SIP call to CUE failing from External Number
scottsassin
I have a CME and CUE using SIP as the PSTN.  I have it configured to receive and place calls with no problem.  When I call the voicemail or Auto attendant from the inside phone, it works fine.  When I receive a call from the outsdie, the transfer to the CUE fails.
I am attaching a copy of the full configuration of the CME and CUE.  Please let me know if I have a loop somewhere or what could be the issue.
I found thet you got diconnect cause=47  , and this is because codec mismtatch . Can you try the following:-
voice class codec 10
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
dial-peer voice 80 voip
no codec g711ulaw
voice-class codec 10
please rate all useful information
7 Replies 7
islam.kamal
Level 10
Level 10
hi
Can you try the below commands on CME?.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
telephony-service
transfer-system full-consult
transfer-pattern .T
Please rate all useful information
All of the commends above are already part of the configuration.
HI
I am so sorry , i didnot check the attached files . Can you share the output debugs?.
Router#debug voip ccapi inout
Router # debug ccsip messages
040568: Feb 15 15:01:53.683 EST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:7875239398@192.254.106.46 SIP/2.0
Via: SIP/2.0/UDP 75.98.35.150:5060;branch=z9hG4bKyDr4Z268jbNptIfZAB6EC5
Call-ID: 20140215200213000075@nysas.vintalk.com
Contact: <13053892158>
CSeq: 201 INVITE
From: "SASSIN SCOTT" <>13053892158@nysas.vintalk.com>;tag=yDr4Z268jbNptIfZAB6EC5
Max-Forwards: 20
To: <7875239398>
Date: Sat, 15 Feb 2014 20:02:13 GMT
Server: NetSapiens SiPBx 1-1218
X-Nortel-Profile: DEFAULT
Content-Type: application/sdp
Content-Length: 277
v=0
o=Acme_UAS 1392494533 1392494533 IN IP4 75.98.35.150
s=SIP Media Capabilities
c=IN IP4 75.98.35.150
t=0 0
m=audio 24238 RTP/AVP 0 18 101
a=rtpmap:101 telephone-event/8000
a=rtpmap:0 pcmu/8000
a=rtpmap:18 g729/8000
a=fmtp:101 0-15
a=ptime:20
a=fmtp:18 annexb=no
040569: Feb 15 15:01:53.683 EST: //-1/D97D602C9F5B/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=13053892158
   ----- ccCallInfo IE subfields -----
   cisco-ani=13053892158
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=7875239398
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
040570: Feb 15 15:01:53.687 EST: //-1/D97D602C9F5B/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x22CD9160, Call Info(
   Calling Number=13053892158,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=7875239398(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=1, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=2709
040571: Feb 15 15:01:53.687 EST: //-1/D97D602C9F5B/CCAPI/ccCheckClipClir:
   In: Calling Number=13053892158(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
040572: Feb 15 15:01:53.687 EST: //-1/D97D602C9F5B/CCAPI/ccCheckClipClir:
   Out: Calling Number=13053892158(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
040573: Feb 15 15:01:53.687 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040574: Feb 15 15:01:53.687 EST: :cc_get_feature_vsa malloc success
040575: Feb 15 15:01:53.687 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040576: Feb 15 15:01:53.687 EST:  cc_get_feature_vsa count is 1
040577: Feb 15 15:01:53.687 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040578: Feb 15 15:01:53.687 EST: :FEATURE_VSA attributes are: feature_name:0,feature_time:1037486800,feature_id:3167
040579: Feb 15 15:01:53.687 EST: //2709/D97D602C9F5B/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=13053892158(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=7875239398(TON=Unknown, NPI=Unknown))
040580: Feb 15 15:01:53.687 EST: //2709/D97D602C9F5B/CCAPI/cc_process_call_setup_ind:
