Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
SIP CONNECTION
I am plan to test a sip connection..,but i don't have CUBE licenses,kindly advice me what are information i need to get from telco in order to create BOQ.
Hall of Fame Super Silver
Do you have CUBE hardware
Do you have CUBE hardware (Cisco router)? if so all you need to get is 'paper' license from Cisco via Cisco reseller.
Chris
Hi Sivakalam2What is the type
Hi Sivakalam2
What is the type of Cisco router that will be a CUBE based platform ?  you might already have a 0$ charge for trying SIP trunking using CUBE ( 25 sessions ) with 29xx and 39xx  with UC bundle VSEC-CUBE/K9 for example. Normally you should be able to conduct a SIP Trunk Trial using the platform .
Check the link
http://www.cisco.com/c/dam/en/us/products/collateral/unified-communications/unified-border-element/voice_bundle_change_final.pdf
Thank you
Abdelmoniem E. Rezk
http://ciscoucx.blogspot.co.uk
41
