SIP and SCCP CME at the same time
I know the above should be possible, except one thing I can't figure out. In flash I have both SCCP and SIP firmware, for, let's say, 7960.
I want some of my 7960s to be SIP others SCCP.
I have the following:
Telephony-service
load 7960-7940 XXXXXX
create cnf
Voice register global
load 7960-7940 YYYYYY
create profile
and all other needed regarding tftp-server.
How will the newly plugged phone behave, which load will it download.
I tried it in the lab and to me it seemed that SCCP FW has advantage over the SIP (Didn't want to upgrade to SIP as long as I kept telephony-service).
Can anyone comment on this?
best regards
Goran Pilat
1 REPLY
Re: SIP and SCCP CME at the same time
OK seems I figured it out...
So you have two possible servers to run CME : SIP (voice register global) and SCCP (telephony-service).
When you create ephone, you basicaly create SEPAAAABBBBCCCC.cfg.xml file for that phone (assume MAC address is aaaa.bbbb.cccc)
When you create voice register pool, you create SIPAAAABBBBCCCC.cfg.xml file for that phone ( MAC address is aaaa.bbbb.cccc)
When the phone boots it looks for its config files in this order:
So if both files exist (both ephone and voice register pool with same MAC), it will take SEP file, and the phone will remain (or upgrade to) SCCP
Useful command that shows which files exactly you have on tftp is :
show telephony-service tftp
show voice register tftp
debug tftp events >> when powering the phone
Now for the tricky part:
If you had your phone configured as ephone, and you want to upgrade it to SIP, just by "no ephone" command you won't remove the SEP file (alias to be correct). And the phone will still find its SEP file and register with SCCP, although appearing "empty" - no ephone-dn. So you have to remove the alias line from the output of "show telephony-service tftp" command.
Only then will phone when booting come to the part to download SIPAAAABBBCCC file...
Phew...
Hope it's useful :) (At least I'l know where to find it next time)
Goran Pilat
331
