01-16-2012 09:44 AM - edited 03-16-2019 09:02 AM
im trying to make calls on my 3700 router with 12.4(25d). I can register into my sip provider but when i call into the router with my external DID, i get this error in my debug cccsip message: 400 Bad Request - Invalid Host. I searched for this error and i got to this:
http://www.cisco.com/en/US/docs/ios/voice/command/reference/vr_p2.html#wp1111046
Basically saying i need to add my hostname into my config to prevent this error during the intitial invite message.
usage:
sip-ua
permit hostname dns: domain name
According to the docs, this should be available as of 12.4(9) however, my ios 12.4(25d), doesnt accept this as a valid command. So im wondering if any body knows that if this command has been replaced by something else or if there is any other way to prevent the 400 Bad Request - Invalid Host during the intital sip invite. Thanks in advance for the help.
Solved! Go to Solution.
01-16-2012 01:53 PM
I afraid that small business router (not a true Cisco) is not doing the task correctly, as it doesn't translate the public address:
INVITE sip:6474788692@24.246.78.233:64270 SIP/2.0
It should replace it with the private IP.
01-16-2012 09:48 AM
I never know about the need to configura that command. Can you post the complete trace with public IPs and numbers masked. Please do not use attachments.
01-16-2012 09:57 AM
*Mar 1 00:09:11.015: %SYS-5-CONFIG_I: Configured from console by console[OK]
Router#
*Mar 1 00:09:17.639: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 174.137.63.206:5060;branch=z9hG4bK45022c7e;rport
From: "6477242754" <6477242754>;tag=as0edb12126477242754>
To: <6474788692>6474788692>
Contact: <6477242754>6477242754>
Call-ID: 6f84457e1ba32bc7533912de6b2b9068@174.137.63.206
CSeq: 102 INVITE
User-Agent: VoIPMS/SERAST
Max-Forwards: 70
Remote-Party-ID: "6477242754" <6477242754>;privacy=off;screen=no6477242754>
Date: Mon, 16 Jan 2012 17:56:22 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
Supported: replaces
Content-Type: application/sdp
Content-Length: 291
v=0
o=root 15898 15898 IN IP4 174.137.63.206
s=session
c=IN IP4 174.137.63.206
t=0 0
m=audio 12000 RTP/AVP 0 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
*Mar 1 00:09:17.651: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 400 Bad Request - 'Invalid IP Address'
To: <6474788692>;tag=88254-1CCB6474788692>
Date: Fri, 01 Mar 2002 00:09:17 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 102 INVITE
Allow-Events: telephone-event
Content-Length: 0
*Mar 1 00:09:17.691: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:6474788692@24.246.78.233:64270 SIP/2.0
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
01-16-2012 10:00 AM
24.246.78.233 is my public ip
the router ip is 192.168.1.195
And as you see this the error indacated i nthe permit command. Its dtrange im getting it and the command been removed. Thnanks.
01-16-2012 10:03 AM
and here is my sip-ua registration log
*Mar 1 00:13:44.107: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:174.137.63.206:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.195:5060;branch=z9hG4bKE17F7
From: "123558_1" <123558_1>;tag=C91C4-1E20123558_1>
To: "123558_1" <123558_1>123558_1>
Date: Fri, 01 Mar 2002 00:13:44 GMT
Call-ID: 5AC6AC1B-2BDF11D6-80058EE3-621364BF
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1014941624
CSeq: 6 REGISTER
Contact: <123558_1>123558_1>
Expires: 180
Authorization: Digest username="123558_1",realm="toronto2.voip.ms",uri="sip:174.137.63.206:5060",response="6b00e2b5bd7e18b6a99c9624eb102ed6",nonce="5b1bc350",algorithm=MD5
Content-Length: 0
*Mar 1 00:13:44.295: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.1.195:5060;branch=z9hG4bKE17F7;received=24.246.78.233
To: "123558_1" <123558_1>;tag=as47b424de123558_1>
CSeq: 6 REGISTER
Supported: replaces
Expires: 180
Contact: <123558_1>;expires=180123558_1>
Date: Mon, 16 Jan 2012 18:00:49 GMT
Content-Length: 0
*Mar 1 00:13:44.383: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 6 REGISTER
Supported: replaces
Content-Length: 0
*Mar 1 00:13:44.387: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 6 REGISTER
Supported: replaces
Expires: 180
Content-Length: 0
01-16-2012 10:11 AM
You are using a NAT device that does not perform SIP ALG.
Consequently, the router gives the error.
You can play around to try to avoid that, but the best solution is either give router a public address, or use a NAT device that works correly, like the Cisco ones.
01-16-2012 10:14 AM
oh so you are saying the problem is the internet router in front of the gw?
01-16-2012 10:22 AM
Yes, and indicated the recommended solutions.
Please remember to rate useful posts clicking on the stars below.
01-16-2012 10:36 AM
ok, my cisco E3000 router has an option for sip alg and i enabled it but im still getting the same error:
*Mar 1 00:46:38.371: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 174.137.63.206:5060;branch=z9hG4bK00e1283b;rport
From: "6479857249" <6479857249>;tag=as3e71241e6479857249>
Contact: <6479857249>6479857249>
Call-ID: 2a25279c7fa0f89735586b3b6aa65e3b@174.137.63.206
CSeq: 102 INVITE
Max-Forwards: 70
Remote-Party-ID: "6479857249" <6479857249>;privacy=off;screen=no6479857249>
Date: Mon, 16 Jan 2012 18:33:43 GMT
Supported: replaces
Content-Length: 291
v=0
s=session
t=0 0
m=audio 17328 RTP/AVP 0 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
*Mar 1 00:46:38.391: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <6474788692>;tag=2AB32C-6CB6474788692>
Date: Fri, 01 Mar 2002 00:46:38 GMT
CSeq: 102 INVITE
Content-Length: 0
*Mar 1 00:46:38.903: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 102 INVITE
Content-Length: 0
01-16-2012 01:53 PM
01-16-2012 02:07 PM
what if i use sip-profile voip class? Do you think i will be able to replace/modify the invite sip header to the extent it it would work? Thanks alot for all the help.
01-16-2012 02:42 PM
As indicated above already, you should solve the problem at the root instead of messing around on the gateway.
That is because when a devices misbehaves with voice, its a problem after another.
01-17-2012 09:07 AM
Thanks for the help Paolo.
01-17-2012 09:10 AM
Thank you for the nice rating and good luck!
01-20-2012 09:06 AM
I worked around this by changing my sip provider. I found this new one that actually takes care of NAT on thir side and sends me message with my private ip embeded in them. teltub.com is this new provider in case somebody else wants to use it. The one that was giving me NAT problem was viop.ms. Thanks.
