SIP dial-peers to two different call Manager clusters
I have a requirement where a voice gateway is to shared between two different Call Manager clusters for incoming and outgoing calls by pointing the dial-peers to two different Call Manager cluster IP.
I know this is possible using H323 but can the same be done using SIP dial-peers?
Yes, assuming they don't overlap in the destination patterns just point each DN as necessary to the cluster where it exists.
Pretty much all you can do with H323 is also possible with SIP
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Thanks. Did you get any oppurtunity to implemented/test this before?
281
