SIP call from ITSP to ITSP failing
hi,
I have a setup of business edition 6000 9.x. There is h323 link between CUCM to GW (2911). and GW is connected to ITSP via SIP Trunk. The outgoing calls from IP phones are successful. But when i dial from my mobile to ip phone, the phone rings but when i attend the call, there is no voice and after some time the call gets disconnected. I looked up the GW traces and found the cause code cause Q.850;cause=47. I also searched this error and found out that there is problem with codec negotiation. I removed codec related command in dial peer. I also checked"mtp required" checkbox (and assign MRGL (software MTP) to Phones and GW) but both incoming and outgoing calls were failing. I also tried changing the Trunk b/w CUCM and GW from H323 to SIP but both incoming and outgoing calls were failing. any ideas??. find the attached config of router and sip trace of GW.
following queries are just to clear my mind.
1. In case of SIP. ITSP dont know my inside network subnet but still the calls are successfull because GW acts as a Proxy/MTP and accepts the request from  CUCM and reintiate it to ITSP because of which ITSP dont have to know the IP address/network of CUCM/IP Phones. Can we do it with H323?
The destination number is 22004603? right ?
From the trace, if you see then the call received from ITSP (I think it's Huawei MsoftX3000 server) carries list of codec with primary of G711alaw and under your dial-peer pointing towards CUCM has default codec of G729r8, due to which codec negotiation fails.
The dial-peer which is pointing to your CUCM is 601. Please try below
dial-peer voice 601 voip
voice-class codec 1
Regards, Nishant Savalia
yes...desitination is 22004603 which is defined as External phone number mask on ip phone.. let me try it and will come back to you
hi ,
I tried but still the same error.
Jul  8 12:38:47.300: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:22004601@10.240.55.74:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.230.0.26:5060;branch=z9hG4bKnoj8ebleecevobvuix7unhkoe
Call-ID: SBC62482c8e1dd35882b0e5e84b0f560c95@SoftX3000
To: <22004601>
CSeq: 1 INVITE
Allow: INVITE,ACK,OPTIONS,BYE,CANCEL,REGISTER,INFO,PRACK,SUBSCRIBE,NOTIFY,UPDATE,MESSAGE,REFER
Max-Forwards: 70
Supported: 100rel,timer
User-Agent: Huawei SoftX3000 V300R601
Session-Expires: 300
Min-SE: 90
Contact: <99103998>
Content-Length: 366
Content-Type: application/sdp
v=0
o=HuaweiSoftX3000 141950 141950 IN IP4 10.230.0.26
s=Sip Call
c=IN IP4 10.230.0.26
t=0 0
m=audio 16994 RTP/AVP 8 0 18 4 2 98 98 98
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=rtpmap:4 G723/8000
a=rtpmap:2 G726-32/8000
a=rtpmap:98 G726-40/8000
a=rtpmap:98 G726-32/8000
a=rtpmap:98 G726-24/8000
a=ptime:20
a=fmtp:18 annexb=no
Jul  8 12:38:47.308: //39893/2B10CE559E31/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <22004601>
Date: Mon, 08 Jul 2013 12:38:47 GMT
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.2.4.M3
Content-Length: 0
Jul  8 12:38:47.376: //39893/2B10CE559E31/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <22004601>;tag=623922C-1B23
CSeq: 1 INVITE
Require: 100rel
RSeq: 7815
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Remote-Party-ID: <601>;party=called;screen=no;privacy=off
Contact: <22004601>
Content-Length: 0
Jul  8 12:38:47.416: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
PRACK sip:22004601@10.240.55.74:5060 SIP/2.0
Via: SIP/2.0/UDP 10.230.0.26:5060;branch=z9hG4bKlkiikvvulxknyxclbuvluchli
CSeq: 2 PRACK
Max-Forwards: 70
RAck: 7815 1 INVITE
Content-Length: 0
Jul  8 12:38:47.416: //39893/2B10CE559E31/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 2 PRACK
Content-Length: 0
Jul  8 12:38:49.396: //39893/2B10CE559E31/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Contact: <22004601>
Supported: replaces
Supported: sdp-anat
Require: timer
Session-Expires:  300;refresher=uac
Supported: timer
Content-Disposition: session;handling=required
Content-Length: 214
v=0
o=CiscoSystemsSIP-GW-UserAgent 7988 3094 IN IP4 10.240.55.74
s=SIP Call
c=IN IP4 10.240.55.74
t=0 0
m=audio 17448 RTP/AVP 18
a=fmtp:18 annexb=no
a=ptime:20
Jul  8 12:38:49.648: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.0.26:5060;branch=z9hG4bKevvjeibcukkohyijeo7cueiil
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
Jul  8 12:38:52.724: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:10.240.55.74:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.230.0.26:5060;branch=z9hG4bKieihbiyho87vbujuocvbkio8k
Call-ID: 8olhbbkhh8ixyboojxnxliby77ciixoh@SE2000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 12:38:52.724: //39895/2E4C70EA9E37/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=623A710-268B
Date: Mon, 08 Jul 2013 12:38:52 GMT
CSeq: 1 OPTIONS
Accept: application/sdp
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Content-Length: 370
v=0
o=CiscoSystemsSIP-GW-UserAgent 3095 612 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15
m=image 0 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:9600
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
Jul  8 12:38:52.780: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.16.26:5060;branch=z9hG4bK8xvlelnoykylvu8jhhnv8cove
Call-ID: vbk7eoclcnjinhilihl7ejvvill7vh7b@SE2000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 12:38:52.784: //39896/2E54FC4A9E38/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=623A748-2547
CSeq: 1 OPTIONS
Content-Length: 370
v=0
o=CiscoSystemsSIP-GW-UserAgent 5830 239 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 12:38:52.916: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.0.26:5060;branch=z9hG4bKhubuouvkyjyujlkklnjuxucbi
Call-ID: SBC91dd16cdc2fd713b34f8f66d39fc5aa4@SoftX3000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 12:38:52.920: //39897/2E69BC949E39/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=623A7D0-2034
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 4806 4534 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 12:38:53.256: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.16.26:5060;branch=z9hG4bKcxnjlvvjvjlceieoux8nhbvob
