SIP and H323
We have the attached setup (attached)  that we have local H.323 network, which includes Cisco 3845 (Gateway), Cisco CVP 3.1 (IVR), Cisco Call Manager and IP Phones.
The gateway was having PRI ISDN Ports and was working fine end-to-end. Then we needed to test using SIP instead of the PRI E1s. that as making the gateway (Cisco 3845) as signaling gateway only with SIP-H.323 signaling conversion. That’s it receive and sends the SIP with the Ericsson Switch (MSC) and H.323 signals with the other Internal system. Also the payload to directed directly from the MSCs to the IVR or the IP Phones, without passing the gateway. We faced a problem to hear IVR when start testing. So to simplify troubleshooting, I configure the dial peers in order to direct the call request directly to the call manager and then to phone for testing purposes.
The case is that when we call from outside (call to 912080000) the phone rings and the caller hear the ringing tone, but when we hang up the phone, the caller still hear the ring and the line is not opened at his side. It looks for me that the signal is not travelling well throughout the Gateway.  Attach is output for the SIP & H323 debug, plus an output for “show SIP call”  during the call.
Can you please help me in this, and if there is something wrong with the configurations.
Below is the Gateway configuration:
Building configuration...
Current configuration : 4044 bytes
version 12.4
service password-encryption
hostname IPCC-Test-GW
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 $1$baVf$Tze2yBVuBGTThhX47t2fu.
no aaa new-model
network-clock-participate wic 0
ip source-route
ip cef
ip domain name icm.ipcclab
ip host isn-vxml 192.168.40.44
ip host media 192.168.40.44
ip host isn-server 192.168.40.44
ip host mediaserver 192.168.40.44
no ipv6 cef
isdn switch-type primary-net5
voice-card 0
voice call send-alert
voice call convert-discpi-to-prog tunnel-IEs
voice rtp send-recv
voice disc-pi-incoming-on
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol cisco
h323
  emptycapability
  h225 timeout setup 20
  no h225 timeout keepalive
sip
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class h323 1
  call start fast
http client cache memory pool 1000
http client cache memory file 100
http client cache refresh 200000
no http client cookie
http client connection timeout 60
http client response timeout 30
ivr prompt memory 16384
ivr prompt streamed all
application
service new-call flash:bootstrap.vxml
  paramspace english language en
  paramspace english index 0
  paramspace english location flash
  paramspace english prefix en
service vru-leg flash:bootstrap.tcl
service handoff flash:handoff.tcl
vxml tree memory 5000
archive
log config
  hidekeys
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
interface GigabitEthernet0/0
ip address 10.0.231.35 255.255.255.0
ip accounting output-packets
ip flow ingress
duplex auto
speed auto
media-type rj45
keepalive 1800
h323-gateway voip interface
h323-gateway voip id ZAINSD ipaddr 10.0.232.32 1719
h323-gateway voip h323-id IPCC-Test-GW
h323-gateway voip tech-prefix 2#
h323-gateway voip bind srcaddr 10.0.231.35
interface GigabitEthernet0/1
ip address 10.18.1.135 255.255.255.240
ip flow ingress
duplex full
speed 1000
media-type rj45
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.0.231.1
ip route 10.3.3.0 255.255.255.128 10.18.1.131 name MG2-MG4
ip route 10.18.3.0 255.255.255.128 10.18.1.131 name MSC-S1
ip http server
control-plane
voice-port 0/0/0:15
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
dial-peer voice 999 voip
destination-pattern ..........
session protocol sipv2
session target sip-server
dial-peer voice 200 voip
description "VRU LEG"
translation-profile incoming block
service vru-leg
voice-class codec 1
incoming called-number 4619T
dtmf-relay rtp-nte h245-signal h245-alphanumeric
no vad
dial-peer voice 300 voip
max-conn 400
destination-pattern 46111
voice-class codec 1
session target ras
tech-prefix 2#
icpif 25
no vad
dial-peer voice 990 voip
voice-class codec 1
incoming called-number 91208....
dial-peer voice 995 voip
destination-pattern 4449
voice-class codec 1
session target ipv4:10.0.232.50
dtmf-relay h245-alphanumeric
num-exp 912080000 4449
gateway
timer receive-rtp 1200
sip-ua
sip-server ipv4:10.18.3.8
gatekeeper
shutdown
line con 0
line aux 0
line vty 0 4
password 7 070C285F4D06
login
scheduler allocate 20000 1000
end
742
