SIP Debug filtering on Cisco Voice Gateway
Below is my configuration on voice gateway :
call filter match-list 1 voice
outgoing called-number 001886.+
debug condition match-list 1 exact-match
debug ccsip messages
And I check the debug status
show debugging
CCSIP SPI: SIP Call Message tracing is enabled          (filter is ON)
But , I still be able to see the SIP message , even it doesn't match the debug condition as below :
Jul 10 07:04:23.471: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:+6628888888@test.com SIP/2.0
P-AV-Message-Id: 2_1
User-To-User: 00FA080004019F51DD0AAF;encoding=hex
Session-Expires: 86400;refresher=uac
Record-Route: <sip:1952b1e5@17.209.112.46;transport=tcp;lr>
Record-Route: <sip:17.209.112.45:15060;transport=tcp;ibmsid=local.1366405052583_25690878_25749261;lr>
Record-Route: <sip:17.127.140.52;transport=tcp;lr>
Min-SE: 86400
History-Info: <sip:+6628888888@test.com>;index=1
History-Info: "+6628888888" <sip:+6628888888@test.com>;index=1.1
Alert-Info: <cid:internal@test.com>;avaya-cm-alert-type=internal
Accept-Language: en
Contact: "DID station" <sip:+6563612442@17.127.140.52;transport=tcp;gsid=f3461500-e92e-11e2-a67c-e41f132eca10>
Allow: INVITE, ACK, OPTIONS, BYE, CANCEL, SUBSCRIBE, NOTIFY, REFER, INFO, PRACK, PUBLISH, UPDATE
Supported: 100rel, histinfo, join, replaces, sdp-anat, timer
Via: SIP/2.0/TCP 17.209.112.46;branch=z9hG4bK194685904640980-AP;ft=96
Via: SIP/2.0/TCP 17.209.112.45:15060;rport=38490;ibmsid=local.1366405052583_25690879_25749262;branch=z9hG4bK1946859
Via: SIP/2.0/TCP 17.209.112.45:15060;rport;ibmsid=local.1366405052583_25690878_25749261;branch=z9hG4bK4879333374516
Via: SIP/2.0/TCP 17.209.112.46;branch=z9hG4bK02c21ed98f7e21e7cf51f6941400-AP;ft=475975;received=17.209.112.46;rport
Via: SIP/2.0/TCP 17.127.140.52;branch=z9hG4bK02c21ed98f7e21e7cf51f6941400
Via: SIP/2.0/TCP 17.127.144.163;branch=z9hG4bK02c21ed98f7e21e7cf51f6941400
From: "DID station" <sip:+6563612442@test.com>;tag=02c21ed98f7e21e5cf51f6941400
To: <sip:+6628888888@test.com>
Call-ID: 02c21ed98f7e21e6cf51f6941400
Max-Forwards: 67
CSeq: 1 INVITE
Content-Type: application/sdp
Content-Length: 232
Av-Global-Session-ID: f3461500-e92e-11e2-a67c-e41f132eca10
P-Location: SM;origlocname="apac-lab-cm";origsiglocname="apac-lab-cm";origmedialocname="apac-lab-cm";termlocname="a
Route: <sip:17.127.140.59;transport=tcp;lr;phase=terminating>
Or Even SIP option
Received:
OPTIONS sip:test.com SIP/2.0
Record-Route: <sip:1952b1e5@17.209.112.46:5068;transport=tcp;lr>
Record-Route: <sip:17.209.112.45:15060;transport=tcp;ibmsid=local.1366405052583_25692122_25750513;lr>
Remote-Party-ID: <sip:17.209.112.45:15060;transport=tcp>;party=calling;screen=no;privacy=off
Contact: <sip:17.209.112.45:15060;transport=tcp>
Expires: 0
User-Agent: AVAYA-SM-6.3.2.0.632023
Via: SIP/2.0/TCP 17.209.112.46:5068;branch=z9hG4bK211513901468451-AP;ft=57
Via: SIP/2.0/TCP 17.209.112.45:15060;rport=35197;ibmsid=local.1366405052583_25692123_25750514;branch=z9hG4bK2115139
Via: SIP/2.0/TCP 17.209.112.45:15060;rport;ibmsid=local.1366405052583_25692122_25750513;branch=z9hG4bK5457733027603
Via: SIP/2.0/TCP 17.209.112.45:15060;rport;ibmsid=local.1366405052583_25692121_25750512;branch=z9hG4bK8353845982764
From: <sip:17.209.112.46>;tag=3718969336612731_local.1366405052583_25692121_25750512
To: <sip:17.127.140.59>
Call-ID: 3713171884946387@17.209.112.45
Max-Forwards: 67
CSeq: 2 OPTIONS
Av-Global-Session-ID: b5839390-e92f-11e2-a67c-e41f132eca10
Content-Length: 0
So , Is there any way to filter those message to not appear on the debug trace ?
Hall of Fame Super Gold
Can be a bug. Find another way to do your troubleshooting, or report to the TAC.
i am running into the same issue.
did you find a solution for is
regards Ron
Hi Ron,
It seems to be a bug for this firmware. I've tried to upgrade fw to version c3900-universalk9-mz.SPA.152-4.M2 and the the SIP filter is working now.
1007
