sip Disconnect Cause (CC): 16 Disconnect Cause (SIP): 487 call keep ringing
CLAUDIO RIVAS
Currently i have an scenario with
alcatel (h323) -> 2921 -> SIP Trunk -> Carrier Softswitch
When i call to a PSTN number form an alcatel extension by going through the SIP Trunk from the alcatel extension i herd ringback, and on the PSTN phone rings, when the phone is answered then there is a silence on the call and then sudently drop the call.
I collected the sip debg info
2012-09-14 10:08:43          Local7.Notice          172.16.4.2          5825010: *Sep 14 09:49:34: %SYS-5-CONFIG_I: Configured from console by sistlajo on vty0 (172.16.1.43)
2012-09-14 10:26:08          Local7.Debug          172.16.4.2          5825011: *Sep 14 10:06:59: //2141100/00809F331317/SIP/Call/sipSPICallInfo:
2012-09-14 10:26:08          Local7.Debug          172.16.4.2          5825012: The Call Setup Information is:
2012-09-14 10:26:08          Local7.Debug          172.16.4.2          5825013: Call Control Block (CCB) : 0x9AA6D58
2012-09-14 10:26:08          Local7.Debug          172.16.4.2          5825014: State of The Call        : STATE_DEAD
2012-09-14 10:26:08          Local7.Debug          172.16.4.2          5825015: TCP Sockets Used         : NO
2012-09-14 10:26:08          Local7.Debug          172.16.4.2          5825016: Calling Number           : 3324004900
2012-09-14 10:26:08          Local7.Debug          172.16.4.2          5825017: Called Number            : 37700028
2012-09-14 10:26:08          Local7.Debug          172.16.4.2          5825018: Source IP Address (Sig  ): 10.15.0.22
2012-09-14 10:26:08          Local7.Debug          172.16.4.2          5825019: Destn SIP Req Addr:Port  : 10.255.252.134:5060
2012-09-14 10:26:08          Local7.Debug          172.16.4.2          5825020: Destn SIP Resp Addr:Port : 10.255.252.134:5060
2012-09-14 10:26:08          Local7.Debug          172.16.4.2          5825021: Destination Name         : 10.255.252.134
2012-09-14 10:26:08          Local7.Debug          172.16.4.2          5825022:
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825023: *Sep 14 10:06:59: //2141100/00809F331317/SIP/Call/sipSPIMediaCallInfo:
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825024: Number of Media Streams: 1
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825025: Media Stream             : 1
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825026: Negotiated Codec         : g711alaw
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825027: Negotiated Codec Bytes   : 160
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825028: Nego. Codec payload      : 8 (tx), 8 (rx)
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825029: Negotiated Dtmf-relay    : 6
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825030: Dtmf-relay Payload       : 101 (tx), 101 (rx)
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825031: Source IP Address (Media): 10.15.0.22
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825032: Source IP Port    (Media): 0
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825033: Destn  IP Address (Media): 172.16.250.29
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825034: Destn  IP Port    (Media): 31100
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825035: Orig Destn IP Address:Port (Media): [ - ]:0
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825036:
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825037: *Sep 14 10:06:59: //2141100/00809F331317/SIP/Call/sipSPICallInfo:
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825038: Disconnect Cause (CC)    : 16
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825039: Disconnect Cause (SIP)   : 481
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825040:
Here is the meaningful part of my configuration:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
fax protocol pass-through g711ulaw
h323
  call preserve
modem passthrough nse codec g711ulaw
--More--          sip
  bind control source-interface GigabitEthernet0/1
  bind media source-interface GigabitEthernet0/1
voice class codec 10
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
voice class codec 11
codec preference 1 g729r8
codec preference 3 g711ulaw
voice class codec 12
codec preference 1 g711alaw
codec preference 2 g711ulaw
voice class h323 1
--More--           h225 timeout tcp establish 3
voice translation-rule 10
rule 1 /\([^9].*\)/ /9\1/
voice translation-rule 20
rule 1 /^9/ //
voice translation-rule 21
rule 1 /..../ /3324004900/
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 172.16.4.2 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 172.16.4.2
ip address 10.15.0.22 255.255.255.0
duplex auto
--More--          speed auto
media-type rj45
no cdp enable
ip route 0.0.0.0 0.0.0.0 172.16.4.1
ip route 10.255.252.134 255.255.255.255 10.15.0.254
ip route 172.16.250.0 255.255.255.0 10.15.0.254
ip route 172.16.253.0 255.255.255.0 10.15.0.254
dial-peer voice 4011 voip
description ~-~-~-~-~-~-~-Dir 937700028~-~-~-~-~-~-~-
translation-profile outgoing SalidaSIP2
preference 2
destination-pattern 937700028
session protocol sipv2
session target ipv4:10.255.252.134
session transport udp
voice-class codec 12
dtmf-relay rtp-nte h245-alphanumeric h245-signal cisco-rtp sip-kpml sip-notify
no vad
as you can notice i hardcoded the phone number i'm trying to reach,
Hope to find help soon, on advice thanks!
