SIP Disconnect Cause (SIP) : 404
Hi there,
I am having issues with dialling a cirtain number (999) which is being routed to a SIP Carrier, all other calls work, but this fails everytime. What I am seeing when debugging ccsip calls are the following disconnect codes..
Disconnect Cause (CC)    : 1
Does anyone know what these are? I cannot find anything anywhere which tells me what these mean..
Cheers.
  • IP Telephony
A SIP 404 is a generic error for failed to establish call (It can mean anything from "This number doesn't exist", to "You're not allowed to call this number (but it does exist)" to "System error making call")
As other numbers work, and this is a SIP trunk, you might want to check with your provider that they accept 999 calls.
GTG
Please rate all helpful posts.
Gold
Also check to ensure you're not digit stripping the leading "9" from outbound calls... Commonly "9" is used to identify an external call - and is stripped before being sent to the carrier. You may find that you're stripping the leading 9 and asking the SIP provider to dial "99" which will fail...
HTH. Barry
Barry Hesk
Intrinsic Network Solutions
I don't know about SIP providers, but I know some TDM carriers (e.g. BT) accept just "99" for "999" calls for exactly this reason.
GTG
Gold
BT being helpful... Now there's a first
Barry Hesk
Thanks for the replies chaps,
I found out what the issue was, and its a real duck-egg. All dial-peers had a destination add of 9T, so 999 didnt match.
Thanks for the input!
Bronze
wanted to chime in with my expereience recently on this.
for us, it was for an initial deployment, and the 404 was caused by a misconfigured CSS on the trunk.
13976