Call-ID: SBCd2b4f3a5b43db78d0cf32e9804268542@SoftX3000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 12:38:53.260: //39898/2E9D9F049E3A/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=623A924-14AC
Date: Mon, 08 Jul 2013 12:38:53 GMT
CSeq: 1 OPTIONS
Content-Length: 370
v=0
o=CiscoSystemsSIP-GW-UserAgent 791 9913 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 12:38:59.416: //39893/2B10CE559E31/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:99103998@10.230.0.26:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.240.55.74:5060;branch=z9hG4bK3112117
To: <99103998>;tag=8ff51c0f-CC-25
Date: Mon, 08 Jul 2013 12:38:49 GMT
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M3
Max-Forwards: 70
Timestamp: 1373287139
CSeq: 101 BYE
Reason: Q.850;cause=47
P-RTP-Stat: PS=0,OS=0,PR=491,OR=9820,PL=0,JI=0,LA=0,DU=10
Content-Length: 0
Jul  8 12:38:59.468: //39893/2B10CE559E31/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.240.55.74:5060;branch=z9hG4bK3112117;rport=56268
CSeq: 101 BYE
Content-Length: 0
Please check which in and out dial-peers are selected. Because trace you've got is still the same as before.
Also, provide the modified configuration of gateway.
I think the incoming dial-peer being matched is "10".
Try below:
dial-peer voice 10 voip
translation-profile incoming PSTN-NAWRUS-IN
destination-pattern .T
session protocol sipv2
session target ipv4:10.230.0.26
codec g711alaw
OR
voice-class codec 1
hi,
i am making cal from ITSP SIP Trunk (calling number:99103998; incoming dial-peer 10)...and called number is cisco ip phone (Ex: 601  EPNM:22004601: dial-peer 600). i added voice codec 1 on all dial-peers command but still no luck.
voip dialpeer default debugging is on
oosc-ucs-gw#
Jul  8 15:00:22.740: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=SBC, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=NO_MATCH(-1) After All Match Rules Attempt
Jul  8 15:00:22.740: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
Jul  8 15:00:22.740: //-1/F2BDFBE3AF5E/DPM/dpAssociateIncomingPeerCore:
Jul  8 15:00:22.740: //-1/F2BDFBE3AF5E/DPM/dpMatchSafModulePlugin:
Jul  8 15:00:22.768: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x0,
Jul  8 15:00:22.768: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul  8 15:00:22.768: //-1/F2C24194AF5F/DPM/dpAssociateIncomingPeerCore:
Jul  8 15:00:22.768: //-1/F2C24194AF5F/DPM/dpMatchSafModulePlugin:
Jul  8 15:00:22.864: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Jul  8 15:00:22.864: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul  8 15:00:22.864: //-1/F2D0E71CAF60/DPM/dpAssociateIncomingPeerCore:
Jul  8 15:00:22.864: //-1/F2D0E71CAF60/DPM/dpMatchSafModulePlugin:
Jul  8 15:00:24.604: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=22004601, Called Number=22004601, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=22004601
   Result=Success(0) after DP_MATCH_DEST
Jul  8 15:00:24.604: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=22004601, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Jul  8 15:00:24.604: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=601
     2: Dial-peer Tag=10
Jul  8 15:00:24.604: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=99103998, Called Number=, Voice-Interface=0x0,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=10
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Jul  8 15:00:24.604: //-1/F3D9CC72AF61/DPM/dpAssociateIncomingPeerCore:
   Calling Number=99103998, Called Number=22004601, Voice-Interface=0x0,
Jul  8 15:00:24.604: //-1/F3D9CC72AF61/DPM/dpMatchSafModulePlugin:
Jul  8 15:00:24.608: //-1/F3D9CC72AF61/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=601, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=601
Jul  8 15:00:24.608: //-1/F3D9CC72AF61/DPM/dpMatchSafModulePlugin:
   dialstring=601, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Jul  8 15:00:24.608: //-1/F3D9CC72AF61/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=600
     2: Dial-peer Tag=10
   Result=SUCCESS(0)
     2: Dial-peer Tag=10
Jul  8 15:00:24.608: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=601, Called Number=601, Peer Info Type=DIALPEER_INFO_SPEECH
Jul  8 15:00:24.608: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul  8 15:00:24.608: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     2: Dial-peer Tag=10
Jul  8 15:00:24.608: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=601, Called Number=, Voice-Interface=0x0,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=600
   Result=SUCCESS(0)
     2: Dial-peer Tag=10
   dialstring=601, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
   Result=SUCCESS(0)
     2: Dial-peer Tag=10
Jul  8 15:00:24.668: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jul  8 15:00:24.668: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul  8 15:00:24.668: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     2: Dial-peer Tag=10
   Calling Number=, Called Number=99103998, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=99103998
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
Jul  8 15:00:24.668: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
   Result=SUCCESS(0)
     2: Dial-peer Tag=10
Jul  8 15:00:26.220: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jul  8 15:00:26.220: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jul  8 15:00:26.220: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
Jul  8 15:00:26.220: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
   Result=SUCCESS(0)
     2: Dial-peer Tag=10
Jul  8 15:00:26.224: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
oosc-ucs-gw#
   Result=SUCCESS(0)
     2: Dial-peer Tag=10
   Result=SUCCESS(0)
     2: Dial-peer Tag=10
   Result=SUCCESS(0)
     2: Dial-peer Tag=10
   Result=SUCCESS(0)
     2: Dial-peer Tag=10
   Result=SUCCESS(0)
     2: Dial-peer Tag=10
   Result=SUCCESS(0)
     2: Dial-peer Tag=10
   Result=SUCCESS(0)
     2: Dial-peer Tag=10
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
   Result=SUCCESS(0)
     2: Dial-peer Tag=10
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
   Result=SUCCESS(0)
     2: Dial-peer Tag=10
Please uncheck "Wait for Far End H.245 Terminal Capability Set" in CUCM Gateway configuration.
