SIP Dial-peer translation-rule
I am trying to build a Translation-rule for CUBE.
how do I create a rule for:
range 2183222030-9 Inbound CUBE to CUCM leg.
2183222030 is the company main number.
CUCM DIDs are 2...$
I would like if possible, if someone dial example 2193222034, the inbound dial-peer with destination-pattern 2... to pick up, then translate the last 2...$ into 2034.
How do I write the RULE?
Or is it even possible?
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
voice translation-rule 1 rule
 rule 1 /^2183412)/ /2/
voice translation-profile MyRULE
 translate called 1
and then apply to desired dial peer.
 translate called 1
Thanks George,I hope I did
Thanks George,
I hope I did not make it sound like if someone calls 2183212030 to be forwarded to 2...$
I meant if:
range 2183222031-9 Inbound CUBE to CUCM leg. The inbound dial-peer with destination-pattern 2... to pick up, then translate the last 2...$ into 2034
Employees and their phone numbers:
Sierra 2183222031
Sam 2183222032
Bravo 2183222033
Jennifer 2183222034
Now if someone calls Jennifer's number 2183222034 from their cell phone,
I would like for it to directly ring Jennifer's phone, (extension 2034), same for Sam, Bravo, Sierra and so on.
Is this the same translation-rule ?
Why dont you simply set the
Why dont you simply set the significant digits to 4 ?????
java
if this helps, please rate
www.cisco.com/go/pdi
I fixed it.I used rule 1 /^.*
I fixed it.
I used rule 1 /^.*\(....\)/ /\1/, to set the significant 4 digits.
My appreciations
 translate called 1
AND
rule 1 /^.*\(....\)/ /\1/.
Chris,I made a translation
Chris,
I made a translation-rule to strip all but the last 4 digits and applied it to the Incoming Dial-peer. It is working as expected.
voice translation-rule 2030
voice translation-profile CUBE2phones
 translate called 2030
The Inbound calls work fine with the translation-rule on the incoming dial-peer but the Outbound calls do not work (when the translation-rule is on the incoming dial-peer).
The Outbound dial-peer work Only when there is no translation rule on the incoming dial-peer.
Both the debug voice dialpeer inout and debug ccsip messages indicate that I am CUBE strips all digits and only send the last 4 digits to the PSTN.
Here is the LOG: What do I need to change please?
O-CUBE(config)#do sh run | be dial-p
dial-peer voice 10 voip
 description Inbound to CUBE from ITSP ffor all incoming calls
 translation-profile incoming CUBE2phones
 session protocol sipv2
 session transport udp
 incoming called-number .
 no vad
dial-peer voice 200 voip
 description Outbound to Vitelity[ITSP]
 destination-pattern 1[2-9]..[2-9]......
 session target ipv4:XX.XX.XX.XX [ITSP IP]
 dtmf-relay rtp-nte
 no vad
dial-peer voice 300 voip
 destination-pattern [2-9]..[2-9]......
 dtmf-relay rtp-nte
 no vad
dial-peer voice 15 voip
 description Outbound DP to CUCM for Inbound Calls for all Extensions2...
 destination-pattern 2...$
 session target ipv4:CUCM
 dtmf-relay rtp-nte
 no vad
Also used this rule to strip
Also used this rule to strip all numbers but only the last 4 digits.
894
