SIP call dropping
We have just moved from ISDN to SIP, and now we have issues that calls are dropping , busy tone and drops when transfering calls. We are using CUCM 8.6 and CUBE (2911 series router). please see attached debugs for more information. I would really appreciate if anyone could help.
Thanks a lot.
Kind Regards
Rohit.
SIP call dropping
Please let me know for which issue you captured the debug (call drop or call busy or call drop for transfer). what is the calling number, called number and time of call (tranferred destination for call transfer issue)
//Suresh Please rate all the useful posts.
SIP call dropping
Hi Suresh,
I captured these debugs yesterday for all these issues mostly call drops. Some of the  called numbers are 9512, 9534,9513. I am not sure of the time however if you look at the debug you will see the information about these numbers.
Thank You,
Kind Regards
Rohit Mangotra.
SIP call dropping
Please condense your debugs and attach again.
Please remember to rate useful posts, by clicking on the stars below.
VIP Super Bronze
SIP call dropping
I looked through all the logs and none of the called numbers were found in all the three logs..9512,9513,9534
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
SIP call dropping
Thank you all guys. It is all working now. The issue was with our Telco they had chaged the duplex and speed without letting us know. So know we changed it and is working fine now. Thanks once again for your time and support.
SIP call dropping
..That happens a lot with Telco's!  (alledgedly)
188
