SIP Day
couple of SIP questions:
1) I tried to converte an SCCP to SIP with no sucess;
phone 7960; sccp firmware 8.0(4) and boot load PC0303010200;
SIP i tried both versions P0S3-07-5-00; P0S3-08-6-00
i followed the chapter in the admin guide about how to do the conversation also i cheked tac notes
SIPDefaultGeneric.cnf and SIPConfigGeneric.cnf; i only have 5 files with zip for the sip firmware
2) Does ip communicator works with CME sip config version 4.0
3) In case i want to run for internal use CME with SIP (IP phone as well) do i need anything or just SIP firmware for the IP phones.
Good day
Hall of Fame Super Gold
Re: SIP Day
First of all, I suggest you keep your phones as SCCP because generally are easier to administer and have more features. Now:
1. The conversion works. Where is failing for you ?
2. CME can run simultaneously SIP and SCCP phones, hence IPCP will always work.
3. Nothing else.
Re: SIP Day
the IP phone (currently SCCP) giving XMLdefault.. not found. it is like it is still looking for the SCCP and not for SIP.
the following files are in flash:
OS79XX.TXT
P0S3-07-5-00.bin
P0S3-07-5-00.loads
P0S3-07-5-00.sb2
and under voice register globale i pointed to the sip load
load 7960-7940 P003-07-5-00
Good day
Re: SIP Day
1. Verify that all the FW files have been configured with "tftp-server "
2. Configure a "voice register pool" with correct MAC, type and dn number.
3. Under "voice register global" do "create profile".
4. Verify that the correct cnf.xml file has been generated with: "show voice register tftp-bind" and "more ".
The phone should upgrade and register on the next boot.
Re: SIP Day
I will try them and come back to you within 30 min aprox
thanks for your help even in we, you should get doubled points ;-)
Good day
Re: SIP Day
same thing, but now i am not getting anyting on the IP phone, only configuring IP, looking for CM list
attached are some info i got for you
just wondering as the you are sure that all the 7960 could be converted to sip.
one more thing regarding CIPC, i was wonderig if it can be configured as voice register not as ephone. as i could not find the type with v4.0 in CME voice register.
thanks in advance and good day.
Re: SIP Day
i have just enabled telephony-service to see what is happening:
also when i unplug the ip phone and plug it again it give no load found!!!
vg-sip(config)#telephony-service
vg-sip(config-telephony)#exit
vg-sip(config)#^Z
vg-sip#show telephony-service tftp-bindings
tftp-server system:/its/SEPDEFAULT.cnf
tftp-server system:/its/SEPDEFAULT.cnf alias SEPDefault.cnf
tftp-server system:/its/XMLDefault7960.cnf.xml alias SEP001A2F53C711.cnf.xml
Re: SIP Day
please remove "ephone" for the MAC you're converting. If you have removed it already,reboot the router and check there is no entry for the MAC when doing "show telephony-service tftp-bindings"
Regarding the IP communicator, it supports SCCP only, so you will always configure it under "ephone" and never under "voice register pool".
Re: SIP Day
vg-sip#show telephony-service ephone
Number of Configured ephones 0 (Registered 0)
thanks a lot for your help
Good day
Re: SIP Day
The thing as you have seen above, it seems the system retains the tftp-bindings for SCCP even after removing the ephone, so you should reboot the router.
After that the phone should get the correct cnf.xml with load definition for SIP and upgrade.
Re: SIP Day
i did the reoot and inded the telephony-service binding disappeared and we are back to the beggining.
on the IP phone it is lookingfor the XMLDefault.
any way it is not a big issue i would try with another IP phone.
Thanks a lot for your help
Good day
Re: SIP Day
Working.
I took a reboot for the IP phone as well after the router.
that was it.
thanks a lot for your assisstant.
Good one.
Good day
Re: SIP Day
Glad to know it worked. The phones at time can be a bit stubborn, and it takes patience.
Thanks for the nice rating and good luck!
236