   Event=0x22EEFAE8
040581: Feb 15 15:01:53.687 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 7875239398
040582: Feb 15 15:01:53.687 EST: //2709/D97D602C9F5B/CCAPI/ccCallSetContext:
   Context=0x2101CB94
040583: Feb 15 15:01:53.687 EST: //2709/D97D602C9F5B/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 2709 with tag 1 to app "_ManagedAppProcess_Default"
040584: Feb 15 15:01:53.687 EST: //2709/D97D602C9F5B/CCAPI/ccCallProceeding:
040585: Feb 15 15:01:53.691 EST: //2709/D97D602C9F5B/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=20009, Params=0x210165B4, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
040586: Feb 15 15:01:53.691 EST: //2709/D97D602C9F5B/CCAPI/ccCheckClipClir:
040587: Feb 15 15:01:53.691 EST: //2709/D97D602C9F5B/CCAPI/ccCheckClipClir:
040588: Feb 15 15:01:53.691 EST: //2709/D97D602C9F5B/CCAPI/ccCallSetupRequest:
   Destination Pattern=7875239398$, Called Number=7875239398, Digit Strip=TRUE
040589: Feb 15 15:01:53.691 EST: //2709/D97D602C9F5B/CCAPI/ccCallSetupRequest:
   Redirect Number=, Display Info=SASSIN SCOTT
   Account Number=13053892158, Final Destination Flag=TRUE,
   Guid=D97D602C-95B2-11E3-9F5B-9DEE26321C16, Outgoing Dial-peer=20009
040590: Feb 15 15:01:53.691 EST: //2709/D97D602C9F5B/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=7875239398
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
040591: Feb 15 15:01:53.691 EST: //2709/D97D602C9F5B/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x3DC1605C, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=13053892158,(Calling Name=SASSIN SCOTT)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=7875239398(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=20009, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
040592: Feb 15 15:01:53.691 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040593: Feb 15 15:01:53.691 EST: :cc_get_feature_vsa malloc success
040594: Feb 15 15:01:53.691 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040595: Feb 15 15:01:53.691 EST:  cc_get_feature_vsa count is 2
040596: Feb 15 15:01:53.691 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040597: Feb 15 15:01:53.691 EST: :FEATURE_VSA attributes are: feature_name:0,feature_time:1037485680,feature_id:3168
040598: Feb 15 15:01:53.691 EST: //2710/D97D602C9F5B/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
040599: Feb 15 15:01:53.691 EST: //2710/D97D602C9F5B/CCAPI/ccCallSetContext:
   Context=0x21016564
040600: Feb 15 15:01:53.691 EST: //2709/D97D602C9F5B/CCAPI/ccSaveDialpeerTag:
040601: Feb 15 15:01:53.691 EST: //2710/D97D602C9F5B/CCAPI/cc_api_update_call_info:
   Interface=0x3DC1605C, Call Id=0xA96
040602: Feb 15 15:01:53.691 EST: //2709/D97D602C9F5B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <7875239398>
Date: Sat, 15 Feb 2014 20:01:53 GMT
CSeq: 201 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.2.4.M4
Content-Length: 0
040603: Feb 15 15:01:53.695 EST: //2710/D97D602C9F5B/CCAPI/cc_api_call_proceeding:
   Interface=0x3DC1605C, Progress Indication=NULL(0)
040604: Feb 15 15:01:53.695 EST: //2710/D97D602C9F5B/CCAPI/cc_api_call_alert:
   Interface=0x3DC1605C, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
040605: Feb 15 15:01:53.695 EST: //2710/D97D602C9F5B/CCAPI/cc_api_call_alert:
   Call Entry(Retry Count=0, Responsed=TRUE)
040606: Feb 15 15:01:53.695 EST: //2709/D97D602C9F5B/CCAPI/ccCallAlert:
040607: Feb 15 15:01:53.695 EST: //2709/D97D602C9F5B/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
040608: Feb 15 15:01:53.699 EST: //2710/D97D602C9F5B/CCAPI/ccCallFeature:
   Feature Type=25, Call Id=2710
040609: Feb 15 15:01:53.699 EST: //2709/D97D602C9F5B/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=2709
