SIP and FXO selection
 hi all;
I need my gateway to route the calls coming from 58XX extensions to PSTN SIP trunk
and to route the calles coming from 61XX extension to FXO lines
anybody had this scenario befor ?!
regards
1 ACCEPTED SOLUTION
Yes you can do that, Youse
Youse answer-adreess to match inbounf dial-peer and then apply translation rule on that,
using translation rule prepfix something to your DNIS that chosses your outbound dial-peer.
on the outbound dial-peer, once gain apply translation rule to remove prefixed digit, and Make DNIS as original.
There are lot many post on this topic, search for ANI based routing.
Chintan
1 REPLY
Chintan
