SIP Error on CCME
Chuan Liu
I have one remote CCME and one home CCME. Calls from remote local to home local ( to bypass toll charge) hit remote ccme, go through a SIP proxy(VoiceMaster) and hit home ccme.
The call is not working. 'debug ccsip message' and 'debug ccsip error' on the home ccme are as follows. Can someone help me understand unsolicited notify absent and internal server error?
001296: Feb 16 08:43:01.150: //886/0CE4DA0DA947/SIP/Error/sipSPIProcessCallInfoHeader: Call-Info header with for Unsolicited Notify Absent,Disabling Unsolicited Notifies
001297: Feb 16 08:43:01.150: //886/0CE4DA0DA947/SIP/Error/sipSPI_ipip_copy_sdp_to_channelInfo:
failed to update call entry
001298: Feb 16 08:43:01.162: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 202.162.176.66:5060;branch=z9hG4bK9F2F1F03
From: <sip:021856588@202.162.176.66>;tag=A866A82C-2F5
To: <sip:049174380@202.162.180.9>
Date: Fri, 15 Feb 2008 19:43:01 GMT
Call-ID: CF1AB1E-DB3511DC-BE86F0A7-DB03B71B@202.162.176.66
Timestamp: 1203104581
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 101 INVITE
Allow-Events: telephone-event
Content-Length: 0
001299: Feb 16 08:43:01.166: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 500 Internal Server Error
To: <sip:049174380@202.162.180.9>;tag=E48C3A0-1B6D
CSeq: 101 INVITE
Reason: Q.850;cause=63
Content-Length: 0
001300: Feb 16 08:43:01.190: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:049174380@202.162.180.9:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Thanks in advance.
paolo bevilacqua
Hi, it seems to me you're trying to have one ccme do sip to sip calls. That requres ip-to-ip gw image, the ones that ends with _isv, and "allow connections sip to sip" under voice service voip.
"allow connections sip to sip" is configured on both ccme. Some numbers are working, some are not, even the configs are exactly similar.
Well, the thing is that without an _ivs image, you are not guaranteed that ip to ip calls do work.
Robert Salazar
You may want to place the call from the CME where these debugs were taken and not go through the SIP trunk to see if the call can be placed successfully.
I've seen the 500 internal server error message when the gw cannot properly route the call.