And do the following task again:-
1). Apply voice-class codec 1 under dial-peer 600, 601, 10 ( make sure g711alaw is the first priority)
2). Make call.
3). Take SIP trace and detailed trace from RTMT.
4). Share gateway configuration.
Re: SIP call from Office to ITSP failing
hi ,
i unchecked "Wait for Far End H.245 Terminal Capability Set" from the begining.
1. I applied voice class codec 1 to all the dial peers with g711alaw as preferred. when i called from ip phone to mobile, the phone was ringing but there was no voice (when i remove voice-class codec 1 command then the call from ip phone to mobile was good) but call was not disconnecting. when i called from mobile to ip phone. the result was same i.e there was no voice and call disconnected after some time. see the attached file.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.07.08 19:57:22 =~=~=~=~=~=~=~=~=~=~=~=
C
OOSC
User Access Verification
Username: admin
Password:
oosc-ucs-gw>en
Password:
oosc-ucs-gw#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
oosc-ucs-gw(config)#voice clas                               boic            voic
oosc-ucs-gw(config)#voice-c       dial
oosc-ucs-gw(config)#voice dial-p
oosc-ucs-gw(config)#voice dial-pe
oosc-ucs-gw(config)#voice dial-pev   e
oosc-ucs-gw(config)#voice dial-pee                                              dal      ial-p
oosc-ucs-gw(config)#dial-peer voi
oosc-ucs-gw(config)#dial-peer voice voi
oosc-ucs-gw(config)#dial-peer voice voi         600 voi
oosc-ucs-gw(config)#dial-peer voice 600 voip
oosc-ucs-gw(config-dial-peer)#voi
oosc-ucs-gw(config-dial-peer)#voice-c
oosc-ucs-gw(config-dial-peer)#voice-class co
oosc-ucs-gw(config-dial-peer)#voice-class codec 1
oosc-ucs-gw(config-dial-peer)#exit
oosc-ucs-gw(config)#v   dial
oosc-ucs-gw(config)#dial-peer voice 601 voi
oosc-ucs-gw(config)#dial-peer voice 601 voip
oosc-ucs-gw(config-dial-peer)#xit
% Invalid input detected at '^' marker.
oosc-ucs-gw(config-dial-peer)#v    exit
oosc-ucs-gw(config)#ei      dial-pe
oosc-ucs-gw(config)#dial-peer oi
oosc-ucs-gw(config)#dial-peer oi      voi
oosc-ucs-gw(config)#dial-peer voice 10 voi
oosc-ucs-gw(config)#dial-peer voice 10 voip
oosc-ucs-gw(config-dial-peer)#e i   xit
oosc-ucs-gw(config)#exit
oosc-ucs-gw#sh run
Building configuration...
Current configuration : 4584 bytes
! Last configuration change at 19:56:15 MSCT Mon Jul 8 2013 by admin
! NVRAM config last updated at 19:50:58 MSCT Mon Jul 8 2013 by admin
version 15.2
hostname oosc-ucs-gw
boot-start-marker
boot-end-marker
card type e1 0 0
security authentication failure rate 10 log
security passwords min-length 6
enable password P@ssw0rd
aaa new-model
--More--                           !
aaa authentication login local_auth local
aaa session-id common
clock timezone MSCT 4 0
clock calendar-valid
no network-clock-participate wic 0
no ip source-route
no ip gratuitous-arps
ip cef
ip dhcp excluded-address 10.14.4.1 10.14.4.100
ip dhcp excluded-address 10.14.4.240
ip dhcp excluded-address 10.14.4.140
--More--                           ip dhcp pool NETWORK
network 10.14.4.0 255.255.255.0
default-router 10.14.4.10
option 150 ip 10.14.4.5
dns-server 10.14.4.68 10.14.4.60
no ip bootp server
ip domain name oosc.net
login block-for 60 attempts 100 within 2
no ipv6 cef
voice-card 0
dspfarm
dsp services dspfarm
--More--                           !
