SIP - Cube reporting
dshumake
Level 4
Level 4
I am trying to find a way to report on SIP utilization on the CUBE.  would like to find away to report number of call per hour.
help!!!
thanks
Brian Meade
Level 7
Level 7
You're going to need to pull this in via SNMP- http://www.cisco.com/c/en/us/products/collateral/unified-communications/unified-border-element/white_paper_c11-613550.html
Edit:  If you're using CUCM, there's some SIP Trunk Utilization reports in CAR.
thanks
I will check that out
