sip incoming authentication
I have been having quite a bit of trouble wrapping my head around this issue.
I register to ITSP and that is fine. Outgoing works ok. Incoming does not seem to work:
SIP/2.0 403 Incorrect Authentication
SIP/2.0 403 Forbidden
Reason: Q.850;cause=57
sip-ua authentication is configured to match and passwords double checked
problem is resolved by adding the ITSP username to the ephone-dn
I don't really understand why this makes a difference authentication-wise
ephone-dn  100
number 100 secondary 1777MYCCID no-reg primary
Everyone's tags (6)
3 ACCEPTED SOLUTIONS
Re: sip incoming authentication
Hi Evan.
Can you please post running config?
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Evan
On your dial-peer 6 use incoming called-number 17772760570110
Try and let me know.
Carlo
Hi Evan
Under sip-ua change the realm on authentication section.
remove -->> authentication username 17772760570110 password realm callcentric.com
add -->>> authentication username 17772760570110 password realm 68.112.156.253
Carlo
Hi.
To register inbound number, use credential statement under sip-ua
eg
sip-ua
credential number 12345677 username user password password realm sipdomain.com
registrar 1 dns:sip.dipdomain.com:5060
Carlo
Carlo hello and thank you for the reply. Below you will find my more configuration. Incoming calls still fail without the sip ID configured on ephone-dn
sip-ua
credentials username 1777MYID password foo realm callcentric.com
authentication username 1777MYID password foo realm callcentric.com
no remote-party-id
retry invite 4
retry response 3
retry bye 2
retry cancel 2
retry register 5
timers register 250
registrar dns:callcentric.com expires 3600
sip-server dns:callcentric.com:5060
host-registrar
dial-peer voice 6 voip
description ## INBOUND DID ##
translation-profile incoming INC
destination-pattern 1777MYID
session protocol sipv2
session target dns:callcentric.com
dtmf-relay sip-notify rtp-nte
codec g711ulaw
no vad
voice translation-rule 1
rule 1 /100/ /1777MYID/
voice translation-rule 2
rule 1 /1777MYID/ /100/
voice translation-profile INC
translate called 2
voice translation-profile OUTGOING
translate calling 1
I have asked the provider but they are unsure as they do not have a Cisco IOS gateway for testing.
Hi All,I am having a similar
Hi All,
I am having a similar issue, however my IOS on the CME router is (C3845-ADVIPSERVICESK9-M), Version 12.4(22)T. Outbound calls via the sip provider is working but inbound calls are not. Below is the output of my running config and debug.
version 12.4
voice service voip
 callmonitor
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 supplementary-service h450.12
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 redirect ip2ip
 h323
 sip
  registrar server expires max 250 min 200
  localhost dns:voip.****.com
voice class codec 100
 codec preference 1 g711ulaw
 codec preference 2 g711alaw
 codec preference 3 g723r53
 codec preference 4 g729r8
 codec preference 5 g729br8
 codec preference 6 g726r32
 codec preference 7 g728
 rule 1 /7120013/ /1200/
 rule 1 /^911$/ /911/
 rule 2 /^9\(.*\)/ /\1/
voice translation-rule 3
 rule 1 /^1200$/ /23417120013/
voice translation-rule 4
 rule 1 /^9(.......)$/ /01\1/
 rule 3 /^9(.*)/ /\1/
voice translation-profile Call_Inbound
 translate called 1
voice translation-profile PSTN_Outgoing
 translate calling 3
 translate called 2
 translate redirect-target 4
 translate redirect-called 4
dial-peer cor custom
 name all
 name Landline
 name Mobile
 name International
 name National
 name Internal
dial-peer cor list executive
 member all
dial-peer cor list all-numbers
 member all
dial-peer cor list Internal-Numbers
 member Internal
dial-peer cor list Landline-Numbers
 member Landline
dial-peer cor list Mobile-Numbers
 member Mobile
dial-peer cor list International-Calls
 member International
 member Internal
 member Landline
 member National
 member Internal
 member Landline
 member Mobile
 member National
 member Internal
 member Landline
 member Mobile
 member National
 member Internal
dial-peer cor list National-Numbers
 member National
dial-peer voice 11 voip
 description **Incoming Call from SIP Trunk**
 translation-profile incoming Call_Inbound
 voice-class sip dtmf-relay force rtp-nte
 session target dns:voip.****.com
 incoming called-number .T
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 12 voip
 corlist outgoing International-Calls
 description **Outgoing Call to SIP Trunk**International Numbers
 translation-profile outgoing PSTN_Outgoing
 destination-pattern 9T
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 13 voip
 corlist outgoing Landline-Numbers
 description **Outgoing Call to SIP Trunk**Landline Numbers**Lagos
 destination-pattern 901.......
