884@178.208.X.X:5060>
Content-Length: 0
06:19:27: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [188.254.68.66]:9290, local_address:[ - ]
06:19:27: //129/EE5EC9DD8170/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 188.254.68.66:9290;branch=z9hG4bK-6110d60075c89eab-a3c000c-2
To: <sip:5555317884@178.208.X.X;user=phone>;tag=15B6280-0
Date: Sat, 23 Nov 2013 13:42:30 GMT
CSeq: 2 PRACK
Content-Length: 0
Sent:
UPDATE sip:9067259847@188.254.68.66:9290;user=phone SIP/2.0
Via: SIP/2.0/UDP 178.208.X.X:5060;branch=z9hG4bK120
From: <sip:5555317884@178.208.X.X;user=phone>;tag=15B6280-0
To: <sip:9067259847@sipgw120.com;user=phone>;tag=sbc09026994325518770806443
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Timestamp: 1385214150
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 UPDATE
Min-SE:  1800
Remote-Party-ID: <sip:1700@178.208.X.X>;party=called;screen=yes;privacy=off
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 2 PRACK
Content-Length: 0
06:19:31: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [188.254.68.66]:9290, local_address:[ - ]
06:19:31: //129/EE5EC9DD8170/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 500 Internal Server Error
CSeq: 1 INVITE
Content-Length: 0
06:19:31: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
06:19:31: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
06:19:31: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:5555317884@178.208.X.X;user=phone SIP/2.0
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
06:19:31: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
06:19:31: //129/EE5EC9DD8170/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x6A874E70
06:19:31: //129/EE5EC9DD8170/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x6A874E70 key=isbc6994325518770806443-1385214296-1620415B6280-0
06:19:31: //129/EE5EC9DD8170/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
06:19:31: //129/EE5EC9DD8170/SIP/Info/sipSPIStopRequestPendingTimer: Stopping Request Pending Timer
06:19:31: //129/EE5EC9DD8170/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
06:19:31: //129/EE5EC9DD8170/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 6A874E70
06:19:31: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[52]
c2801#
c2801#
1 ACCEPTED SOLUTION
Hi,Piyush
I resolved it already,it was a codec problem and h323 faststart should have been enabled.
Thank you for trying to help.
Hi Ahmed,
Looking at the logs, it seems some important messages are missing..
can you please again collect the following debugs ?
- debug voip ccapi inout
- debug ccsip all
- debug voice translation
Piyush
Hi,Piyush
1577
