SIP Cisco cube 2921 swapped fields TO and From
Ext.phone  -- SIPProv  -- Cube2921 -- CUCM --Int.phone
call from   Ext.phone 3074211055   -- SIPProv  -- Cube2921 -- CUCM --   to Int.phone 27223344345
debug ccsip messa  from CUBE2921
021949: Jul 29 05:39:55.378: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:27223344345@17.88.18.16:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 172.16.240.4:5060;branch=z9hG4bKqp43rq20aov0ousav3f1.1
From: <sip:3074211055@172.16.240.4:5060;user=phone>;tag=SDcflb301-3830131697
To: <sip:27223344345@17.88.18.16:5060;user=phone>
Max-Forwards: 69
Call-ID: SDcflb301-2d068e330a01af9cc2aff52e778e9ce5-v300g00
CSeq: 22785 INVITE
Accept: application/sdp
Allow: INVITE,ACK,OPTIONS,BYE,CANCEL,PRACK,UPDATE
Supported: 100rel
Content-Type: application/sdp
Contact: <sip:19.7.25.7:5060;transport=udp>
Content-Length: 429
v=0
o=- 1514724 1514724 IN IP4 19.7.25.7
s=-
c=IN IP4 19.7.25.7
t=0 0
a=sendrecv
m=audio 27780 RTP/AVP 8 96 18 97
c=IN IP4 19.7.25.7
b=RR:0
b=RS:0
a=rtpmap:8 PCMA/8000
a=rtpmap:96 AMR/8000
a=fmtp:96 mode-set=0,2,4,7;mode-change-period=2;mode-change-capability=2;mode-change-neighbor=1;max-red=0
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:97 telephone-event/8000
a=fmtp:97 0-15
a=maxptime:40
call is ok.
call is disconnected from Int.phone 27223344345
so CUBE sent BYE to SIPProv
provider told me that it is error according to SIP standart and I have to fix it
022071: Jul 29 05:40:12.718: //48666/9AB9395C9C74/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:19.7.25.7:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 17.88.18.16:5060;branch=z9hG4bK6C41A65
From: <sip:27223344345@17.88.18.16:5060;user=phone>;tag=5349754-20EC
To: <sip:3074211055@172.16.240.4:5060;user=phone>;tag=SDcflb301-3830131697
Date: Tue, 29 Jul 2014 05:39:58 GMT
User-Agent: Cisco-SIPGateway/IOS-12.x
Timestamp: 1406612412
CSeq: 101 BYE
Reason: Q.850;cause=16
Max-Forwards: 70
P-RTP-Stat: PS=712,OS=113920,PR=728,OR=116480,PL=0,JI=0,LA=0,DU=15
Content-Length: 0
SIPProv  sent me 200 ok
022074: Jul 29 05:40:12.730: //48666/9AB9395C9C74/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 BYE
Content-Length: 0
here is config
voice-card 0
 dspfarm
 dsp services dspfarm
voice call send-alert
voice rtp send-recv
voice service pots
 supported-language ru
voice service voip
 ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
 address-hiding
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 redirect ip2ip
 fax protocol t38 nse version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
 h323
  call start slow
  h245 passthru all
 sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
  rel1xx disable
  error-passthru
  registrar server expires max 1200 min 300
  midcall-signaling passthru
  no call service stop
System image file is "flash:c2900-universalk9-mz.SPA.151-4.M8.bin"
1 ACCEPTED SOLUTION
Check the SIP RFC its all
Check the SIP RFC its all there. Link.
Its working as per RFC. Here
Its working as per RFC. Here is the part from RFC....
Invite from Alice to Bob
INVITE sip:bob@biloxi.com SIP/2.0
      Via: SIP/2.0/UDP pc33.atlanta.com;branch=z9hG4bK776asdhds
      Max-Forwards: 70
      To: Bob <sip:bob@biloxi.com>
Bye from Bob to Alice
F13 BYE Bob -> Alice
BYE sip:alice@pc33.atlanta.com SIP/2.0
Via: SIP/2.0/UDP 192.0.2.4;branch=z9hG4bKnashds10
Max-Forwards: 70
To: Alice <sip:alice@atlanta.com>;tag=1928301774
OK from Alice to Bob
F14 200 OK Alice -> Bob
SIP/2.0 200 OK
Manish
tnx. can you please give
tnx. can you please give prooflink or web link
115