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 14 voip
 corlist outgoing National-Numbers
 description **Outgoing Call to SIP Trunk**Landline Numbers**National2
 destination-pattern 90[2-9][2-9].......
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 15 voip
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 16 voip
 corlist outgoing Mobile-Numbers
 description **Outgoing Call to SIP Trunk**Mobile Numbers
 destination-pattern 90[78].........
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
sip-ua
 credentials username 23417120013 password 7 1445151E1D153F3A272D realm voip.xxxx.com
 keepalive target dns:voip.****.com
 authentication username 23417120013 password 7 124B0202031A1915292E realm voip.xxxx.com
 retry invite 2
 retry register 10
 retry options 1
 timers connect 100
 registrar dns:voip.****.com expires 3600
 sip-server dns:voip.****.com
 host-registrar
 permit hostname dns:voip.****.com
telephony-service
 no auto-reg-ephone
 em logout 0:0 0:0 0:0
 max-ephones 40
 max-dn 80
 ip source-address 192.168.1.82 port 2000
 timeouts interdigit 5
 timeouts busy 20
 timeouts ringing 20
 system message Chams
 url directories http://192.168.1.82/localdirectory
 load 7911 SCCP11.7-2-1-0S
 load 7960-7940 P00308000500.loads
 time-zone 23
 time-format 24
 max-conferences 8 gain -6
 web admin system name admin password chams*01
 dn-webedit
 time-webedit
 transfer-system full-consult
 secondary-dialtone 9
 create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1  dual-line
 number 1200
 name ABA
 corlist incoming International
ephone  1
 device-security-mode none
 mac-address 0026.0B5E.5556
 type 7940
 button  1:1 2:20
*Apr  2 13:24:58.836: //890/000000000000/SIP/Transport/sipSPISendRegister: Sending REGISTER to the transport layer
*Apr  2 13:24:58.836: //890/000000000000/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
*Apr  2 13:24:58.836: //890/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x67E96228, addr=41.221.164.4, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x61741564
*Apr  2 13:24:58.836: //890/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Apr  2 13:24:58.836: //890/000000000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Apr  2 13:24:58.836: //890/000000000000/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x67E96228
*Apr  2 13:24:58.836: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x67E96228, addr=41.221.164.4, port=5060, connId=2 for UDP
*Apr  2 13:24:58.836: //890/000000000000/SIP/State/sipSPIChangeState: 0x70EAA778 : State change from (SIP_STATE_OUTGOING_REGISTER, SUBSTATE_NONE)  to (SIP_STATE_OUTGOING_REGISTER, SUBSTATE_NONE)
*Apr  2 13:24:58.840: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:voip.****.com:5060 SIP/2.0
Date: Wed, 02 Apr 2014 13:24:58 GMT
Authorization: Digest username="23417120013",realm="voip.****.com",uri="sip:voip.****.com:5060",response="4eb44f0f8bd51d914514c7d66f29a635",nonce="1396443258:242409a6de6a94b034fea3058e5c8614",algorithm=MD5
Timestamp: 1396445098
Content-Length: 0
User-Agent: Cisco-SIPGateway/IOS-12.x
To: <sip:1222@voip.****.com>
Contact: <sip:1222@41.58.134.146:5060>
Expires: 3600
Call-ID: 9CDE3986-B99111E3-82E2D20E-52D92922
Via: SIP/2.0/UDP 41.58.134.146:5060;branch=z9hG4bK4DD634
CSeq: 47 REGISTER
Max-Forwards: 70
*Apr  2 13:24:58.864: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [41.221.164.4]:5060
*Apr  2 13:24:58.864: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*Apr  2 13:24:58.864: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Apr  2 13:24:58.864: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Apr  2 13:24:58.864: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:1222@voip.****.com>;tag=d672fb14
CSeq: 47 REGISTER
Content-Length: 0
*Apr  2 13:24:58.864: //890/000000000000/SIP/Error/ccsip_api_register_result_ind: Message Code Class 4xx Method Code 100 received for REGISTER
*Apr  2 13:24:58.864: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_register_free_rcb: Freeing rcb
*Apr  2 13:24:58.864: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_register_reset_dns_cache: CCSIP_REGISTER:: Primary registrar DNS resolved addr reset
*Apr  2 13:24:58.864: //-1/xxxxxxxxxxxx/SIP/Info/ccsipRegisterStartExpiresTimer: Starting timer for pattern 1222 for 180 seconds
*Apr  2 13:24:58.864: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[666] removed.
