SIP 6941 phone rejected from CUCM 9.1
I'm having issues with a 6941 phone with SIP firmware connecting back to the CUCM.  It connects enough to pull firmware from the call manager but then the call manager rejects it once it tries to connect up and pull config.  The phone is just saying phone not registered and the CUCM is saying rejected.  The phone is at a remote location and is being NAT'd but I have disabled SIP ALG on the remote router to make sure that didn't interfere.  Should SIP ALG be disabled on the server side as well.  Below is a screenshot of what I'm seeing on the CUCM.
Thanks for your help in advance
1 ACCEPTED SOLUTION
Re: SIP 6941 phone rejected from CUCM 9.1
I assume you are trying to load 69xx-sip.9-3-3-2-sr1? If so, Download 69xx-sip.9-3-1-5 and try that. I ran into a similar issue with cucm 8.5.1 and send traces to Cisco, they should be validating the bug and releasing a new load at some point.
Hope this helps.
Anyone had this issue or have a recommendation?
Search  with the Device Name whether the device name is  already registered or not
Hope this helps.
459