2 Accepted Solutions
Hi Claudio
Just some thoughts
its better to have (incoming called number .) for calls coming from alcatel through h323 (h323 dial peer)and also the same for calls coming from sip trunk(sip dial peer)
1)Are you able to ping the isp ip
2) incoming calls are working?
3) so the provider is using a calling number athentication(or no authentication at all)
4) The calling number is what isp expecting?
5) did you ask isp to be involed on that?Help with trace etc?
Could you pls answer the above
We will be waiting for the debug ccsip messages
chrysostomos
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Is this the called number 37980899 ?
Can you explain the set up better...Is this diagram correct?
Alcatel---h323--->CUBE--sip trunk-->-ITSP
Where are you making the call from..Is it from alcatel to Carried? or carrier to alcatel?
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
29 Replies 29
I am wondering if the sip trunk is register with the isp
show sip-ua registration status
One question
calls from alcatel are g711 or g729
what protocol have the alcatel phones(sip?)
hi, calls from alcatel are g711alaw and the alcatel phones are analog connected to the pbx, which send the calls to the voice gateway through h323 protocol.
No sip-ua registration because everything is on dial-peers configuration, carrirer is not having authentication.
I noticed there is also a SIP Cause code 481 also, but i think this could be caused depending if the people on the pstn phone answers when the phone rings, if this is distracting lets focus on 487.
2012-09-14 09:57:52          Local7.Notice          172.16.4.2          5825009: *Sep 14 09:38:42: %SYS-5-CONFIG_I: Configured from console by sistlajo on vty0 (172.16.1.43)
2012-09-14 10:41:51          Local7.Debug          172.16.4.2          5825041: *Sep 14 10:22:41: //2141792/80EFAF09D636/SIP/Call/sipSPICallInfo:
2012-09-14 10:41:51          Local7.Debug          172.16.4.2          5825042: The Call Setup Information is:
2012-09-14 10:41:51          Local7.Debug          172.16.4.2          5825043: Call Control Block (CCB) : 0x9AA6D58
2012-09-14 10:41:51          Local7.Debug          172.16.4.2          5825044: State of The Call        : STATE_DEAD
2012-09-14 10:41:51          Local7.Debug          172.16.4.2          5825045: TCP Sockets Used         : NO
2012-09-14 10:41:51          Local7.Debug          172.16.4.2          5825046: Calling Number           : 3324004900
2012-09-14 10:41:51          Local7.Debug          172.16.4.2          5825047: Called Number            : 37700028
2012-09-14 10:41:51          Local7.Debug          172.16.4.2          5825048: Source IP Address (Sig  ): 10.15.0.22
2012-09-14 10:41:51          Local7.Debug          172.16.4.2          5825049: Destn SIP Req Addr:Port  : 10.255.252.134:5060
2012-09-14 10:41:51          Local7.Debug          172.16.4.2          5825050: Destn SIP Resp Addr:Port : 10.255.252.134:5060
2012-09-14 10:41:51          Local7.Debug          172.16.4.2          5825051: Destination Name         : 10.255.252.134
2012-09-14 10:41:51          Local7.Debug          172.16.4.2          5825052:
2012-09-14 10:41:51          Local7.Debug          172.16.4.2          5825053: *Sep 14 10:22:41: //2141792/80EFAF09D636/SIP/Call/sipSPICallInfo:
2012-09-14 10:41:51          Local7.Debug          172.16.4.2          5825054: Disconnect Cause (CC)    : 16
2012-09-14 10:41:51          Local7.Debug          172.16.4.2          5825055: Disconnect Cause (SIP)   : 487
2012-09-14 10:41:51          Local7.Debug          172.16.4.2          5825056:
Thank you for your quick response and regards,
Claudio.
