02-15-2012 10:56 AM - edited 03-16-2019 09:37 AM
I am going to deploy Call Manager 8.6. and planning to use SIP as a gateway protocol. Is there any pros and cons to use SIP instead of H323 protocol and also I tried to find the configuration guide to integrate with CM 8.6. Anybody has any idea where I can find the proper document. Will appreciate your expert help.
Thanks.
02-15-2012 11:20 AM
Either one is perfectly fine as both share similar feature sets and are peer-to-peer protocols requiring dial-peers. I've done both successfully.
HTH,
Chris
02-15-2012 12:03 PM
Hi Chris,
Thanks for your reply. Is there any document which I can a take a look for the deployment?
Thanks.
02-15-2012 12:16 PM
Check out "SIP Gateway" secrtion in SRND doc:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_implementation_design_guides_list.html
HTH,
Chris