040610: Feb 15 15:01:53.699 EST: //2709/D97D602C9F5B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <7875239398>;tag=79551C6C-1156
CSeq: 201 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Remote-Party-ID: <3010>;party=called;screen=no;privacy=off
Contact: <7875239398>
Content-Length: 0
040611: Feb 15 15:02:03.695 EST: //2710/D97D602C9F5B/CCAPI/cc_api_call_disconnected:
   Cause Value=19, Interface=0x3DC1605C, Call Id=2710
040612: Feb 15 15:02:03.695 EST: //2710/D97D602C9F5B/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=19, Retry Count=0)
040613: Feb 15 15:02:03.695 EST: //2709/D97D602C9F5B/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
040614: Feb 15 15:02:03.695 EST: //2710/D97D602C9F5B/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
040615: Feb 15 15:02:03.695 EST: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
   type=6 redirecting_number=7875239398
040616: Feb 15 15:02:03.695 EST: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectNumber:
   type=6  Original Called Number=7875239398, Called Number=7875239398, Calling Number=13053892158, Calling DN=-1 Calling Id=2709,
   Redirect Number=3999, Redirect Reason=2
040617: Feb 15 15:02:03.695 EST: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
040618: Feb 15 15:02:03.695 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040619: Feb 15 15:02:03.695 EST: :cc_get_feature_vsa malloc success
040620: Feb 15 15:02:03.695 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040621: Feb 15 15:02:03.695 EST:  cc_get_feature_vsa count is 3
040622: Feb 15 15:02:03.695 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040623: Feb 15 15:02:03.695 EST: :FEATURE_VSA attributes are: feature_name:0,feature_time:1037482768,feature_id:3169
040624: Feb 15 15:02:03.695 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
040625: Feb 15 15:02:03.695 EST:  feature_vsa is 3DD6CAC8,featname is 0
040626: Feb 15 15:02:03.695 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040627: Feb 15 15:02:03.695 EST: :cc_get_feature_vsa malloc success
040628: Feb 15 15:02:03.695 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040629: Feb 15 15:02:03.695 EST:  cc_get_feature_vsa count is 4
040630: Feb 15 15:02:03.695 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040631: Feb 15 15:02:03.695 EST: :FEATURE_VSA attributes are: feature_name:0,feature_time:1037483216,feature_id:3170
040632: Feb 15 15:02:03.695 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
040633: Feb 15 15:02:03.695 EST: : Generating new feature vsa,inserting it
040634: Feb 15 15:02:03.695 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
040635: Feb 15 15:02:03.695 EST:  feature call forward featname is 3
040636: Feb 15 15:02:03.695 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
040637: Feb 15 15:02:03.695 EST:  feature_vsa is 3DD6C668,featname is 0
040638: Feb 15 15:02:03.695 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040639: Feb 15 15:02:03.695 EST: :cc_get_feature_vsa malloc success
040640: Feb 15 15:02:03.695 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040641: Feb 15 15:02:03.695 EST:  cc_get_feature_vsa count is 5
040642: Feb 15 15:02:03.695 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040643: Feb 15 15:02:03.695 EST: :FEATURE_VSA attributes are: feature_name:0,feature_time:1037485456,feature_id:3171
040644: Feb 15 15:02:03.695 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
040645: Feb 15 15:02:03.695 EST: : Generating new feature vsa,inserting it
040646: Feb 15 15:02:03.695 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
040647: Feb 15 15:02:03.695 EST:  feature call forward featname is 3