Two questions
What is the ip:172.16.250.29
What is the ip :10.255.252.134
Pls send debug ccsip messages, debug ccsip errors in VG
what is the version of your ios?
Thank you Chrys,
Version 15.0(1)M4
The ip address 172.16.250.29 - The RTP is passed by an rtp forwarder on the carrier side. Seems they handle the RTP on another equipment. I don't think this is an impact, i have a CUCM also using this gateway and sip trunk but on this scenario doesn't have problems.
Currently to place the test again i need to modify the scenario from the Alcatel side and this impacts the user, I'll try to get the debugs as soon as posible.
Claudio.
Hi Claudio
Just some thoughts
chrysostomos
Thank you Chrys,
1.- im able to ping the isp
2.- incomming calls are on another trunk, this is just for outbound
3.- no authentication on the carrier side for sip
4.- yes, they requested us to change the 4 digit extension format (ej. 3811@ip address for a 10 digit number (ej 3312000122@ipaddress)
5.- the carrier is involved
I'm preparing the scenario to collect the debugs.
I taked the debugs from the gateway, thank you for your patience, the callflow is:
alcatel->voice gateway->sip trunk
The caller keeps listening ringback even if the call.
The pstn phone listen silence for a while when the call is answered, but suddently listen fast busy as if the call where disconnected.
Best regards,
Claudio.
Hi Chris, i've noticed about a response from you this morning about changing a parameter on the Alcatel, but now that i'm on site i can't get your post to retrieve the value that you suggested, can you repeat me the value that you suggested on your last/deleted post?
Hi Claudio
Config Alcatel for Fast Start on the H323 connection.
Configured alcatel for Destination: Gateway Fast Start on the Alcatel OmniPCX
Also tryied configured on gateway the following lines:
voice service voip
h323
  call start fast
but the result is the same.
On the destination number there is just silence.
Claudio.
Hi claudio
Did you check without the fast start enable in the cube?
Can you send another one debug?
Hi Chrys,
Please find attached the logs on this post, thank you for your patience, here is the log file that i retrieved.
You will identify the calls by the dialed number 37700028.
Best regards,
Claudio.
First test:
ip route 10.15.0.22  255.255.255.255  10.15.0.254
Test one call with debug
Second test:
Remove the bind commans into sip
Hi Claudio,
I have looked at your traces and here is what I see..
1. Your CUBE sends an invite with delayed offer, that means you do not send any SDP in your invite
2. In this scenario, you cant enable fast start on your h323 trunk becasue cube does not support delayed offer to fast start support.
3. Something is not quite wright with your sip integration to alcatel..
Alcaltel does not send the required sip messages such as "trying", 183 ringing..Insteand alcatel sends 2oo ok without any SDP parameter...then sends 183 with media change, and sends it multiple times because cube does not send any ACK to it. I belive the reason is because cube does not understand what the message is for..
So here is my advice
1. Try and enable early offer on your cube
voice service voip
sip
early-offer forced.
Then test again..If this doesnt work, you will need to check CCO for how to integrate your version of Alcatel with CUCM and CUBE
