Hi Jason,
Is the call through the SIP trunk using the MTP resource on the callmanager that went down ? Basically once the media is set up it will be streamed directly between the endpoints , but if an MTP is incolved it goes through that MTP and if it is on the same CUCM then your call will drop.
Lakshmi