040648: Feb 15 15:02:03.695 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
040649: Feb 15 15:02:03.695 EST: :cc_free_feature_vsa freeing 3DD6BB08
040650: Feb 15 15:02:03.695 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
040651: Feb 15 15:02:03.695 EST:  vsacount in free is 4
040652: Feb 15 15:02:03.695 EST: //2710/D97D602C9F5B/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=19)
040653: Feb 15 15:02:03.695 EST: //2710/D97D602C9F5B/CCAPI/ccCallDisconnect:
   Cause Value=19, Call Entry(Responsed=TRUE, Cause Value=19)
040654: Feb 15 15:02:03.695 EST: //2710/D97D602C9F5B/CCAPI/cc_api_get_transfer_info:
040655: Feb 15 15:02:03.699 EST: //2710/D97D602C9F5B/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3DC1605C, Tag=0x0, Call Id=2710,
   Call Entry(Disconnect Cause=19, Voice Class Cause Code=0, Retry Count=0)
040656: Feb 15 15:02:03.699 EST: //2710/D97D602C9F5B/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
040657: Feb 15 15:02:03.699 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
040658: Feb 15 15:02:03.699 EST: :cc_free_feature_vsa freeing 3DD6C588
040659: Feb 15 15:02:03.699 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
040660: Feb 15 15:02:03.699 EST:  vsacount in free is 3
040661: Feb 15 15:02:03.699 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
040662: Feb 15 15:02:03.699 EST:  vsacount in free is 2
040663: Feb 15 15:02:03.703 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040664: Feb 15 15:02:03.703 EST: :cc_get_feature_vsa malloc success
040665: Feb 15 15:02:03.703 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040666: Feb 15 15:02:03.703 EST:  cc_get_feature_vsa count is 3
040667: Feb 15 15:02:03.703 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040668: Feb 15 15:02:03.703 EST: :FEATURE_VSA attributes are: feature_name:0,feature_time:1037485680,feature_id:3172
040669: Feb 15 15:02:03.703 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
040670: Feb 15 15:02:03.703 EST:  feature call forward featname is 3
040671: Feb 15 15:02:03.703 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
040672: Feb 15 15:02:03.703 EST: :cc_free_feature_vsa freeing 3DD6C668
040673: Feb 15 15:02:03.703 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
040674: Feb 15 15:02:03.703 EST:  vsacount in free is 2
040675: Feb 15 15:02:03.703 EST: //2709/D97D602C9F5B/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=80, Params=0x2101A304, Progress Indication=NULL(0)
040676: Feb 15 15:02:03.703 EST: //2709/D97D602C9F5B/CCAPI/ccCheckClipClir:
040677: Feb 15 15:02:03.703 EST: //2709/D97D602C9F5B/CCAPI/ccCheckClipClir:
040678: Feb 15 15:02:03.703 EST: //2709/D97D602C9F5B/CCAPI/ccCallSetupRequest:
   Destination Pattern=399., Called Number=3999, Digit Strip=FALSE
040679: Feb 15 15:02:03.703 EST: //2709/D97D602C9F5B/CCAPI/ccCallSetupRequest:
   Called Number=3999(TON=Unknown, NPI=Unknown),
   Redirect Number=7875239398, Display Info=SASSIN SCOTT
   Guid=DF764E8C-95B2-11E3-9F61-9DEE26321C16, Outgoing Dial-peer=80
040680: Feb 15 15:02:03.703 EST: //2709/D97D602C9F5B/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=3999
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=73
   cisco-rdn=7875239398
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=2   fwd_final_type =0
040681: Feb 15 15:02:03.703 EST: //2709/D97D602C9F5B/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x22CD9160, Interface Type=3, Destination=, Mode=0x0,
   Called Number=3999(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=80, Call Count On=FALSE,
040682: Feb 15 15:02:03.703 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040683: Feb 15 15:02:03.703 EST: :cc_get_feature_vsa malloc success
