Community Member
SIP Fax to email
I am looking for a design guide or a config example that's taking inbound numbers from a SIP trunk and sending it to the onramp fax application. I have been able to get this to work in the past with PRIs but not luck so far with SIP. Thanks in advance.
Community Member
Re: SIP Fax to email
I have loaded the latest T.38 tcl fax detect script, has anyone had any luck getting this to work with inbound SIP trunk?
Unfortunately T37 onramp isn't supported with an incoming voip dial-peer. The latest version of the fax-detect script can route it to a different number, however. Which are you looking to do?
-nick
174
