SIP CUBE - Convert UDP > TCP
Cisco 2821
IOS 15.1(3)T
Trying to configure a Cisco 2821 to receive UDP SIP calls, then send them to a Lync server (which requires TCP). It has a working configuration and is also used for a SIP Trunk.
So I have added a dial-peer to send calls to the Lync Server, calls will match on the Dial-peer and route correctly if I leave the configuration for it as UDP. But if I set the Dial-peer to use TCP the calls stop routing to the Lync server. Running a dial-peer debug shows that the calls are still matching on the Dial-peer, but for some reason don't route.
dial-peer voice 210 voip
description Link to Lync
translation-profile outgoing Lync
preference 1
destination-pattern 164702
session protocol sipv2
session target ipv4:x.x.x.x
session transport tcp
voice-class codec 1
max-redirects 10
dtmf-relay rtp-nte
no vad
Let me know if you need anything cleared up. Voip ccapi debug is attached. Thanks in advance.
1 REPLY
Bronze
1. Can you pink Lync - do you have IP connectivity ?
2. What TCP port is Lync running on? You have 5060 configured.
3. Is there an establishedTCP connection ? You won't see any SIP traffic unless you have a connected TCP session.
"show tcp brief" should show a connection to the link server (look for ESTAB)
Incidently - I've found Lync works better if you re-write the dial peer like this - but only look at this once you have you TCP issue fixed:
preference 1
session target dns:MyDominaGoesHere.com
voice-class sip outbound proxy ipv4:x.x.x.x:5060
voice-class codec 1
max-redirects 10
dtmf-relay rtp-nte
no vad
Adam
1932