voice service voip
ip address trusted list
  ipv4 10.230.0.26 255.255.255.255
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  min-se 90 session-expires 90
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
codec preference 4 g729br8
voice translation-rule 1
rule 1 /^22004\(6..\)$/ /\1/
voice translation-profile PSTN-NAWRUS-IN
translate called 1
license udi pid CISCO2911/K9 sn FCZ171561NR
hw-module pvdm 0/0
username admin password 0 randme
redundancy
controller E1 0/0/0
--More--                           !
ip ssh time-out 60
ip ssh authentication-retries 2
interface Embedded-Service-Engine0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
shutdown
no mop enabled
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.1
encapsulation dot1Q 9
ip address 10.14.4.3 255.255.255.0
no ip redirects
interface GigabitEthernet0/1
ip address 10.240.55.74 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/2
description ** Link to STS Voice **
ip address 10.192.192.1 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
no mop enabled
--More--                           !
ip default-gateway 10.240.55.73
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.240.55.73
ip route 172.20.0.0 255.255.252.0 10.192.192.2
logging trap debugging
logging facility local2
dialer-list 1 protocol ip permit
control-plane
mgcp profile default
sccp local GigabitEthernet0/0.1
sccp ccm 10.14.4.5 identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register XCODE-OOSC
dspfarm profile 1 transcode
codec pass-through
codec isac
codec ilbc
codec gsmamr-nb
codec g729r8
--More--                            codec g729br8
codec g722-64
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 14
associate application SCCP
destination-pattern 6..$
session target ipv4:10.14.4.5
voice-class codec 1
dial-peer voice 500 voip
destination-pattern 1..$
session target ipv4:10.192.192.2
voice-class codec 1
destination-pattern 220046..$
voice-class codec 1
sip-ua
gatekeeper
shutdown
banner motd ^CC
OOSC ^C
--More--                           line con 0
exec-timeout 0 0
logging synchronous
login authentication local_auth
transport output telnet
line aux 0
exec-timeout 15 0
line 2
exec-timeout 15 0
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password P@ssw0rd
transport input telnet ssh
scheduler allocate 20000 1000
ntp master 5
ntp server 216.171.112.36
end
oosc-ucs-gw#
oosc-ucs-gw#
oosc-ucs-gw#
oosc-ucs-gw#deub
oosc-ucs-gw#deub      bu
oosc-ucs-gw#debug ccsip                                    u all
All possible debugging has been turned off
oosc-ucs-gw#debu            conf t
oosc-ucs-gw(config)#log
oosc-ucs-gw(config)#logg
oosc-ucs-gw(config)#logging con
oosc-ucs-gw(config)#logging console
oosc-ucs-gw(config)#t   exit
oosc-ucs-gw#et      term
oosc-ucs-gw#terminal on      mon
oosc-ucs-gw#terminal monitor
oosc-ucs-gw#terminal monitor de
oosc-ucs-gw#
oosc-ucs-gw#
oosc-ucs-gw#
oosc-ucs-gw#debu
oosc-ucs-gw#debug ccsip mes
oosc-ucs-gw#debug ccsip messages
SIP Call messages tracing is enabled
oosc-ucs-gw#
Jul  8 15:57:21.192: //45583/00CC60110400/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:99103998@10.230.0.26:5060 SIP/2.0
Via: SIP/2.0/UDP 10.240.55.74:5060;branch=z9hG4bK395C30
Remote-Party-ID: "HE Salim Macki" <22004601>;party=calling;screen=yes;privacy=off
To: <99103998>
Date: Mon, 08 Jul 2013 15:57:21 GMT
Call-ID: E84BB8FD-E71D11E2-B4F9D5D5-ED3EBC86@10.240.55.74
Min-SE:  90
Cisco-Guid: 0013393937-1642176797-0067112193-0168690792
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1373299041
Contact: <22004601>
Expires: 180
Content-Length: 0
Jul  8 15:57:21.208: //45583/00CC60110400/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.240.55.74:5060;branch=z9hG4bK395C30;rport=56268
To: <99103998>
CSeq: 101 INVITE
Content-Length: 0
Jul  8 15:57:22.260: //45583/00CC60110400/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
To: <99103998>;tag=c4f78587-CC-27
CSeq: 101 INVITE
Require: 100rel
RSeq: 1
Contact: <10.230.0.26:5060>
Content-Length: 364
v=0
o=HuaweiSoftX3000 43971 43971 IN IP4 10.230.0.26
s=Sip Call
t=0 0
m=audio 19012 RTP/AVP 8 0 18 4 2 98 98 98
a=ptime:20
a=fmtp:18 annexb=no
Jul  8 15:57:22.280: //45583/00CC60110400/SIP/Msg/ccsipDisplayMsg:
Sent:
PRACK sip:10.230.0.26:5060 SIP/2.0
Via: SIP/2.0/UDP 10.240.55.74:5060;branch=z9hG4bK3961F8
CSeq: 102 PRACK
RAck: 1 101 INVITE
Max-Forwards: 70
Content-Length: 191
v=0
o=CiscoSystemsSIP-GW-UserAgent 6743 2079 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=audio 17558 RTP/AVP 8
a=ptime:20
Jul  8 15:57:22.324: //45583/00CC60110400/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.240.55.74:5060;branch=z9hG4bK3961F8;rport=56268
CSeq: 102 PRACK
Content-Length: 0
Jul  8 15:57:22.748: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.0.26:5060;branch=z9hG4bKyhjxkccvjluyib8unhlbhlnjn
Call-ID: oboo88hyx7jnhev8jueiy8hicjuleece@SE2000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:57:22.748: //45584/E939C143B4FA/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6D96298-B2D
Date: Mon, 08 Jul 2013 15:57:22 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 8412 6759 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:57:22.896: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.16.26:5060;branch=z9hG4bKk7ijel7yculxkkn8h8i7ehjoy
Call-ID: hcunlechyj7honibyioejnob7vkibblc@SE2000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:57:22.900: //45585/E9505604B4FB/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6D9632C-11AD
