SIP Call Failing CME conifg is Below
SIPGATEWAY#sh run
Building configuration...
Current configuration : 2334 bytes
version 12.4
hostname SIPGATEWAY
boot-start-marker
boot-end-marker
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.5.1 192.168.5.10
ip dhcp pool ITS
   network 192.168.5.0 255.255.255.0
   option 150 ip 192.168.5.1
   default-router 192.168.5.1
voice service voip
allow-connections h323 to sip
allow-connections sip to sip
voice class codec 1
interface FastEthernet0/0
ip address dhcp
duplex auto
speed auto
interface Serial0/0
no ip address
no fair-queue
interface FastEthernet0/1
ip address 192.168.5.1 255.255.255.0
duplex auto
speed auto
interface Serial0/1
no ip address
ip route 10.3.3.0 255.255.255.0 192.168.2.50
ip http server
no ip http secure-server
control-plane
dial-peer voice 2 voip
destination-pattern 9...........
voice-class codec 1
session protocol sipv2
session target ipv4:204.11.192.36
dtmf-relay rtp-nte
no vad
sip-ua
authentication username 17772823581 password 15160A0800337A
no remote-party-id
retry invite 2
retry register 10
sip-server ipv4:204.11.192.39
telephony-service
max-ephones 10
max-dn 10
ip source-address 192.168.5.1 port 2000
auto assign 1 to 10
--More--
*Mar  8 05:33:50.732: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed sta create cnf-files version-stamp Jan 01 2002 00:00:00
dialplan-pattern 1 7705774... extension-length 4 extension-pattern 500.
max-conferences 4 gain -6
transfer-system full-consult
ephone-dn  1  dual-line
number 5001
ephone-dn  2  dual-line
number 5002
ephone-dn  3  dual-line
number 5003
ephone-dn  4  dual-line
number 5004
ephone-dn  5  dual-line
number 5005
ephone-dn  6  dual-line
number 5006
ephone-dn  7  dual-line
number 5007
ephone-dn  8  dual-line
number 5008
ephone-dn  9  dual-line
number 5009
ephone-dn  10  dual-line
number 5010
ephone  1
mac-address 000F.34EC.C959
type 7940
button  1:1
ephone  2
ephone  3
ephone  4
ephone  5
ephone  6
ephone  7
ephone  8
ephone  9
ephone  10
line con 0
line aux 0
line vty 0 4
end
*Mar  8 06:37:10.576: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:917771234567@204.11.192.36:5060 SIP/2.0
Via: SIP/2.0/UDP  192.168.5.1:5060;branch=z9hG4bKA42497
From: <sip:7705774..1@192.168.5.1>;tag=25782450-1026
To: <sip:917771234567@204.11.192.36>
Date: Fri, 08 Mar 2002 06:37:10 GMT
Call-ID: C09FFAFF-319511D6-80B8A7A1-2DFA084@192.168.5.1
Supported: 100rel,timer,replaces
Min-SE:  1800
Cisco-Guid: 3204589746-831853014-2159388577-48210052
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, COMET, REFER, SUBSCRIBE, NOTIFY, INFO, UPDATE, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1015569430
Contact: <sip:7705774..1@192.168.5.1:5060>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Length: 266
v=0
o=CiscoSystemsSIP-GW-UserAgent 2974 638 IN IP4 192.168.5.1
s=SIP Call
c=IN IP4 192.168.5.1
t=0 0
m=audio 16526 RTP/AVP 18 101
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
*Mar  8 06:37:11.072: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Fri, 08 Mar 2002 06:37:11 GMT
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1015569431
Expires: 180
Content-Length: 266
v=0
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
*Mar  8 06:37:12.072: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Fri, 08 Mar 2002 06:37:12 GMT
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1015569432
Expires: 180
Content-Length: 266
v=0
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
520: //35/240C4CEF8052/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 84198CB4
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
Re: SIP Call Failing CME config are Below
Check your NAT device, as router never receives a reply.
as per your sip invite sent:
Sent:
looks that this is sent to a routeable IP 204.11.192.36 on the internet so you will need to include a source routable address. The one you are sending is private and more than likely your SIP provider will not reply properly:
I see no public addresses within the router so you need an interface with a public address or NAT...
let me know if it helps
Efrain
Re: SIP Call Failing Debug and CME conifg are Below
Take "debug ccsip message" ONLY and post relevant configuration ONLY.
Excessive verbosity doesn't help diagnising.
Should the 7705774... be the number the SIP Provider gave me? I actually created the 770number myself. I also deleted the debug CCSIP All info.
Sent:
Efrain
Thanks for your help but, my CME router is behind a another firewall. In performing some tests. I found out that the firewall was not passing the traffic properly. Everything is working fine now.
292