*Apr  2 13:24:58.864: //890/000000000000/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
*Apr  2 13:24:58.864: //890/000000000000/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x70EAA778 key=9CDE3986-B99111E3-82E2D20E-52D92922
*Apr  2 13:24:58.868: //890/000000000000/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
*Apr  2 13:24:58.868: //890/000000000000/SIP/Info/ccsip_qos_cleanup: Entry
*Apr  2 13:24:58.868: //890/000000000000/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
*Apr  2 13:24:58.868: //890/000000000000/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 70EAA778
*Apr  2 13:24:58.868: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[666]
Hi Evan.
Can you please share the output of show sip-ua register status and a debug ccsip message
Carlo
Carlo
I get registration 2 ways
1) Adding SIPID to the ephone-dn as a secondary number
2) Removing secondary number and "registrar dns:callcentric.com expires 3600", and replacing with "registrar 1 dns:callcentric.com:5060 expires 3600" as you indicated above. I do not get a registration without modifying the sip-ua config after removing secondary number.
Both look like this:
--------------------- Registrar-Index  1 ---------------------
Line                             peer       expires(sec) registered P-Associ-URI
17772760570110                   -1         6            yes
Method 1 works for incoming calls
Method 2 fails with following messages. (I hope pastebin will be ok, sip debug is very long)
link removed
http://pastebin.com/CyXWXmN1registrar 1 dns:sip.dipdomain.com:5060--------------------- Registrar-Index  1 ---------------------
Hi Evan.
Carlo
Sure, thank you for your continued support on this.
Do not worry about credentials. I will review them all later.
link removed
Hi Evan
Carlo
Carlo,
You've done it. Incoming calls are working now!
I did not read this doc well enough, it would seem:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
Too many nights of staring a debugs!
In any case, I cannot possibly thank you enough.
Here is the full config:
voice service voip
ip address trusted list
! ADD YOUR PROVIDERS IPV4 ADDRESSES HERE
redirect ip2ip
sip
! WAN INTERFACE
  bind control source-interface FastEthernet0/1
  bind media source-interface FastEthernet0/1
  e911
  registrar server expires max 36000 min 600
  localhost dns:callcentric.com
  outbound-proxy dns:callcentric.com
rule 1 /EXTENSION/ /SIPID/
! REPLACE THESE TO MATCH YOUR INFORMATION
rule 1 /SIPID/ /EXTENSION/
translate called 2
translate calling 1
incoming called-number SIPID
codec g711ulaw
no vad
description ### LD USA ###
translation-profile outgoing OUT
destination-pattern 1[1-9]..[1-9]......
! YOU MAY NEED TO CHANGE THIS DEPENDING ON YOUR LOCATION
session target dns:callcentric.com:5060
session transport udp
codec g711ulaw
dial-peer voice 10 voip
destination-pattern .T
codec g711ulaw
sip-ua
credentials username password realm callcentric.com
authentication username password realm
no remote-party-id
retry invite 4
retry response 3
retry bye 2
retry cancel 2
retry register 5
timers register 250
host-registrar
telephony-service
no auto-reg-ephone
max-ephones 42
max-dn 144
ip source-address 172.16.1.1 port 2000
no caller-id name-only
calling-number initiator
time-zone 8
voicemail 202
max-conferences 4 gain -6
transfer-system full-blind
transfer-pattern .T
ephone-dn  100
! MAKE SURE THIS MATCHES YOUR VOICE TRANSLATION RULES
number 100 no-reg primary
ephone  100
mac-address 3191.7E4E.0082
max-calls-per-button 2
type anl
button  1:100
Hi Evan.
Thank you for nice rating and I'm glad to help.
Carlo
Carlo
I think I spoke too soon. For some reason now outgoing fails with the same error.
Hi Evan.
Can  you please send the output of debug ccsip message during a failing call?
Carlo
Hello again Carlo
Here are the debugs
All are from calling my cell number from EXT 100
Config
link removed
CCSIP Messages
link removed
Translation
link removed
Dial-Peer
link removed
Message was edited by: Evan Roggenkamp (remove links)
Hi Evan.
Modify you dial-peer 11 as follow
Please attach a full trace of a call using debug ccsip messages.
Carlo
Carlo
I have made the change. Here is the debug output.
link removed
If I may note there is a significant difference between debugs on the IOS platform and on my Asterisk system (which works OK in/out with the same ITSP)
I will leave them here in the event they may help; otherwise, disregard.
link removed
All the best,
Evan
Hi Evan
Carlo
Carlo
You have done it again! Everything is working as expected. Tested BOTH ways this time, to be sure. Much I have to learn about the SIP protocol it would seem.
You have saved me much time and further frustration by your assistance; dinner is on me!
Thank you again, and all the best.
Thank you again for nice rating and for the dinner :)
Please keep on posting whenever you need
Best regards
Carlo
1535