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 8122 3280 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:57:25.572: //45583/00CC60110400/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Require: 100rel
RSeq: 2
Content-Length: 0
Jul  8 15:57:25.576: //45583/00CC60110400/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.240.55.74:5060;branch=z9hG4bK3974FE
CSeq: 103 PRACK
RAck: 2 101 INVITE
Max-Forwards: 70
Content-Length: 0
Jul  8 15:57:25.608: //45583/00CC60110400/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.240.55.74:5060;branch=z9hG4bK3974FE;rport=56268
CSeq: 103 PRACK
Content-Length: 0
Jul  8 15:57:28.308: //45583/00CC60110400/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Require: timer
Content-Length: 0
Jul  8 15:57:28.312: //45583/00CC60110400/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.240.55.74:5060;branch=z9hG4bK3981AC1
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Jul  8 15:57:29.656: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.0.26:5060;branch=z9hG4bKhlcxkblx7i7l7n7novvjhibox
Call-ID: SBCb5cca15b6a46b7316b26c6fc6dbe7d92@SoftX3000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:57:29.660: //45586/ED57D4C9B4FC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6D97D94-23B7
Date: Mon, 08 Jul 2013 15:57:29 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 7433 6315 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:57:30.672: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.16.26:5060;branch=z9hG4bKibilu7hbexnc8oj7cxvly8ouc
Call-ID: SBCed1711f58c4f34ce61715c28aca5568d@SoftX3000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:57:30.676: //45587/EDF378AAB4FD/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6D98190-1BE4
Date: Mon, 08 Jul 2013 15:57:30 GMT
CSeq: 1 OPTIONS
Content-Length: 369
v=0
o=CiscoSystemsSIP-GW-UserAgent 122 293 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:57:32.748: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.0.26:5060;branch=z9hG4bKnkxkivkebijikblcyun8xhv8n
Call-ID: oo8i8ixyeoykhhn7jyovcceyi7hycenk@SE2000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:57:32.748: //45588/EF2FA243B4FE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6D989A8-1532
Date: Mon, 08 Jul 2013 15:57:32 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 2892 7886 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:57:32.896: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.16.26:5060;branch=z9hG4bKxbyhveejbvekcvhune8xoovv7
Call-ID: oecxeh887hjehh8ucycjivkk88vvbeye@SE2000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:57:32.900: //45589/EF463704B4FF/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6D98A3C-F01
CSeq: 1 OPTIONS
Content-Length: 370
v=0
o=CiscoSystemsSIP-GW-UserAgent 4925 836 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:57:38.904: //45583/00CC60110400/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:10.230.0.26:5060 SIP/2.0
Via: SIP/2.0/UDP 10.240.55.74:5060;branch=z9hG4bK39912E
Max-Forwards: 70
Timestamp: 1373299058
CSeq: 104 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=529,OS=84640,PR=826,OR=132160,PL=0,JI=0,LA=0,DU=10
Content-Length: 0
Jul  8 15:57:38.956: //45583/00CC60110400/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.240.55.74:5060;branch=z9hG4bK39912E;rport=56268
CSeq: 104 BYE
Content-Length: 0
Jul  8 15:57:39.708: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.0.26:5060;branch=z9hG4bKcnhh77hoovuoxkoecncxxbuvx
Call-ID: SBC2f0d97b161d66bd818c6002c4e3861b4@SoftX3000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:57:39.708: //45590/F355A502B500/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6D9A4D8-26C5
Date: Mon, 08 Jul 2013 15:57:39 GMT
CSeq: 1 OPTIONS
Content-Length: 370
v=0
o=CiscoSystemsSIP-GW-UserAgent 695 1073 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:57:40.740: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.16.26:5060;branch=z9hG4bKejn8x8lvjhvyhn7cucee7xuju
Call-ID: SBCe1e6e3a6d9ae0f016c3eb20b1ed9e690@SoftX3000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:57:40.744: //45591/F3F31D5AB501/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6D9A8E0-88E
Date: Mon, 08 Jul 2013 15:57:40 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 7760 6183 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:57:42.748: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.0.26:5060;branch=z9hG4bKubuxvb7ecjnkeeeloixiekjn7
Call-ID: bjehhlciyioyuhxknixuov7cexlie7j8@SE2000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:57:42.748: //45592/F5258343B502/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6D9B0B8-994
Date: Mon, 08 Jul 2013 15:57:42 GMT
CSeq: 1 OPTIONS
Content-Length: 370
v=0
o=CiscoSystemsSIP-GW-UserAgent 974 4513 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:57:42.896: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.16.26:5060;branch=z9hG4bKcxoknojeucbekyccubb77heku
Call-ID: xuuejb88nnjju8yvvvibuykyy87eyjno@SE2000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:57:42.900: //45593/F53C1804B503/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6D9B150-18FD
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 1519 7473 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:57:49.772: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.0.26:5060;branch=z9hG4bKlxjevkoj8uvonyonnniyeikbi
