Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
SIP dial-peer problem sending *
I have a sip dial-peer with destination-pattern 521T sending calls to a GSM gateway (QUESCOM). the normal calls are working prefectly, but when i tried to call 521*333 for example, the GSM gateway only receives 521 in other words the cisco gateway is stripping the * and the other numbers. Even if a put a specific dial peer with destination-pattern 521*333.
dial-peer voice 1 voip
preference 1
voice-class codec 1
session protocol sipv2
session target ipv4:10.1.1.1
dtmf-relay sip-notify
no vad
dial-peer voice 2 voip
voice-class codec 1
no vad
I trid usinf different DTMF relays with no luck, but i think is not a DTMF relay issue because i'm not pressing any number dureing the call. im just sendind the whole thing.
any advice will be appreciated.
Re: SIP dial-peer problem sending *
Hi German
Have you tried to debug the SIP messages (deb ccsip messages)?
Dial-Peer 2 will not be used since 521T is a better match.
I used the above dial-peers separately with no luck in both cases. in every case the GSM gateway only got 521
You really need to check the SIP messaging. I tried this in the lab and my router was able to send the * in the SIP INVITE with the dial peers just fine.
hth,
nick
190
