SIP incoming call Match with H323 Dialpeer, Why?
Hi everyone,
I'm working with a Cisco 3945 (CUBE) and I have realized that a SIP incoming call is matching a H323 Dialpeer. Could a SIP call match a H323 Dialpeer?
dial-peer voice 2 voip
incoming called-number .
voice-class codec 1
dtmf-relay h245-alphanumeric rtp-nte
no vad
Debug:
*Nov 13 08:02:12.622: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=8095445000, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=NO_MATCH(-1) After All Match Rules Attempt
*Nov 13 08:02:12.622: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
*Nov 13 08:02:12.622: //-1/BCBDC6278B46/DPM/dpAssociateIncomingPeerCore:
   Calling Number=8095445000, Called Number=5449, Voice-Interface=0x0,
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=2
*Nov 13 08:02:12.622: //-1/BCBDC6278B46/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
*Nov 13 08:02:12.622: //-1/BCBDC6278B46/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=5449, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=5449
   Result=Success(0) after DP_MATCH_DEST
   dialstring=5449, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
*Nov 13 08:02:12.622: //-1/BCBDC6278B46/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=11
     2: Dial-peer Tag=12
     3: Dial-peer Tag=31 *Nov 13 08:02:12.622: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=SUCCESS(0)
     1: Dial-peer Tag=11
     2: Dial-peer Tag=12
     3: Dial-peer Tag=31
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
__________________________________________________
1 ACCEPTED SOLUTION
Re: SIP incoming call Match with H323 Dialpeer, Why?
@aokanlawon I guess we both know a voip dialpeer won't match a call coming from the TDM world, and vice versa, a POTS dialpeer will not ever match a call coming from the VOIP world, even if the incoming called-number (or destination-pattern or answer address) would be a potential match. I believe this distinction made leosalcie confused - if voip does not match pots and pots does not match voip, then perhaps voip with SIP should not match voip with H.323. But as I said in my previous post, regardless of the signalling protocol, SIP or H.323, if it's voip, it matches.
G.
yes, it's either POTS or VOIP (or VOATM etc), regardless of the signalling protocol used.
I noticed this behaviour as well but can't find an explanation at the available documents. I might be looking at the incorrect ones, I must admit.
G.
I have not found any documenation regarding this case. My concern is beacause maybe at the future this scneario will cause trouble so is better to avoid it...
VIP Super Bronze
Leo,
The issue is with the wild card (incoming called number .) I suggest you define specific dial-peer to match your inboound sip calls..eg
dial-peer voice 3 voip
incoming called number 9XXXXXX
session protocol sipv2
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hi aokanlawon,
I know why the call is match but why a SIP call is matching a H323 Dialpeer? is this secnario supported?, that's the real question here.
VIP Super Bronze
Leo calls are not matched based on protocols. Calls are matched based on calling and called number. This scneario cound give you issues because what you want is sip signalling going to your CUBE. One key issue you will have is that when you attempt to troiubleshoot and you turn on sip relates debugs, you woundlt see anything for the inbound leg because your inbound leg is not sip, its h323. This could also lead to call failure...
So in summary, Cisco IOS gateways are not looking to match calls to dial-peers based on protocols, rather based on calling and called number
G.
VIP Super Bronze
Gergely (+5) Good point on the POTS and VOIP comparison. I have never considered becuase I just know like you said that an inboud POTS call wont match a VOIP dial-peer and vice versa.
Both have answered my doubt. Thanks (+5)
247