Call-ID: SBCb23d247f2ce9c801a867754c1807b6dd@SoftX3000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:57:49.776: //45594/F95549B2B504/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6D9CC28-18EC
Date: Mon, 08 Jul 2013 15:57:49 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 2089 1045 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:57:50.808: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.16.26:5060;branch=z9hG4bKnlyj8oxxuvijikvubchxo7e8l
Call-ID: SBC70da30af4142a50656642d678a0e64d7@SoftX3000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:57:50.808: //45595/F9F35ECBB505/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6D9D034-2592
Date: Mon, 08 Jul 2013 15:57:50 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 1007 6867 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:57:51.560: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.0.26:5060;branch=z9hG4bKxnbi7biiyyivhnivijocych8y
Call-ID: SBC2a02c0320f06867921fb36feb04baccb@SoftX3000
To: <22004601>
CSeq: 1 INVITE
Max-Forwards: 70
Min-SE: 90
Contact: <99103998>
Content-Length: 366
v=0
o=HuaweiSoftX3000 164780 164780 IN IP4 10.230.0.26
s=Sip Call
t=0 0
m=audio 19026 RTP/AVP 8 0 18 4 2 98 98 98
a=ptime:20
a=fmtp:18 annexb=no
Jul  8 15:57:51.564: //45596/FA661E40B506/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <22004601>
Date: Mon, 08 Jul 2013 15:57:51 GMT
CSeq: 1 INVITE
Content-Length: 0
Jul  8 15:57:51.628: //45596/FA661E40B506/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <22004601>;tag=6D9D368-1DED
CSeq: 1 INVITE
Require: 100rel
RSeq: 3588
Remote-Party-ID: "HE Salim Macki" <601>;party=called;screen=no;privacy=off
Contact: <22004601>
Content-Length: 0
Jul  8 15:57:51.672: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.0.26:5060;branch=z9hG4bKhulxbl777xvnve7llui78ynvo
CSeq: 2 PRACK
Max-Forwards: 70
RAck: 3588 1 INVITE
Content-Length: 0
Jul  8 15:57:51.676: //45596/FA661E40B506/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 2 PRACK
Content-Length: 0
Jul  8 15:57:52.748: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.0.26:5060;branch=z9hG4bKhnceux7hkyvjcjccl7ivvkyjc
Call-ID: nnyyhvijcnbvn7hnn7ejyeyckvbkunii@SE2000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:57:52.748: //45598/FB1B6443B50C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6D9D7C8-1213
Date: Mon, 08 Jul 2013 15:57:52 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 8824 1045 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:57:52.896: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.16.26:5060;branch=z9hG4bK88jn88vvieyxux77ovohbbo7e
Call-ID: olhhjvivvyexhcoch8nvxkuy8jje7bby@SE2000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:57:52.900: //45599/FB31F904B50D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6D9D860-1C0A
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 4181 6357 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:57:53.176: //45596/FA661E40B506/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Contact: <22004601>
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 191
v=0
o=CiscoSystemsSIP-GW-UserAgent 4562 1605 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=audio 17560 RTP/AVP 8
a=ptime:20
Jul  8 15:57:53.424: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.0.26:5060;branch=z9hG4bKcyl7noyo88v8xllejnheekv8n
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
Jul  8 15:57:59.808: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.0.26:5060;branch=z9hG4bKouunxoxobbkijx88kiibbeee8
Call-ID: SBC8c5ba2d3cf3140a18c2244888faead8d@SoftX3000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:57:59.808: //45600/FF50A94BB50E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6D9F35C-236
Date: Mon, 08 Jul 2013 15:57:59 GMT
CSeq: 1 OPTIONS
Content-Length: 370
v=0
o=CiscoSystemsSIP-GW-UserAgent 423 1874 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:58:00.876: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.16.26:5060;branch=z9hG4bKxlkxexuikvnkb7lu7e8ecknvu
Call-ID: SBC347ae6032d4fb7c8f639ff7d780dee05@SoftX3000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:58:00.876: //45601/FFF39FA4B50F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6D9F788-2439
Date: Mon, 08 Jul 2013 15:58:00 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 4570 3315 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:58:02.748: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.0.26:5060;branch=z9hG4bKull88hbbjvxnxhyyvvbohlvcv
Call-ID: oicyblookululohbkue7ykxi77xn7k78@SE2000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:58:02.748: //45602/01114543B510/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6D9FED8-2F
Date: Mon, 08 Jul 2013 15:58:02 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 4866 7334 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:58:02.896: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.16.26:5060;branch=z9hG4bKo8uonjykekobbkheelvcnnn88
Call-ID: hhbuxkjlcuohniy7n7icxvojeyjuiu87@SE2000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:58:02.900: //45603/0128762CB511/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6D9FF70-B59
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 3882 5147 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:58:03.196: //45596/FA661E40B506/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.240.55.74:5060;branch=z9hG4bK39A1BC5
To: <99103998>;tag=d671bb2a-CC-23
Date: Mon, 08 Jul 2013 15:57:53 GMT
Max-Forwards: 70
Timestamp: 1373299083
CSeq: 101 BYE