040684: Feb 15 15:02:03.703 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040685: Feb 15 15:02:03.703 EST:  cc_get_feature_vsa count is 3
040686: Feb 15 15:02:03.703 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040687: Feb 15 15:02:03.703 EST: :FEATURE_VSA attributes are: feature_name:0,feature_time:1037485680,feature_id:3173
040688: Feb 15 15:02:03.703 EST: //2711/D97D602C9F5B/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
040689: Feb 15 15:02:03.703 EST: //2711/D97D602C9F5B/CCAPI/ccCallSetContext:
   Context=0x2101A2B4
040690: Feb 15 15:02:03.703 EST: //2709/D97D602C9F5B/CCAPI/ccSaveDialpeerTag:
040691: Feb 15 15:02:03.703 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
040692: Feb 15 15:02:03.703 EST:  feature call forward featname is 3
040693: Feb 15 15:02:03.703 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
040694: Feb 15 15:02:03.703 EST:  feature_vsa is 3DD6C668,featname is 0
040695: Feb 15 15:02:03.703 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040696: Feb 15 15:02:03.703 EST: :cc_get_feature_vsa malloc success
040697: Feb 15 15:02:03.703 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040698: Feb 15 15:02:03.703 EST:  cc_get_feature_vsa count is 4
040699: Feb 15 15:02:03.703 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
040700: Feb 15 15:02:03.703 EST: :FEATURE_VSA attributes are: feature_name:0,feature_time:1037485456,feature_id:3174
040701: Feb 15 15:02:03.703 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
040702: Feb 15 15:02:03.703 EST: : Generating new feature vsa,inserting it
040703: Feb 15 15:02:03.703 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
040704: Feb 15 15:02:03.703 EST:  feature call forward featname is 3
040705: Feb 15 15:02:03.703 EST: //2711/D97D602C9F5B/CCAPI/ccGetMediaClassTag:
   media class tag 0
040706: Feb 15 15:02:03.703 EST: //2711/D97D602C9F5B/CCAPI/ccSetMediaclassIp2ipTags:
   media class tags set: NR 0, ASP 0
040707: Feb 15 15:02:03.703 EST: //2709/D97D602C9F5B/CCAPI/ccGetMediaClassTag:
   media class tag 0
040708: Feb 15 15:02:03.707 EST: //2709/D97D602C9F5B/CCAPI/ccSetMediaclassIp2ipTags:
040709: Feb 15 15:02:03.707 EST: //2711/D97D602C9F5B/CCAPI/ccGet_xc_nr_asp_info:
   media class tags: NR 0, ASP 0
040710: Feb 15 15:02:03.707 EST: //2709/D97D602C9F5B/CCAPI/ccGet_xc_nr_asp_info:
040711: Feb 15 15:02:03.707 EST: //2711/D97D602C9F5B/CCAPI/ccGetMediaClassTag:
   media class tag 0
040712: Feb 15 15:02:03.707 EST: //2711/D97D602C9F5B/CCAPI/ccSetMediaclassIp2ipTags:
040713: Feb 15 15:02:03.707 EST: //2709/D97D602C9F5B/CCAPI/ccGetMediaClassTag:
   media class tag 0
040714: Feb 15 15:02:03.707 EST: //2709/D97D602C9F5B/CCAPI/ccSetMediaclassIp2ipTags:
040715: Feb 15 15:02:03.707 EST: //2711/D97D602C9F5B/CCAPI/ccGet_xc_nr_asp_info:
040716: Feb 15 15:02:03.707 EST: //2709/D97D602C9F5B/CCAPI/ccGet_xc_nr_asp_info:
040717: Feb 15 15:02:03.707 EST: //2711/D97D602C9F5B/CCAPI/cc_api_call_disconnected:
   Cause Value=47, Interface=0x22CD9160, Call Id=2711
040718: Feb 15 15:02:03.707 EST: //2711/D97D602C9F5B/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=47, Retry Count=0)
040719: Feb 15 15:02:03.707 EST: //2711/D97D602C9F5B/CCAPI/cc_api_event_indication:
   Event=188, Call Id=2711
040720: Feb 15 15:02:03.707 EST: //2711/D97D602C9F5B/CCAPI/cc_api_event_indication:
   Event Is Sent To Conferenced SPI(s) Directly
040721: Feb 15 15:02:03.707 EST: //2709/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
040722: Feb 15 15:02:03.707 EST: cc_api_get_xcode_stream : 4819
040723: Feb 15 15:02:03.707 EST: //2711/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
040724: Feb 15 15:02:03.707 EST: cc_api_get_xcode_stream : 4819
040725: Feb 15 15:02:03.707 EST: //2709/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
