SIP-Call with CCME 4.1 - outgoing calls without registration works
we want to use SIP-Softphones (like x-lite) with CCME 4.1.
Everything works fine, after registration with username and password in- and outgoing calls from the phone works.
Our problem is, that outgoing calls are also possible without registration, only specify the IP of the CCME as proxy-address on the softphone is enough.
How can I block this behavior, so username password is always needed to place calls ?
Hall of Fame Super Gold
Re: SIP-Call with CCME 4.1 - outgoing calls without registration
Yes, it is possible, however the configuration required is quite complicated.
Because the feature has been developed for TISP, use of a radius server is generally required. I'm not sure if you can configure username and password local on the router. See:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123cgcr/vvfax_c/callc_c/sip_c/sipc1_c/chapter5.htm
Could you send me
CME config
THANKS
recep.sefer@alannetwork.com
Sorry, I have never configured that and the only information I have is in the document above.
89