P-RTP-Stat: PS=0,OS=0,PR=491,OR=78560,PL=0,JI=0,LA=0,DU=10
Content-Length: 0
Jul  8 15:58:03.240: //45596/FA661E40B506/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.240.55.74:5060;branch=z9hG4bK39A1BC5;rport=56268
CSeq: 101 BYE
Content-Length: 0
Jul  8 15:58:06.884: //45605/8040332C0500/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.240.55.74:5060;branch=z9hG4bK39B19E
To: <99103998>
Date: Mon, 08 Jul 2013 15:58:06 GMT
Call-ID: 3885EF4-E71E11E2-B514D5D5-ED3EBC86@10.240.55.74
Min-SE:  90
Cisco-Guid: 2151691052-2397151517-0083889665-0168690792
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1373299086
Contact: <22004601>
Expires: 180
Content-Length: 0
Jul  8 15:58:06.908: //45605/8040332C0500/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.240.55.74:5060;branch=z9hG4bK39B19E;rport=56268
To: <99103998>
CSeq: 101 INVITE
Content-Length: 0
Jul  8 15:58:08.040: //45605/8040332C0500/SIP/Msg/ccsipDisplayMsg:
Received:
To: <99103998>;tag=26a257c6-CC-22
CSeq: 101 INVITE
Require: 100rel
RSeq: 1
Content-Length: 366
v=0
o=HuaweiSoftX3000 189352 189352 IN IP4 10.230.0.26
s=Sip Call
t=0 0
m=audio 19042 RTP/AVP 8 0 18 4 2 98 98 98
a=ptime:20
a=fmtp:18 annexb=no
Jul  8 15:58:08.068: //45605/8040332C0500/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.240.55.74:5060;branch=z9hG4bK39CBDF
CSeq: 102 PRACK
RAck: 1 101 INVITE
Max-Forwards: 70
Content-Length: 188
v=0
o=CiscoSystemsSIP-GW-UserAgent 3 5799 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=audio 17566 RTP/AVP 8
a=ptime:20
Jul  8 15:58:08.124: //45605/8040332C0500/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.240.55.74:5060;branch=z9hG4bK39CBDF;rport=56268
CSeq: 102 PRACK
Content-Length: 0
Jul  8 15:58:09.856: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.0.26:5060;branch=z9hG4bKoybje8nlecb8vcivub77ui8xi
Call-ID: SBC836c72b8defd8fd809f2334cd97ac312@SoftX3000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:58:09.860: //45606/054DDCC3B515/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6DA1A9C-2127
Date: Mon, 08 Jul 2013 15:58:09 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 1193 2095 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:58:10.940: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.16.26:5060;branch=z9hG4bKjuv7bhvcivycvvyhlbxu7ylhx
Call-ID: SBC28a5f2a368b95dad798031a8c69788a5@SoftX3000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:58:10.944: //45607/05F34454B516/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6DA1ED8-A45
Date: Mon, 08 Jul 2013 15:58:10 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 5019 2740 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:58:11.624: //45605/8040332C0500/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Require: 100rel
RSeq: 2
Content-Length: 0
Sent:
Via: SIP/2.0/UDP 10.240.55.74:5060;branch=z9hG4bK39D3CE
CSeq: 103 PRACK
RAck: 2 101 INVITE
Max-Forwards: 70
Content-Length: 0
Jul  8 15:58:11.656: //45605/8040332C0500/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.240.55.74:5060;branch=z9hG4bK39D3CE;rport=56268
CSeq: 103 PRACK
Content-Length: 0
Jul  8 15:58:12.748: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.0.26:5060;branch=z9hG4bK8lnlo7kii8veyyb8vkhujhyyy
Call-ID: beiyikbbcb8ux8xyoejlhcjlli8keue7@SE2000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:58:12.748: //45608/07072643B517/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6DA25E8-1B22
Date: Mon, 08 Jul 2013 15:58:12 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 7000 9163 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:58:12.896: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.16.26:5060;branch=z9hG4bKobexjcnuyjlvvjjyx7cbyebhh
Call-ID: knkiixbiucnjy8nhhvu8cyo8ncj7xxle@SE2000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:58:12.900: //45609/071E572CB518/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6DA2680-A29
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 1213 1558 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:58:13.808: //45605/8040332C0500/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Require: timer
Content-Length: 0
Jul  8 15:58:13.812: //45605/8040332C0500/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.240.55.74:5060;branch=z9hG4bK39E21D3
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Jul  8 15:58:19.908: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.0.26:5060;branch=z9hG4bKxnyixilu7ec8hnejvbijxijc7
Call-ID: SBC9bd076d27dc7ce1ee38f87a998ef1b84@SoftX3000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:58:19.908: //45610/0B4BACFCB519/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6DA41E0-60F
Date: Mon, 08 Jul 2013 15:58:19 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 8745 6842 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:58:21.008: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.16.26:5060;branch=z9hG4bKc8yibokkvox8vc8ecibelvncj
Call-ID: SBCbbe998fc5632e837a8d416eb2c05e458@SoftX3000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:58:21.008: //45611/0BF387CAB51A/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6DA462C-15D9
Date: Mon, 08 Jul 2013 15:58:21 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 1627 4835 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:58:22.748: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.0.26:5060;branch=z9hG4bKvyohxyyv78yyl7ynoh87nvk8u
Call-ID: yicy8cno7eeojxylnycouhnhhn8jlovc@SE2000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:58:22.748: //45612/0CFD06AAB51B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6DA4CF8-440