040726: Feb 15 15:02:03.707 EST: cc_api_get_xcode_stream : 4819
040727: Feb 15 15:02:03.707 EST: //2709/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
040728: Feb 15 15:02:03.707 EST: cc_api_get_xcode_stream : 4819
040729: Feb 15 15:02:03.707 EST: //2711/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
040730: Feb 15 15:02:03.707 EST: cc_api_get_xcode_stream : 4819
040731: Feb 15 15:02:03.707 EST: //2709/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
040732: Feb 15 15:02:03.707 EST: cc_api_get_xcode_stream : 4819
040733: Feb 15 15:02:03.707 EST: //2711/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
040734: Feb 15 15:02:03.707 EST: cc_api_get_xcode_stream : 4819
040735: Feb 15 15:02:03.707 EST: //2711/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
040736: Feb 15 15:02:03.707 EST: cc_api_get_xcode_stream : 4819
040737: Feb 15 15:02:03.707 EST: //2709/D97D602C9F5B/CCAPI/ccCallReleaseResources:
040738: Feb 15 15:02:03.707 EST: //2711/D97D602C9F5B/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=2711
040739: Feb 15 15:02:03.707 EST: //2711/D97D602C9F5B/CCAPI/ccCallDisconnect:
   Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=47)
040740: Feb 15 15:02:03.707 EST: //2711/D97D602C9F5B/CCAPI/ccCallDisconnect:
   Cause Value=47, Call Entry(Responsed=TRUE, Cause Value=47)
040741: Feb 15 15:02:03.707 EST: //2711/D97D602C9F5B/CCAPI/cc_api_call_disconnect_done:
   Disposition=-11, Interface=0x22CD9160, Tag=0x0, Call Id=2711,
   Call Entry(Disconnect Cause=47, Voice Class Cause Code=0, Retry Count=0)
040742: Feb 15 15:02:03.707 EST: //2711/D97D602C9F5B/CCAPI/cc_api_call_disconnect_done:
040743: Feb 15 15:02:03.707 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
040744: Feb 15 15:02:03.707 EST: :cc_free_feature_vsa freeing 3DD6C588
040745: Feb 15 15:02:03.707 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
040746: Feb 15 15:02:03.707 EST:  vsacount in free is 3
040747: Feb 15 15:02:03.707 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
040748: Feb 15 15:02:03.707 EST:  vsacount in free is 2
040749: Feb 15 15:02:03.707 EST: //2709/D97D602C9F5B/CCAPI/ccCallDisconnect:
   Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
040750: Feb 15 15:02:03.707 EST: //2709/D97D602C9F5B/CCAPI/ccCallDisconnect:
040751: Feb 15 15:02:03.707 EST: //2709/D97D602C9F5B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 503 Service Unavailable
CSeq: 201 INVITE
Reason: Q.850;cause=47
Content-Length: 0
040752: Feb 15 15:02:03.791 EST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:7875239398@192.254.106.46 SIP/2.0
CSeq: 201 ACK
Content-Length: 0
040753: Feb 15 15:02:03.791 EST: //2709/D97D602C9F5B/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x22CD9160, Tag=0x0, Call Id=2709,
040754: Feb 15 15:02:03.791 EST: //2709/D97D602C9F5B/CCAPI/cc_api_call_disconnect_done:
040755: Feb 15 15:02:03.791 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
040756: Feb 15 15:02:03.791 EST: :cc_free_feature_vsa freeing 3DD6BCC8
040757: Feb 15 15:02:03.791 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
040758: Feb 15 15:02:03.791 EST:  vsacount in free is 1
040759: Feb 15 15:02:03.791 EST: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
040760: Feb 15 15:02:03.791 EST:  vsacount in free is 0
040761: Feb 15 15:02:03.887 EST: %SEC-6-IPACCESSLOGP: list InetIn denied udp 64.94.105.150(0) -> 192.254.106.46(0), 1 packet
no codec g711ulaw
I had forgot to specify the Codec in the incoming dial peer.  Thanks, for the help.
Last question.  I believe that the CUE only accept g711.  Is that correct?  If so, how would I setup transcoding so a g729 call could go to the CUE?
Thanks fo the help!!!
Scott
