11-27-2013 07:37 AM - edited 03-16-2019 08:36 PM
All,
running CM 9.1(2) and trying to add an ALtigen IP phone as a 3rd party SIP device. Getting SIP REG FAIL on the phone. I followed the link below but still the same results. Any ideas on where to start troubleshooting this?
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmcfg/b09sip3p.pdf
Thanks in advance. All replies rated.
11-27-2013 09:55 AM
Hi Scott.
Which parameters did you configure on your sip phone.
Remember that Displayed name should be the Directory number defined on CUCM phone, Username should be the same directory number and Authorization Username should be the digest user defied no the phone.
Carlo
11-27-2013 11:17 AM
Thanks Carlo,
I have configured all the parameter in the link I posted. I did have something different in the Displayed Name but I changed that per your suggestion. That didn't change anything. It is still failing. I have the DN configured as the username and the password just trying to make things simple. Could that be the issue?
11-27-2013 11:28 AM
I think I found the issue. According to the document the 3rd part phones have to be configured on the native phone system and then the config on CM has to match. I was trying to do build a phone from the ground up. Thanks for your help!
11-27-2013 11:33 AM
Hi Scott.
I've configured many third party sip phones from the scratch without any issue.
Are your phones now registered to CUCM?
Let me know
Carlo
11-27-2013 12:27 PM
Hello Carlo,
my SCCP phones are registered just fine. This would be ther first SIP phone on the cluster.
11-27-2013 12:33 PM
Hi Scott.
You told that you probably found the issue and so I asked if your Sip phone are ok now? :)
Let me know
Carlo