Date: Mon, 08 Jul 2013 15:58:22 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 9205 7063 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:58:22.896: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.16.26:5060;branch=z9hG4bKuunixo8vcuuvujkkvo7nvcvcb
Call-ID: kvovyoxive77ebixjbhnbu7lkeijjje7@SE2000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:58:22.900: //45613/0D14382CB51C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6DA4D90-1D6A
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 1501 7781 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:58:29.956: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.0.26:5060;branch=z9hG4bKuioiee7nkebuhbykv7v7iiyxo
Call-ID: SBC74a31d76e35fad84f860654300b09e65@SoftX3000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:58:29.960: //45614/1148E10DB51D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6DA6920-217E
Date: Mon, 08 Jul 2013 15:58:29 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 5430 2840 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:58:31.076: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.16.26:5060;branch=z9hG4bKhbe8eeoexyvhkkh7coyn7ykkk
Call-ID: SBC178ce616b864c765690662af385ef680@SoftX3000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:58:31.076: //45615/11F3C8A3B51E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6DA6D80-15D0
Date: Mon, 08 Jul 2013 15:58:31 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 4494 8759 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:58:32.748: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.0.26:5060;branch=z9hG4bKnvjhkyhcenvv8xxbn7ebhc8ve
Call-ID: yluo8blixeyhbovxueebkuhvnovu7xen@SE2000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:58:32.748: //45616/12F2E7AAB51F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6DA7408-17C
Date: Mon, 08 Jul 2013 15:58:32 GMT
CSeq: 1 OPTIONS
Content-Length: 370
v=0
o=CiscoSystemsSIP-GW-UserAgent 711 4468 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul  8 15:58:32.896: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.16.26:5060;branch=z9hG4bKeexxlio7uy8ocj87llljhv8il
Call-ID: vlbvvk88e8uchyiobnxchbxenkykcuik@SE2000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:58:32.900: //45617/130A192CB520/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6DA74A0-ECD
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 3525 2832 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
u a
Jul  8 15:58:40.008: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.230.0.26:5060;branch=z9hG4bK8ucnjyjyolcxjvooeeo7bv7xy
Call-ID: SBCffa19b48d13325d2cd6bad84702289a9@SoftX3000
To: <10.240.55.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul  8 15:58:40.008: //45618/1746B34AB521/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.240.55.74>;tag=6DA9064-2406
Date: Mon, 08 Jul 2013 15:58:40 GMT
CSeq: 1 OPTIONS
Supported: 100rel,timer,rell
oosc-ucs-gw#source-priority,replaces,sdp-anat
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 4175 9305 IN IP4 10.240.55.74
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Actually it should have worked.
Can you confirm from where the call is being released after the latest modification? I think CUCM released the call...
Do make a test call again and Please collect detail sdi trace and also debug h225 asn1 from gateway and do share it.
Also, let me know the device pool & MRGL setting of gateway in CUCM and codec applied in region of that device pool.
After that try the following thing:-
1). remove all the codec priorities from all the dial-peers
2). Ask the remote end to send the codec first priority as G729r8 (i.e. RTP = 18) and then test the call.
3). Collect traces of all evidences (i.e. SIP, detail sdi trace from rtmt, debug h225 asn1 of terminating gateway).
hi,
issue resolved...cucm uses slow start and cube uses fast start..so on cucm i configured on h323 gatway "allow inbound fast start" and it started working..thanx nishant
Great!!!
hi,
but i dont know why..when i assign codec class 1 to dial peer pointing to cucm.. there is no voice..though within region call is g711 and also i set the service paramter for interegion codec to g711. I am facing issue of dtmf as well..when ever i am calling an ivr and pressing digits.. the digits are not accepted by ivr system. even though i entered dtmf-relay rtp-net h245-signal h245-alphanumeric to each dial peer
Can you confirm which dial-peer is being selected while making an outgoing call from your side?
And try by just giving "dtmf-relay h245-alphanumeric" to that incoming dial-peer which is being selected.
hi,
for outgoing..dial-peer 10 is selected (sip-dial-peer).
Hey sorry,
but i mean that which incoming dial-peer is being selected when call comes from CUCM to your gateway.
hi,
incoming dial peer for outoging call is 601
Please try by applying below to that dial-peer and check
incoming called number .
All problems you've been facing are common on SIP-to-H323 call flows, you may want to use SIP-to-SIP CUBE configuration, it will overcome the DTMF problem and more.
Here you're having issues becuase H323 uses OOB DTMF method, and SIP uses RFC2833 (most of the time), that is like a hibrid DMTF, it is a RTP payload that is send to the ITSP, if you were using SIP-to-SIP you wouldn't have any issues.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
602
