05-06-2014 04:57 AM - edited 03-16-2019 10:41 PM
i have an Telephony setup with CME 2921 router with 15.X software version.
I need to configure the SIP Bind command under the voice service voip.
bind control source-interface FastEthernet 0/0
But when I am configuring I getting the error.
"There are active sip calls
The bind command change will not take effect".
There is no sip active calls when I configure the command.
I tried the below
voice service voip
shut
sip
call service stop
But there is no luck.
Thanks in advance
Nithin Louis.
Solved! Go to Solution.
05-06-2014 05:18 AM
Hello Nithin,
There might be some hanging calls on the router which would be cleared only by reboot.
Please enter 'show call active voice brief' to check them. If there are any calls hanging and if the gateway is not in production, you can reboot the gateway to clear those calls. After the reboot, check the calls once again with 'show call active voice brief'. if no calls, then you would be able to bind the IP address.
//Suresh
Please rate all the helpful posts.
05-06-2014 06:39 AM
As Suresh correctly suggested (+5 S) there might be active sip calls including SIP registration processes or refresh through sip-ua .
show sip-ua calls should show you active calls.
If present I can suggest you to copy all sip-ua config and then issue a no sip-ua command in configuration mode , change the bind command under voice service voip --> sip and than paste again sip-ua config.
Carlo
05-06-2014 05:18 AM
Hello Nithin,
//Suresh
05-06-2014 06:39 AM
Carlo
05-06-2014 11:38 PM
Hi Suresh,
Thanks for the response.Yes there was some sip call legs hanging and after reload all sip call legs cleared and I was able to configure the SIP Bind command.
Nithin Louis.
