I'm trying to apply the same caller-id for all calls coming from my itsp provider.
Current Senario:
CUCM --> SIP-Trunk --> CUBE ---> ITSP
Alls incoming calls coming from the ITSP dont have a caller-id.
I'm trying to use sip normalization in the gateway but matching a sip-profile in the incoming dial-peer from the itsp but its not working.
Please help
Current Config
dial-peer voice 200 voip
description ***Incoming calls from SBC***
session protocol sipv2
incoming called-number 285....
vocie-class sip profiles 100
sip-profile
dtmf-relay rtp-nte
codec g711alaw
no vad
voice class sip-profiles 100
request INVITE sip-header Remote-Party-ID add "FROM-ITSP"
dial-peer voice 300 voip
description calls from ***CUCM***
destination-pattern 285....
session target ipv4:192.168.1.1
dtmf-relay rtp-nte
codec g711alaw
no vad
Thanks.
